Question about Kenmore 4.3 cu. ft. High-Efficiency Top-Load Washer
Washer fills and stops
Initial ld error, checked all hoses no clog, now just fills and stops
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
It sounds like you need to check your lid switch not closing contacts or loose connection
Posted on Nov 22, 2013
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
LD-2040WH
The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 27, 2014 | LG Dishwashers
When running wash cycle, the washer stops during initial cycle when water is going into tub. The "Ld" error code comes up on the panel and sometimes it is accompanied by a humming sound. Can not start...
LD is long Drain.
You'll need to crawl underneath and disconnect the hoses to check the traps for obstructions.
Have a pan handy to catch the water.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 10, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My washer is indicating a "ld" problem. I have readjusted the load and restarted the machine but it continues to stop and the "ld" code keeps coming on. I have a very small load in the machine so I know...
Hello, the "Ld" error code indicates a long drain. It is displayed when water level does not change while the drain pump is running. You can check for the following problems:
  • Is the drain hose kinked or clogged?
  • Check the drain pump for clogs. Is it running?
  • Is the drain hose height greater than 96 inches?
  • Is the pressure switch hose connection from the tub to the machine control board pinched or plugged?
  • Do you see excessive suds in the basket? Are you using high efficiency (HE) detergent?
  • Thanks
Jun 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My kenmore elite calypso has a code of ld
Well error Ld means - Long drain - The Ld error code indicates a long drain. It is displayed when water level does not change while the drain pump is running. Anyway you can please check out the following steps -
Is the drain hose height greater than 95 inches?
You can try to reset your washer by Pressing STOP/CANCEL. Please check out all the above steps, post comments if further you have the same problem.......
Good Luck!!
Thanks
May 12, 2010 | Washing Machines
Won't fillCalypso whirlpool washer model#GVW9959KQ1 LD on display
LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
Parts and diagrams available here.
Oct 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My washer stops at the spin cycle. The LD code
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jul 16, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Ld error code won`t drain.or do anything starts for 10 sec and stops
Owner manual - Code Ld -says the drain hose is kinked or clogged.
Check that the hose didn't get kinked when pushed back to the wall. It's a common problem. The problem is NOT the wall drain as water would be coming out onto the floor if that was the issue.
Jan 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer fills with water and stops
Hello, LD stands for long drain.
If all the water isn't out of the unit within a certain time, the ld will flash.
Could be 2 things.
1) There's lint stuck in the pump preventing the water to drain properly or
2) You're using too much soap causing lots of suds also preventing the pump from draining properly. If this is the case, what you need to do is run the washer on full load with no detergent and clothes. Let it go thru the cycle and get rid of eccess suds. This is most likely your problem.
Best of luck :)
Jan 14, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore (Calypso) Elite Washing machine shows LD and LF!
LD means long drain and according to the manual your drain hose could be clogged or kinked.
LF means long fill. check your water hoses and the screens to make sure they are not clogged. Had that happen to me once and i had to change the hoses. several months later same thing happened and it was the motor pump part # 8054968, this you can fix yourself.
Dec 10, 2008 | Kenmore Elite 21086
Kenmore 4.3 cu. ft. High-Efficiency Top-Load Washer Logo
55 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
