Question about RCA Lawton 841.662 Turntable
How do I remove the turntable?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • RCA Master
  • 924 Answers
I don't see allot of information on that turntable. Please let me know how old is it and take a picture of the platter. Once you have that, please visit my website at audioserviceclinic,com. Thank you.
Posted on Dec 07, 2013
Does old Zenith Allegro Console Stereo - 8 track/AM/FM/turntable, have a belt drive phono? I can see metal gears to drive the stuck turntable .
The manufacturers of such items would usually buy in such hardware as record turntables from fairly standard catalogues.
One popular brand of turntable was the BSR but the design of other brands were similar. The metal gears aren't for driving the turntable but to drive the multichange mechanism so when one record has finished playing another will drop from the stack loaded onto the extended centre spindle.
This type of turntable is driven by a synchronous motor with a multidiameter spindle via a moveable idler wheel equipped with a soft rubber tyre. Lack of maintenance causes many problems and as the rubber tyre ages it tends to harden and lose traction on the inside of the steel turntable so when the record reaches the end and the metal gears engage there is insufficient torque and everything stops.
It is for that reason many older examples have had the multichange removed or disabled.
Removing the turntable centre motif should reveal a circlip which when removed will allow the turntable to be removed for maintenance.
Jun 07, 2017 | Zenith Televison & Video
How do you remove the turntable?
It depends on the turntable you have. For example Dual turntables with idler wheel drive have a spring round the platter's axle which has to be remove. Some Dual belt drive turntables have a bajonett lock, other a lever to be moved and some have only weight fixed platters. Most platters of direct drive turntalbles are just fixed by their weight and are removed with a strong pull. Greetings from northern gemany
Nov 08, 2015 | Audio Players & Recorders
Thomas Pacconi TPC-MSE 800
could you include a picture of the under side of the turn table where the belt is fitted?
May 21, 2014 | Seth Thomas Pacconi Turntable
How to remove the turntable plate
At the base of the spindle of the turntable is a c-clip. Use a table knife or flat screwdriver and needle-nosed pliers to carefully remove it. The turntable can be lifted off. Take care to not damage the belt underneath, if a belt-drive turntable.
If luck is with you, all it needs is a thorough cleaning.
Jan 17, 2013 | Microwave Ovens
Phillips whirlpool microwave turntable not turning
HELLO.
The turntable is the unit in the center of a microwave that you set your food on. It rotates during the microwave cycle, making sure all parts of a dish are properly heated. These are typically made of either hard glass or microwave-safe plastic.
Your microwave turntable may not turn due to any of these problems explained below.
(a)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properly on the turning mechanism.
(b)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
Most microwaves have different settings that the user can select with the press of a button, like a "Defrost" setting or a "Popcorn" setting. Certain microwaves may stop the turntable from turning during certain pre-programmed selection modes. Stop your microwave and don't use a pre-programmed mode. Instead, just specify the time using the number pads and start your microwave to see if your turntable begins to rotate again.
(c)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
follow these steps below to replace the faulty motor.
1. Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 .Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3. Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4. Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5. Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6. Reinstall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Thanks.
Oct 01, 2011 | Microwave Ovens
My sony pslx250h turnable belt was ordered and i can't find the repair book to repair it.
Pretty simple fix. Remove the mat, remove the turntable, install new belt on bottom of turntable hub. Place turntable back onto spindle. rotate turntable so you can see motor pulley. Stretch the belt from turntable hub over motor pulley, replace mat, enjoy.
Nov 08, 2010 | Sony PS-LX250H Turntable
Microwave quit
Well first of all you can try to clean the turntable- Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable. With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing. If further you have the same problem then this could be a failing turntable motor...... Please post comments for further help or information.......
Good Luck!!
Thanks
Jun 25, 2010 | Sharp R-1610 Microwave Oven
REPLACING TURNTABLE BELT
as the belt sliped from the turntable you must replace it with new one.if upside down turntable you can see marking of belt on it.just put a new belt on turntable keep it on center.remove top rubber pad you will see three or one big hole on turntable from where you can see the belt turn that hole so you can see motor pully just hold belt by a screwdriver and pull it on motor pully.
Jun 21, 2010 | Audio Players & Recorders
How do I remove the spindle to get at the drive
this video answers that question for most turntables.
Apr 05, 2010 | Crosley CR248 Turntable
Turntable will not turn. the motor is not
After removing the rubber mat, you should see a clip on the spindle that keeps the turntable on. But you will still not be able to remove the platter until you remove the unit from the cabinet. Remove the bottom cover and flip the two clips and the turntable assembly can be removed.
Nov 21, 2009 | Emerson NR303TT CD Shelf System
RCA Lawton 841.662 Turntable Logo
65 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
