Question about Razer Tiamat 2.2 Expert Stereo Analog Gaming Headset
Razer tiamat left side not working
All of a sudden the left speakers and the mic (mounted on the left) are not working. However what's strange is the cord comes in at the left.
Hi, I have a Razer Tarantula keyboard i have had it in a year now and never had this problem but now the mic input does not work any more. Well my program shows the mic is in but no other programs/games...
Some programs like Skype set up their own profile in the audio hardware side of the operating system. Check the audio properties and see if two or more are listed and change to the other one and check the operation.
Nov 26, 2017 | Razer Tarantula RZ03-00070100-R2U1
My head set just stopped working no sound, mic dosent work or anything, plugged in a second headset to make sure it wasnt the jack, definately something wrong with the razer. any suggestions? where do i...
Possible that the wires would have wriggled off from the jack side due to some ****. to confirm you will need to check one by one afteropening the sides,the continutiy of the wires to the jack and to the mic.
if ther is no continutiy replace the wires and jack. You can also dissect the jack to get to the problem and patch this up after finding the open wire. Ok
Jul 01, 2010 | Razer Carcharias Gaming Headset
My webcam was working with my desktop for over 6 months. then suddenly, my microphone stopped working.....i could not be heard. i tried the webcam on my laptop and it all works fine.
Check your audio set-up
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO CHAT PROGRAM
Jan 10, 2010 | Microsoft LifeCam VX-3000 Web Camera
Speakers feedback through my Barracuda Mic
if have a camera already connect on your pc try to unplug the mike of your camera or go to the audio device manager and change the settings.
Jul 06, 2009 | Razer Barracuda Gaming Headset
Motorola v3i mic not work
better to replace ur mic in your v3i if its not working.....put mic from another v3i...
Feb 05, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Roland MV 8800 No inputs, phono
Hi, post on mvnation.com, they will be able to help.
Jan 26, 2009 | Roland Mv8800 Production Studio
Tascam Us-144 Only plays back in left speaker
If you have a condenser mic you need an adapter that you plug both into the right and left...
Jan 18, 2009 | Tascam US-144 Sound Card
No sound in rear speakers
I figured this one out, although I might still send it back for an exchange. It turned out that the right rear speaker works just fine, however the jack seems to be flawed. When fully plugged in, the rear speaker input only picks up the left channel. If you pull it out just a little, say 1/8-1/4 the way out it will pick up both channels. Not a good solution but it works for the time being.
Jun 03, 2008 | Razer Barracuda HP-1 Consumer Headphones
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Open Questions:
Razer Tiamat 2.2 Expert Stereo Analog Gaming Headset Logo
168 people viewed this question
Top Razer Radio Communications Experts
 Grubhead
Grubhead
Clive
Clive
Are you a Razer Radio Communication Expert? Answer questions, earn points and help others
