Brake lever almost touches the grip before brakes are stopping. I have bled the lines several times , little or no air bubbles come out. the pads look to have at least 1/4 `` I bought the bike with 12,000 miles on it , I am not sure if the front pads have been changed. Any suggestions ?
Its not your pads min thickness is 0.04..you have air in the lines or a loose fitting. You really need a vacmum suction device to bleed harley brakes not the old auto turn the nut pump the valve routine. Take it to a shop and have it done will only take about 15 min. Maybe someone prior to you mixed dot 4 and dot 5 maybe it fluid just needs to be replaced. but its not your pads the brake fluid makes up for the pad thickness.
Remove brake pads and inspect them.see that they are wering flat and not angled. replace brake pads.
Thanx,, I checked with my mechanic and he said he`s noticed problems with the calipers leaking air on models 01 thru 06,, another harley defect!
