Question about Jacques Lemans Watches
JL 1-1715 - the date arm is not functioning
Just started the watch after purchasing, but could not set the date arm, its fixed at the reset position, not functioing; any suggestions; also suggest any service centers in banagalore for Jacques Lemans
escapement
  • 2334 Answers
SOURCE: Bucherer Day/Date Setting Problem
You have to change day by the means of moving hands clockwise. Move as long as the desired day appears in window, then adjust the date and set time. Rate me, plz.
Posted on Mar 31, 2010
Testimonial: "Thanks so much. I thought I had tried what you suggested already, but apparently I hadn't. The watch is now set correctly. Thanks again!"
  • 15 Answers
SOURCE: jacques lemans 1215
I think this should work for you...
Jacques Lemans has some instructions posted here:
http://www.jacqueslemans.com/JLinstructions.html
Posted on Dec 21, 2007
VOTIT
  • 2071 Answers
SOURCE: I have a Jacques Lemans
Hi Rege I only can help you is to give you a site, where you can order . ...www.professionalwatches.com/jacques_lemans
Posted on Jun 19, 2008
mcdevito75
  • 1970 Answers
SOURCE: LOST INSTRUCTION MANUAL FOR JACQUES -LEMANS MODEL
mcdevito75 here, From your home page, type into search the name of your watch plus.com this should bring you to their website.
Posted on Oct 26, 2010
escapement
  • 2334 Answers
SOURCE: My Jacques Lemans G-190E's second
No worries - just replace the battery. As the battery was fitted at the time of watch assembly, it is actually already old. The seconds hand movement by 5sec increments indicates low battery power, so, next time you see that - you will know what to do.
Posted on Feb 25, 2011
Hello. I have purchased a seiko premier perpetual snp025 watch. From the moment I opened the box the 2nd hand is moving consistently at 2sec intervals and it does not move normally every 1sec. Also the...
Two sec jumps is low power in the elec store,,, winds with movement back and forth as your arm would swing. Sometime the day date function is changed by pressing the small button type crown in slightly with your finger nail.it may have on or two detents if so it adjusts both functions. if not the stemcrown needs to be used to set day and button to set date.
May 09, 2017 | Seiko Premier KineticĀ® Perpetual Watch for...
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
  • THE CROWN
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
  • 12 O'CLOCK POSITION
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
  • FINISH
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
Dec 18, 2010 | Seiko SNA304 Wrist Watch
Pulled out the stop watch button on my daytona before it was prewound and the whole watch has ceased HELP
The stop watch buttons don't pull out. There are 2 pushbuttons. The upper one starts and stops the timing function and the lower button resets the timing function. The crown has three positions: 1st position is for winding, 2nd for date setting and 3d for time setting. Once things are set wind the watch in position one and it should run. If it does not take it to a watchmaker. You don't want to fool around with such a valuable watch.
Apr 22, 2010 | Rolex Daytona 116520 Wrist Watch
Hi there i have bought a second hand tag heuer carrera tachymeter,i dont have a user manual,but cant seem to get the chronograph functions to work ?
Great watch! Operation should be pretty straight forward. The top button starts the chrono and stops it. The bottom button resets it. To calibrate the sweep arm into the right position pull the crown out to the first or second set position and press the start button until the sweep arm is in the start position you desire. This is typically 12:00 or 0.
If your chrono is not working then have the battery checked. If the battery has been recently replaced then make sure the watch doesn't need to be cleared.
I recommend you take this to a watch maker/technician who will be familiar with the service requirements of this model including resealing and pressure testing the watch to be sure it is sealed to its marked water resistance specifications.
Thanks!
Sep 20, 2009 | Tag Heuer Carrera Series Chronograph Watch
Emporio Armani AR0534, How do you reset the Chronograph function of this watch?
If it is not working you may need to "AC" the watch. This generally needs to be done when the battery is replaced. This will reset the circuit board and allow the watch to work correctly. There maybe instructions on the inside of the back lid to do this but i always recommend having a watch maker/technician doing it because of the delicate nature of the circuit board.
If the sweep arm is not resetting to the 0 position then you can set by....
pull the crown out to the first or second set position then press and hold down the start button until the sweep arm is in the position you want.
Sep 11, 2009 | Giorgio Armani Emporio Armani Classic...
How do i set the time on an Invicta Lupah mens watch with three subdials
The Lupah has a chronograph so dont worry about the sub dials while your setting the time. Pull the crown out to the first position and set the time. For the date pull out to the second position and set the date.
To set the chronograph sweep arm pull the crown out and press and hold down the start button. The sweep arm will move into position. Stop it on the 12:00 or 0 position.
Jun 09, 2009 | Invicta Dragon Lupah 2093 Wrist Watch
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Jan 05, 2009 | Bulova Watch
Rolex watch yacht master set time
Let me start by saying that I own this watch and LOVE it!
To set the time you need to pull the crown all the way out to the furthest position.
To set the date you need to have the crown in the position in between the "winding" position and the "time set" position. Basically, pull the crown out till you hear/feel 1 click to wind, 2 clicks (total) to set the date, and 3 (total) clicks to set the time. I always set the date first to 1 day behind the current date. I then move the crown out to set the time so that I can set the watch to either AM/PM depending on the actual time. For example, I set my Rolex today (the 5th of January at 3pm - just an example). I would first move the crown to the date setting function and move it to January 4. I would then move it out one more position to set the time. I would go around the watch until the date changed to the 5th and then go around from 12 to 12 to change from AM to PM. I would then move it to the 3 and then I'm all set. This is helpful because it will ensure that your date will correctly change when the day changes and not be 12 hours behind.
Jan 03, 2009 | Watches
Pulsar (Seiko) Watch Changes Date at different time.
mcdevito75 here, The manufacturer recommends you don"t try to change the date between certain hours as this could hurt the date changeing mechanism inside the watch, I don"t think you did any harm (LUCKY) and the date changeing 45 minutes before mid nite is just about right. BUT! if the date change was aliitle closer to mid nite at 1 time you can try to reset the date, here"s how, your stem should have 2 positions to change the date without haveing to cycle the watch the 24 hours 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it:s first position, it may take a little practise but you"ll get it, once you do, trun the crown and you should see the DATE change, if so set the DATE to 1 DATE before the DATE you want, now pull the stem out and set the correct gate and time of day. Your watch is now reset and date will change on time, around nid nite.
Jun 10, 2008 | Pulsar Bracelet PXQ502 Wrist Watch
Watches Logo
123 people viewed this question
Top Jacques Lemans Watches Experts
Ansel Alberto
Ansel Alberto
Tom Chichester
Are you a Jacques Lemans Watch Expert? Answer questions, earn points and help others
