Question about Hoover F5807 SteamVac Wet/Dry Vacuum
My vacuum will not extract shampoo from the carpret
I have a Hoover Steam Vac LS 3000 that just stopped pulling the shampoo out of the carpret. I can't find what's wrong. Can you help?
  • Anonymous Dec 21, 2007
    uplostery attachment will not extract water solution
We found that there was a small slit in the hose assy and had to replace it.
Posted on Oct 22, 2007
Hoover max extract V clean water leaking
get a new clean water tank or a seal to put on it from
Mar 16, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Using my hoover steam vac tonight and too much water coming out. once it's turned on, water and shampoo continuously come out underneath until tanks are empty. looks to be leaking from left side bottom as...
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty.
if the problem persists take it to service.
Feb 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
SteamVac Carpet/Upholstery Deep Cleaner Vacuum: how do i add the solution to the steam vac? how mu...
You didn't give a model number so I'll tell you both methods. The F5xxx and F6xxx models have a cap at the top of the clean water tank that doubles as a measuring cup. The cap is about 3 inches in diameter. Fill the cap to the fill line with shampoo and dump it in the tank. Then fill the tank with hot (Not Boiling) water.
The F7xxx series has a 2 section tank. The large section is for hot (Not Boiling) water. The smaller section is for shampoo. Fill the smaller section with shampoo and the Steam Vac will mix the water and shampoo for you in the proper proportion.
May 16, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Need instructions for filling the Hoover Steam Vac Spot with cleaning solutions
Hi There,
Here's a link to the owners manual for your Hoover F5505 Steam Cleaner that will explain step by step how you can add water & cleaning solutions and carpet shampoo. I hope that this was helpful to you. If it did help you, please be so kind and follow the Fixya model and rate the repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair.
Hoover F5505 SteamVac Spot Vacuum Product Manual:
Thank you, this is really appreciated.
Chris J.
Apr 06, 2010 | Hoover F5505 SteamVac Spot Vacuum
Can't get lid off of water and shampoo tank of a hoover steam vac
You can get the tank off the machine correct? Pull down on the black handle.
The lid is the black circular cap on top of the tank. It only moves a bout a quarter of a turn then pulls straight up. If it's still stuck run it under hot water to loosen up any residue buildup.
Aug 20, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Water and shampoo run out with the trigger in the off position
From your description, you have a problem with your one of the solenoids that may be stuck open. this would require a shop repair.
Nov 30, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac LS F5897-900
get a copy of the manual at this site
Aug 07, 2008 | Hoover F6055-900 SteamVac Maxextract LS...
My question seems to be lost in cyberspace. I need instructions for operating my steam/vac L.S edition Model # 5892-900. Is it possible to download this?
Generic problem for all Vacuums
Posted by asavage37 on Jul 02, 2008
My question seems to be lost in cyberspace. I need instructions for operating my steam/vac Hoover L.S Edition Model # 5892-900. Is it possible to download this?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to find out if you can download the operating instructions for your Hoover L.S Edition Model # 5892-900 is to contact the Hoover website link listed below or to call the Hoover Cust Serv @ the factory for further assistance and they can either tell you how to download or they would send out the information by US Mail.
If you have any questions, please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Vacuums
Hoover Steam Vac with Rinse
The bottom tank is for the dirty water, the top tank, it has a small tank attached to it for the shampoo, clear hot water goes in the bigger tank. Then turn it on, squeeze the trigger as you pull it backwards. It will spray and vacuum up at about the same time.
Mar 05, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover F5807 SteamVac Wet/Dry Vacuum Logo
298 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
