Question about Water Sport
Really old blair bali blue paddle boards
How do i tell the value
How do I identify a bad capacitor on a Samsung LN55C610N1F power supply board?
you can tell by the top of them,when there bad they bulge ( as if there going to pop )
Nov 26, 2015 | Samsung Televison & Video
Can I remove my fins on my paddle board?
The fins can be easily removed to transporting the paddle board, however they are used for navigation of the water so you should not try to paddle board without the fins attached.
Jan 17, 2013 | Water Sport
Do I need to wax the top of the paddleboard?
Most paddle boards are made with traction pads attached to the top of the board, these should never be waxed. Boards that do not have the traction pads should be lightly covered with a base wax.
How should I choose the size of my paddle board?
Paddle boards come in three sizes 10ft, 11ft and 12ft, the size is determined by the weight of the person and how many paddles there will be as well as how far the paddler wants to glide between paddles. Normally a person weighing less than 160lbs will choose the 10ft board and someone weighing over 160lbs would take the 11ft. If the paddler is heaver let's say 300lbs or they want to have more than one paddler they would take the 12ft board.
Hi I want to send a fax to Bali Indonesia from Perth Western Australia the fax Number is listed as +62 361 753 523 not sure what codes to use. Would you be able to tell me the exact numbers to use ...
im sure the number you are looking for is for The White Rose Hotel there comntacts are...
+62 (361) 756 515 Fax. 0062361753523 PO. Box 3867 Denpasar Bali 80001 Indonesia. info@whiterosebali.com
Regards
Egroeg
Mar 24, 2011 | Office Equipment & Supplies
Samsung HLP4663w. After replacing the Ballast, Bulb and Color Wheel (color wheel came without the CCA values and the Actuator and Index delay values) we still have the same color and picture problems. Do...
if the picture is blue green there is a jumper to be removed on the dmd board on connector cn810--the index delay should be between 40 and 50 for optimum color --or adjusted for best flesh tone also in the options the cw setting should be set for cw2
Feb 06, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
My image just went blair on my camera, what can I
well either the screen died or more likely there is a setting that will turn the screen off for reduced glare in sunny conditions check owners manual.
Oct 28, 2009 | Sanyo VPC-CG6 Digital Camera
Sony KP-65WV600 Convergence AD Board
It should be a 4.7 OHM if its under the heatsink near the convergence chips.
You can do the repair yourself using the following instructions.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 22, 2009 | Sony KP-65WV600 65" Rear Projection...
Water Sport Logo
582 people viewed this question
Top Water Sport Experts
Tom Chichester
Bill Boyd
Are you a Water Sport Expert? Answer questions, earn points and help others
