Question about Rowenta Effective DX1900 Iron with Auto Shut-off
Iron calc problem - Rowenta Effective DX1900 Iron with Auto Shut-off
The iron leaks water when sitting upright and in ust.
Time to buy a new iron. It just is not worth the time or money to repair it.
Aug 03, 2015 | Rowenta DW9055 1600W Anit Calc Stainless...
My Tefal pro iron sometimes makes noise and dont steam any more?
get rid of the calcium,and use distilled water for steam,not tap water
Jun 20, 2015 | Tefal Pro Express GV 8120 Iron
Calc-clean function light keeps flashing
Press the reset button
Nov 12, 2013 | Irons
Anti/calc iron water pours out from evry where
see this steps and fix it. God bless you
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Oct 15, 2012 | Frigidaire Fcl222/H 2200W Steam Spray Iron...
I have an bosch sensixx b5 iron and the calc clean sign keeps flashing what can i do .i have lost theinstuctions
Here you have how to solve this issue. It has been obtained from the device's manual.
2. calc'n clean The "calc'n clean" function helps to remove scale particles from the steam dispenser. The iron includes a system to warn when the dispenser needs periodically cleaning. When the "calc 'n clean" symbol lights up on the navigation display the dispenser needs cleaning. Fill the water tank. Plug in the iron and select the temperature setting . After the necessary warm-up period, unplug the iron and hold it over a sink. Position the steam regulator to the "calc'n clean" position and keep it in this position. Gently shake the iron. Boiling water and steam will come out, removing any scale or deposits that might be there. When the iron stops dripping, position the regulator to the position. For improved descaling, heat up the iron again fully and press the steam button several times in quick succession. Then wait until the remaining water has evaporated from the soleplate of the iron. Once it has been cleaned, the cleaning warning must be cancelled on the navigation display. To do this, simply press and hold the on/set navigation key for more than 5 seconds, with the iron plugged in. If you do not do this, the cleaning icon will remain lit. 3. anti-calc The "anti-calc" cartridge has been designed to reduce the build-up of scale produced during steam ironing, helping to extend the useful life of your iron. Nevertheless the "anti-calc" cartridge cannot remove all of the scale that is produced naturally over time.
Jan 25, 2011 | Bosch Irons
Instructions for calc n clean HAVE TODAY
Hi
I too had the same problem. I emailed Bosch (via their website and gave them the model number and they have emailed the instructions.
This should have been with the iron in the first place!
Aug 09, 2010 | Bosch Irons
How to use the calc-clean button
Calc-Clean function
The Calc-Clean function removes scale and impurities.
To do so, set the steam control to position '0', set the temperature dial to 'MAX', and fill water tank up to the 'MAX' level. Then heat up the iron until the pilot light on the handgrip goes out.
Remove the mains plug from the wall socket and hold the iron horizontally over the sink. Then press and hold down the 'CALC CLEAN' button.
Move the iron forwards and backwards while boiling water/steam squirt from the holes in the soleplate to wash away impurities/scales.
When the water tank is empty, heat up the iron to dry it.
Finally move the iron to and fro on a piece of cloth to dry the soleplate. Repeat the process if necessary
May 05, 2009 | Philips HI-296 Iron
I have a bosch iron and it needs to be calc cleaned how do i do it?
hello my name is gilles to clean your iron get yourself a bottle of clr it is a mild acid pour a litte in with water let you iron sit for 1/2hour or so then drain your iron out by turning it upside down then you should be ok thanks from gilles
Mar 15, 2009 | Bosch Irons
Rowenta Effective DX1900 Iron with Auto Shut-off Logo
Top Rowenta Irons Experts
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
