Question about Toshiba Office Equipment & Supplies
Toshiba 451c "can not find HDD data" message
From troubleshooting: HDD seems ok = data visible when attached to PC via usb/ide dongle. Cloned HDD to new HDD but same message. With No HDD installed msg changes to "Can not mount HDD" Tried {Clear] + [3] option [3] "delete/create new partition.." with both orig and new HDD but the "initilize HDD table" msg soon replaced by "initialize erro" msg. Also tried new HDD cable and various Master cable select positions for HDDs jumpers. I suspect the SYS board faulty?
    Problem Solver:
  • 15 Answers
Had the same problem and solved inserting and extracting the card a whole bunch of times and blowing hard inside the slot. You can also try using the rubber to clean the contacts of the SD. God luck.
Posted on Nov 22, 2013
5 Suggested Answers
  • 287 Answers
SOURCE: Cannot reset the change drum soon message after replacing drum.
This message would appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
This message would continue to appear if the clear plastic starter sheet was removed from the "new" drum before it was installed. This plastic starter sheet, resets the drum counter. To reinstall drum with the starter sheet, please follow the instructions listed below:
Locate the starter sheet. Clear plastic sheet, 9 inches long, with a cut out in the center. The sheet will have "Initialization of your new drum successfully completed. Please discard this sheet" written on it.
If you cannot locate the starter sheet, contact the Brother Customer Service or the appropriate Brother authorized dealer.
additionl info HERE
Posted on Jul 11, 2008
daryn720
  • 113 Answers
SOURCE: canon mp620 -cannot change wi-ficonnection back to USB
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=17406
HERE IS THE SITE FOR YOUR MANUAL .....ALL THE ANSWERS ARE THERE ....GOOD LUCK !
Posted on Jun 02, 2009
HP Xpert
  • 112 Answers
SOURCE: HP Laserjet 3100 all in one USB driver / cable
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Also try with another USB cable, If you are using a long cable, just try with a short one.
Posted on Jan 19, 2010
  • 35 Answers
SOURCE: Zebra LP 2844 Printer Error, Cannot Print
Try this
START
SETTINGS
PRINTER/FAXES
in the pop up window go to
FILE/SERVER PROPERTIES
DRIVERS
SELECT THE MFC5440 DRIVER AND REMOVE
SELEST THE LP 2844 DRIVER AND REMOVE
Now go to www.seagullscientific.com and download the Zebra driver pack, once downloaded run it and install the Zebra Lp2844 to with the USb port.
This should solve the problem, if not please come back.
trevor
Posted on Feb 16, 2010
My HPBAAC5000ABK-00 (HP sd500a) USB Hard Drive is not recognized when I connect it to the USB computer. The light comes up and after a few seconds it becomes flashing and the computer was unable to turn...
I see this very often in my shop, 99 times out of 100 it is the actaul HDD inside the unit, seldom is it the actualUSB interface board. Most often the drive itself fails. The ONLY way to "Fix" a faulty HDD, if you want the data back, is to replace the controller board from another HDD, that is from an EXACTLY THE SAME HDD, and use the board from a known good one, and IF that is the ONLY damage, and there is NO internal damage, then one may be able to recover data. Otherwise it isn't DIY practically and one would most likely have to resort to a professional recovery agency.
Sometimes it IS the USB interface, to test this simply use a USB to SATA/IDE converter dongle,(Or if brave hook up directly to a PC's SATA IDE controller?) and see if the drive responds, if it does, then the interface is faulty, and the drive can then be put into another HDD enclosure.
Apr 24, 2011 | HPBAAC5000ABK 500 GB USB 20 Hard Drive
Old computer with windows xp won't boot - how can I get the data off the hard drive by hooking it up to my new computer with windows vista?
You should be able to put the old hard drive in the new computer and connect it as a secondary drive. That all depends on the type of interface the new computer is using. Most new computers use SATA inferface for HDD now. You're old drive might be IDE. in which case you can't add it to new computer unless it also has IDE interface on new MB. If no IDE interface on new MB, you can use USB 2.0 to IDE or Serial ATA Drive Adapter Cable from Cablestogo.com to connect your old drive via USB.
Apr 01, 2011 | Seagate Barracuda 7200.10 ST3250310AS SATA...
Hi i have Toshiba HDD2194, i want to connect it to my PC with USB Cable, please can somebody help me to find which kind of adapter i use ?
OK just go to say, Ebay, or your local PC store, and buy a HDD/DVD, SATA/IDE - USB "Dongle" Pack, they are real inexpensive, simply use the interface that matches your HDD the "Dongle" has BOTH connectors, hook up the Power to the HDD/DVD and hook up to the PC via USB, to the PC, the PC, should "See" the device, and install a "Driver' then it should be available in My Computer, as a normal "Drive".
Example below.
http://cgi.ebay.com/USB-2-0-IDE-SATA-S-ATA-2-5-3-5-HD-HDD-Adapter-Cable-/180550148600?pt=LH_DefaultDomain_0&hash=item2a09a0a1f8
Apr 01, 2011 | Toshiba (HDD2194) (hdd2194-50pk) 60 GB...
HDD Maxtor 80Gb IDE: Harddisk error! At boot it say's Primary harddisk error. Press F1 to continue. *When I press F1 nothing happens. *When I go to the bios at IDE Configuration and hit refresh at Primary...
OK the only shot you got is to geta USB to SATA/IDE converter dongle, connect to another PC's USB port. Hopefully, you will be able to read it. Otherwise still plugged in you may be able to use recovery software and get you DATA back. Recover my files is one,
http://www.recovermyfiles.com/
Other freeware data recovery software GL.
http://www.freebyte.com/filediskutils/
Feb 15, 2010 | Maxtor Hard Drive
I need to attached my hard drive of My toshiba laptop 2455-S305 to an external IDE enclosure so I can download the files from it to another computer. The one I bought, External IDE Enclosure High speed...
OK it seems as though you have an IDE - USB dongle. What you need is a SATA - USB dongle. It appears that the drive you have is SATA, you will know this as there is only a small connector for tha Data and Power Plug. The IDE is a wide multi pinned socket with a large 4 pin Power Connector.
I have included a link to Ebay so you can see what you need. as in the USB to SATA dongle. http://shop.ebay.com/i.html?_nkw=usb+-+sata&_sacat=0&_trksid=p3286.m270.l1313&_dmpt=PCC_Drives_Storage_Internal&_odkw=usb+-+memory+card&_osacat=0
You need to get one such as this to connect to your drive.
Jan 21, 2010 | Toshiba Satellite 2455-S305 Notebook
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
Sir/Madam when i attached my external 30gb hdd via usb ide data cable with my laptop message appear "unrecognized device" how i solve this problem?
You need the driver for the device. If the HDD came with a disk you will need to install that beore hand. =) Hope this works.
Ed
Jan 31, 2009 | Toshiba (HDD2181) (hdd2181-50pk) 30 GB...
No hdd found...
Hi.
Most new hard drives are not partitioned nor formatted and therefore are not ready for use when first bought. They have to be initialized/prepared for whatever device they will be attached to. Formatting may be FAT, FAT32, NTFS and others.
This could be done using a PC where the hard drive (HD) could be initially/temporarily installed as a secondary master/slave and use the Operating System to partition and format making it ready for use. Alternately, an external casing with USB interface may be used.
For your purpose, you need to determine in what format will your digital video player/recorder accept the new HD. This may be found in the manual. Alternately, some digital video player/recorder has this feature/option that will allow you to format newly attached to HDs.
Should the above be not sufficient, please post back with the brand and model of your digital video player/recorder.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Western Digital Caviar WD400JB Special...
Sata hard disk drive on asus p4v8x-x motherboard
i think you should install via raid tool from asus driver cd then check in control panel --> administrative tools--> computer management and you click to disk management
the sata hd will dectected by the computer so you can format it
you must reboot first after via raid tool instalation
i manage this way and succeed on my 500 gb sata drive
try it
Jan 28, 2008 | ASUS P4V8X-X Motherboard
194 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
