Question about AEG 18 in. Favorit 54750Vi Slim-Line Built-in Dishwasher
My AEG 547540VI dishwasher has a problem. It finished a cycle but still had water in the base. I tried to re-start on fresh cycle, but the machine made noises but no water pumped out, and when I opened the door the 65 and 70 degree lights were flashing (I had set it on quick). I tried again, with the same result except that now the machine constantly gave two beeps repeatedly. Any ideas?s
SOURCE: error code 30
i fixed the problem by tipping the machine over slightly, as suggested by other members, about a pint of water came out the bottom and it now seems to work perfectly.
Posted on Mar 28, 2008
  • 1462 Answers
SOURCE: AEG Dishwasher 35080VI inbuilt - door pops open
usual door closure is onto a hook coming out of the top of ther cabinet just under the worktop. this needs adjusting to come out a little
Posted on Sep 02, 2008
SOURCE: AEG DISHWASHER, DOES NOT HEAT WATER.
I had this same problem on our AEG dishwasher. The reason was on the controller board. There is one relay switch which drives the heater element.One of the legs of that relay box was disconnecteds from the circuitboard. Check this out.
Posted on Dec 09, 2008
joe_lishman
  • 192 Answers
SOURCE: Hi, I have an aeg 60870 dishwasher showing error
Sounds like the Anti-Flood system activated (polystireen float at base of machiene coupled to a micro switch) the purpose of this system is to put the drain pump on and stops any other function on the machiene. The anti lood system activates when any amount of water appears on the bottom (caused by leaky pipe / blokked pipes / spills etc.) . Dry the water and rectify the leak. This should solve the problem.
Posted on Jan 19, 2010
joe_lishman
  • 192 Answers
SOURCE: Recurring .30 fault on AEG dishwasher. Have tried
This is caused by the Anti-Flood device at the base of the machiene being activated. This device detects water leaks and is a polystireene float / micro switch that puts the machiene in pump out mode only. You need to determine where the leak comes from (pipe or perforated hose pin hole or pipe clamp etc.) If you tilt the washer and some water comes out from the bottom it is a clear indication that there is a small leak.
AEG 40850 not filling after leak
check pcb board sounds like its blown something
Mar 01, 2014 | AEG Dishwashers
Drain pump running when unit starts but no water to appliance
The machine probably has water in the base (not visibly in the machine, but in the base where the conponents are). Pull the machine out, sit the front on a large towel and holding the back of the d/w pull it towards you. Any water trapped in the base will drain out. It may be a fair amount as the flood safety switch will activate on approx 1.5 ltrs. Once you've cleared the water run a prewash or quickwash to check d/w. Hope this helps.
Jul 05, 2010 | Bosch SHU5315UC Dishwasher
Sep 25, 2008 | AEG 18 in. Favorit F54850 Slim-Line...
Having problems with AEG dishwasher-tablet not dissolving..
open the door when in cycle and check both spray arms are rotating. you will get a bit of water out but not a lot. if arms not rotating, then this is caused usually by rubbish in the spray arm jets so clean them. also check water is being heated
Aug 05, 2008 | AEG 18 in. Favorit 54750Vi Slim-Line...
AEG Washer dryer will not complete cycle
I ended up trying the machine on a few different cycles all of which failed to complete. Finally tried a 'Drying' only cycle and it emptied out quite alot of water which was odd. It now seems fine. guessing it was a blockage and a certain amount of water was backed up in the machine??? any clarity welcome.
Mar 24, 2008 | AEG Washing Machines
AEG 50760 Dishwasher shows Error Code 30
there is water in the base of the macine. lean it over to the side to get all of the water out then try again.
Feb 14, 2008 | Dishwashers
Drain pump
Switch off at the mains. Take a side panel off and tip your dishwater over 45degrees towards th open side. Make sure you put towels down to soak up the water that will come out of the base. This will reset the flood detector. Reassemble. Switch back on and let the dishwasher finish its cycle and away you go. Remember this does not solve the reason for the flooding but it will get your dishwasher going again. Depending on the cause of flooding you may only need to reset like this once a year.
Jan 21, 2008 | AEG 24 in. Favorit 40260i Built-in...
Open Questions:
See all AEG 18 in. Favorit 54750Vi Slim-Line Built-in Questions
AEG 18 in. Favorit 54750Vi Slim-Line Built-in Dishwasher Logo
Top AEG Dishwashers Experts
Mike
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
