Question about Hammering
Serpentine belt diagrams for a 2002 ford focus 2.0ltr sohc w/ac
  • 13 Answers
SOURCE: serpentine belt diagram:
if yours has the 3.8L then here is the diagram. Hope this helps
~ Zach
Posted on Jun 16, 2008
Molson02536
  • 3854 Answers
SOURCE: need a serpentine belt diagram for 2005 ford focus
You should have that diagram on the inside of your hood or on the fan shroud. Good luck
Posted on Apr 08, 2009
michigan man
  • 3533 Answers
SOURCE: belt diagram
for the most part there is a diagram under the hood showing you how the belt goes back on you can try www.autozone.com to see if they have your car listed but this is what i do i draw a diagram of the old belt before i take it off and that way i know how the new one goes on.
Posted on Apr 20, 2009
SOURCE: diagram serpentine belt for a ford f-250 7.3l diesel
I had this same thing happen to me. i spent some time trying to find a image of this so i could replace my belt. ford dealers will help. but for me this was not a option. so i searched the net. here is a image that may help.
Posted on Jun 26, 2009
rylee_smith
  • 8619 Answers
SOURCE: i need a diagram of the serpentine for a ford
Hi
Thanks for using FixYa. You can look at this picture for serpentine belt for your 2002 Ford Focus Z3--
Ford Focus Z3 Serpentine belt Removal--
· Jack up the front of the vehicle and support it on jack stands. Use a wrench to remove two bolts and take off the drive belt lower cover.
· Note belt routing and make a sketch for your reference if you don't have a belt routing diagram from the manufacturer.
· Find the belt tensioner pulley. Use your wrench to rotate the tensioner pulley by pulling clockwise on a bolt in the center of the pulley. Slip the old belt off of the tensioner pulley.
· Release the belt tensioner. Slip the belt off of the pulleys and install the new belt according to your routing diagram.
· Rotate the tensioner again to allow the new belt to slip over the tensioner pulley. Release the tensioner again. Replace the drive belt lower cover and lower the vehicle.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Sep 06, 2009
Need to find diagram for 2002 ford focus serpentine belt tensioner
Assuming the car is equipped with AC, your diagram is 1 of these.
2002 Focus Serpentine #1
2002 Focus Serpentine #2
Jul 30, 2011 | Ford Focus Cars & Trucks
Need routing diagram for ford Focus ZX1 with AC 2001, serpentine belt
I used the information you had in your question, and it looks like there's just one belt option/engine for a 2001 Focus with AC, but just in case, you can look it up on www gates.com
http://www.gates.com/common/part_locator/diagrams/S7002.jpg
Best wishes, and thanks for using Fixya.
Feb 06, 2011 | 2001 Ford Focus
I need a diagram for a 2004 ford focus 2000cc zetec serpentine belt
Click on the following direct Free Link. It has the Serpentine Belt Diagrams, including for your 2004 Ford Focus 2.0L with the unspecified Engine Options (AC/No AC, etc.).
http://www.2carpros.com/car_repair_information/year/2004/make/ford/model/focus/2004_ford_focus_drive_belt_routing_diagram.htm
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
Apr 19, 2010 | 2004 Ford Focus
Diagram for 92 acclaim serpentine belt
For the 1992 Plymouth Acclaim:
Click on the following free, direct Link. It has several Seprentine Belt Diagrams, including one to match your specific 1992 Plymouth Acclaim with the unspecified Engine: 2.5L SOHC In-Line 4-Cylinder or 3.0L SOHC V6; and the unspecified Engine Options (AC/No AC ect.)
http://www.2carpros.com/car_repair_information/year/1992/make/plymouth/model/acclaim/1992_plymouth_acclaim_drive_belt_routing_diagram.htm
Apr 17, 2010 | 1992 Plymouth Acclaim
I need a diagram for the routing of the belts on
For the 1998 Ford Escort 2.0L SOHC In-Line 4-Cylinders:
Click on the following free direct Link. It has several Serpentine Belt Diagrams for the 1998 Ford Escort depending on your engine options (AC/No AC etc.). It also has several other Instructional and Directional Diagrams that will help you.
http://www.2carpros.com/car_repair_information/year/1998/make/ford/model/escort/1998_ford_escort_drive_belt_routing_diagram.htm
Apr 08, 2010 | 1998 Ford Escort
Diagram 2001 Focus timing belt installation
2001 Ford Focus 4-Cyl. 2.0 L
Serpentine; W/DOHC Eng.; W/A.C.
Serpentine; W/DOHC Eng.; W/O A.C.
Serpentine; W/SOHC Eng.; W/A.C.
Serpentine; W/SOHC Eng.; W/O A.C.
For more details about the
Timing Belts & Components, visit HERE.
Good luck (remember rated this help).
Sep 14, 2009 | Ford Focus Cars & Trucks
I need a diagram of the serpentine for a ford focus 2002 z3
Hi
Thanks
Rylee
Sep 06, 2009 | 2000 Ford Focus
Serpentine belt replacement
2.0L Engines
See Figures 11, 12 and 13
The accessory drive belt for 2.0L engines has no provision for manual belt adjustment, since these engines use an automatic belt tensioner. Drive belt slack is taken up by the automatic tensioner.
Movement of the automatic tensioner assembly during engine operation is not a sign of a malfunctioning tensioner. This movement is the tensioner self-adjusting and is required to maintain constant belt tension.
The belt tensioner has a belt length indicator. If the indicator marks are not between the MIN and MAX marks, the belt must be replaced.
0900c1528008d836.jpgFig. 11: Drive belt routing-2.0L SOHC engine with A/C 0900c1528008d837.jpgFig. 12: Drive belt routing-2.0L SOHC engine without A/C 0900c1528008d838.jpgFig. 13: Drive belt routing-2.0L DOHC engine
Jul 24, 2008 | 1999 Ford Escort
Hammering Logo
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
