Question about Refrigerators
Ge flashing 88 and 8A on front panel for a Ge Profile PFss6Pkxass
  • 74 Answers
SOURCE: GE Icemaker PFSS6PKXASS
To reset the filter light you need to hold the button in for 3-5 seconds , the light will usually flash while you hold the button down then it will go solid and then go out once you release the button. The ice maker will only make ice when the freezer is cold enough approx -14c . Did it make ice ok before ? There is the possibility that when changing the water filter air got into the system and has not bleed out of the ice maker feed tube yet.
The Ice maker can usually be put into a test mode by turning it off , wait 30 secs then turn it back on and press the ice level sensing paddle back three times within 15 secs of switching the ice maker back on . The ice maker should then go through a forced harvest cycle and ask for water at the end of it.
Hope this helps
Posted on Sep 02, 2008
jumptrout51
  • 3361 Answers
SOURCE: blocked defroster drain GE profile tfx25pr, tft25pr
Remove the freezer bins and shelves.
Remove the rear freezer panel.
The drain is on the bottom center of the freezer after the rear panel is removed.
Posted on May 25, 2009
erpaalai
  • 999 Answers
SOURCE: Ge Profile Stainless Steel Refrigerator panel replacement
You can replace the doors but you will think you bought a new frig when you see what they cost. Most come as an assembly and are very expensive.
Eric
Posted on Jun 29, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE profile TFX27PFSM diagnostic is flashing de
DE means something is wrong with defrost system. Here is your user manual=> TFX27PFSMWW the notes are on page 8. If you need assistance please contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Posted on Jan 19, 2010
Testimonial: "Now that's a response! If the monitor lite starts flashing again, I will take ur advice. It's enclsd in a wall so it just might need air circulation"
SOURCE: How to remove front panel from ge ice maker model PSS26SGPASS
If you are talking about the ice/water dispenser palnel, on my PSF26NGPABB Arctica it just pulled off. there is double sided tape all the way around it and I used a thin, sharp knife to cut it as I pulled the panel off.
Posted on Dec 28, 2010
Correct ohm value on a water tank heater coil part # wr13x10500
First neither the model number or the supposed part number are correct. Second is this the top or mid-line heater loop?
Usually it's not the coil that fails but the thermostat.
Jun 12, 2014 | General Electric WR13X10500 - WATER TANK...
Ge model pfss6pkxass integrated ice maker not making enough ice
it could be to much force maybe back off the supply tap to the water side of it and see how it goes
Apr 08, 2014 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Ge profile front-load washer not draining
Firstly took the bottom front panel off and removed the drain plug/trap. Then the problem should be solved easily. For More information please visit Clothes Dryer Element .
Sep 22, 2012 | GE White Profile Series 15 Frontload...
How do you take the front panel off of a GE Profile Prodigy Dryer DPSR483 GAWW? There is a squeeking noise inside.
Best off to call a reliable service company such as Sears. You have to remove the top and take 2 screws off that hold the front panel on but this is a gas appliance which requires a gas technician to legally work on it.
Feb 01, 2010 | GE Profile Prodigy DPSR513GA Dryer
Our GE Profile started beeping and flashing f 3. None of the buttons will work now.
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad). Once the key panel is replaced, the issue will be solved.
Nov 25, 2009 | GE Profile Spacemaker Over-the-Range...
GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
Aug 07, 2009 | GE PDS22LBN Bottom Freezer French Door...
Cracked fronts of drawers GE profile PSS26LSRCSS
Try the GE website or these:
  1. GE Fridge Parts Onlinewww.AppliancePartsPros.com/Parts      Good prices on GE fridge parts. Same day shipping. Order now!
  2. Ge Profile Refrigerator Partswww.RepairClinic.com      850,000 parts, 93,000 photos. Call center, same day shipping
  3. GE Refrigerator Partswww.pcappliancerepair.com      OEM source of GE refrigerator parts Online or toll free 1-877-922-2880
May 29, 2009 | Refrigerators
Spin Basket Spins Along with Agitatdor in GE Profile Washing Mach
if washer is newer version remove front panel and ck if has a gearcase it's probably bad if it has what ge calls a mode shifter it's probably bad it has a coil with connection to motor bd..look on bd for flashing green 4 flashes means open mode shifter coil
Dec 17, 2008 | Kenmore 24032\24036 Top Load Washer
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
