Question about Saeco Magic De Luxe Espresso Machine
Trouble Lights Stay On
I have had my machine for a couple of years trouble free and I love it! This is just a minor annoyance, but the "bean hopper empty" red warning light has been on constantly ever since the unit arrived. Recently, also, I decided to descale and clean the machine even thought descale warning light was not on and as soon as I was done it came on and will not go off. I used descaling solution and followed the instructions in the manual. Otherwise the machine works beautifully, 2 double capuccinos every morning of the week. Thanks for any help you can offer.
  • gallaman Oct 12, 2007
    Thanks! I'll try the steam button thing. If it works it's an 'undocumented feature' - I think. I never saw it in the manual.
    Grinder settings are the factory default. It takes only 2-4 seconds to grind a cup. I did call the place I bought this unit from about the bean hopper light problem early on, a couple of years ago, and they said something about the beans being too "wet" or greasy, which Starbucks beans are. I just switched to some dryer beans and noticed this morning that the light had gone off, but it's gone off before and then come back on.
    G
    Sergeant:
  • Saeco Expert
  • 223 Answers
How long does it take for your machine to grind for 1 cup? Longer then 10 seconds? Grinder setting?
Descaling should be done every 2-3 regardless if the light comes on or not. To reset the light hold the steam button until the light goes off.
Descaling information can be found at http://www.cerinicoffee.com/clean_descale_coffee_equipment_instructions.asp
Hope this helps!
Posted on Oct 12, 2007
  • Cerini Coffee
    Cerini Coffee Oct 12, 2007
    If the grinder is grinding that quickly there is no reason for the light to come on. It was probably a CPU issue from the beginning.
Bean hopper is full, machine starts to grind the coffee but right before it starts to pull the shot, it stops & says "add beans to hopper".
the add beans to hopper signal most likely is triggered by the machine not sensing enough load put on the grinder (hence it thinks its out of beans) , this most likely is set by the grind (fine/course ) id say the grind is set to an improper size and the automatic sensor is picking up on that
another thing is the coffee / if its way too moist and not dry enough then its also going to trip the sensor as well
Feb 26, 2016 | Coffee Makers & Espresso Machines
Hi my breville barista express does not grind the beans, and the "single/double" light is blinking, what is the problem?
My wife tried to make my coffee and long story short, she removed the lid to "move the beans around"..The grinder stopped working and the filter size lights began flashing intermittently. After taking the whole thing apart, the only REAL problem is that the lock mechanism inside the hopper came unlocked. So put your machine back together and "lock" the hopper. The lights will stop flashing...lets hope
Sep 26, 2013 | Breville Die Cast 800ESXL Espresso Machine
I have a Jura Impressa E85 purchased in 2006. The coffee beans are not feeding to the grinder. The display reads 'fill beans'. This ocurred after a normal cleaning operation.
This sometimes happens when after cleaning the machine. I will explain: The beans have a natural oil on them as you know, that also helps coat the hopper for beans to fall. Sometimes when cleaning the machine, the natural oil that is built up around the hopper is not there. Once you brew a cup sometimes the light will go off on its on. If the beans by shaking the machine will not drop down, try using a wooden spoon and help get them going. Other way, is cleaning out the beans completely and then spaying some PAM (used for cooking). What I also did was locate the complete manual for you to download and read page 21 in the trouble shooting area. Here is the link you can copy and paste and put in your browser.
http://www.uk.jura.com/home_uk_x/service_support/download_manual_jura_impressa_e80_e85_english.pdf
I hope this helps you, and please rate my free advice accordingly , thanks Mike
Oct 14, 2011 | Coffee Makers & Espresso Machines
The coffee is filled and yet when it begins to grin the beans it stops and tells me to add coffee. So I giggle around the coffee dispenser and sometimes it works, but the problem is getting worse. Seems...
Are the beans very oily? Oily beans can sometimes cause things like this. My suggestion is you take out the bean hopper and clean the beans under that because on my Miele CVA4066 there are usually more than a few beans and chipped off pieces of beans under the hopper which cause some trouble.
Jun 29, 2011 | Miele Coffee System
Grinder does not stop
I need more information to solve this.
If you mean the grinder just spins but doesn't seem to be grinding anything - and then after 30 seconds or so it tells you the bean hopper is empty - then the problem is sticky, oily beans that aren't sliding down into the grinder.
You want to buy freshly roasted (roasted less than a week ago) beans. Coffee beans from the supermarket are old, stale and sticky with rancid oil. Even Starbucks and Peets - although the sign says "roasted daily" if you read the fine print, the beans in the store are rotated out 90 days after roasting. The oils turn rancid and get sticky after a couple of weeks so you really need to get beans from a local roaster or order them from a roaster who ships them fresh.
I have been using RedBird espresso blend and these beans work perfectly with this machine. They also are the best tasting of any espresso blend I've ever tried. The price is reasonable (cheap even) and the roast date is written on the bag. I get my beans 2 days after they were roasted.
http://redbirdcoffee.com/redbirdespresso.html
In the meantime, until you get some coffee beans that are not oily, you can stir the beans in the hopper. Use a wooden coffee stirring stick or a chopstick and just lift the hopper lid and stir the beans so they slide down into the grinder. You will probably have to do this before each coffee and maybe even 2-3 times just to get one coffee.
Once you get some fresh roasted beans that don't have that oily shine to them you will be grinding without any problems.
Oct 22, 2010 | Gaggia Titanium Espresso Machine
The ground coffee is not passing down to the brew unit. It is grinding the beans but going no further thereby back filling the powder filler
The usual problem is the grind is too fine. Try turning the large knob in the bean hopper to the max 16 and turning the small knob to the minus (-). If it works turn the large knob down (only when it is grinding can you turn to a smaller #) but higher than you had before the trouble.
Sep 23, 2010 | Saeco Incanto Classic Espresso Machine
My Saeco won't grind the beans
There's moisture in the grinder & it's clogged - just dismantle the grinder & clean it, then ensure you don't splash water into the bean hopper when you fill the water tank.
Mar 29, 2008 | Saeco Magic De Luxe Espresso Machine
Beans stick in hopper
Bob,
Thanks for the help but I was well past that stage. After cleaning half a dozen times, changing beans three or four times, soldering the contacts on the switch, changing it, replacing the whole doser flap sled and anything else I could think to do I finally fixed it. It took me months but in the end it was the doser trap door not allowing the dozer flap to move back and hit the switch when the grounds came down. A simple light bending out fixed it. So...we had a rare mechanical issue. The machine does have a design flaw in that it has a long three inch shoot for the grounds which makes it susceptible to clogs. Do not use oily beans!
Feb 20, 2008 | Gaggia Titanium Espresso Machine
Limited coffee output
sounds like normal wear and tear, but i do suggest a advanced cleaning of your coffee maker.clean your bean hopper out and sanitize it good, check your owners manaul for tips and tricks on getting the most from your model!
Dec 11, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Magic De Luxe Espresso Machine Logo
455 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
