Question about Radio Communications
I have a general lee connex 3300 , the radio works great but the pa is not loud at all and can barely be heard , I know it's not the speaker or the mic because I immediately plugged them up to my cobra and it is loud like it should be , can you help me?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Have you tried unplugging it and plugging it in again?
Posted on Nov 22, 2013
3 Suggested Answers
  • 1274 Answers
SOURCE: Knob setting of front of radio (Connex 3300)
The best way to set it is to get you a radio check, go to channel 19 and ask someone about three to five miles away to give you a radio check, start with your modulation all the way open and go from there.....hope this was helpful...
Posted on Apr 20, 2010
  • 66 Answers
SOURCE: cobra 29, no rx, no tx, pa dose not work, good
Not sure which model you have as there are at least 13 cobra 29's. I am using the LTD as an example. You say good mic? Is it made for this model? If it is good then I would have to say the final audio stage is not working. The TA72222AP is the IC that is the final audio amplifier. Check pin 1 of the TA72222AP ic for 12 volts. If 12 volts is present then replace the audio IC TA72222AP. If 12 volts is not present then you have power supply problems that are internal. The conclusion I have made is based on no rx audio, ( could have been the jack at the pa and ext spkr) but you say they don't work either, also no meter movement during modulation check (that does not need a spkr to make the meter move) so yes I'm 99.99% sure its the final audio stage is a bad. If your model is not the LTD then the IC could be different but still the same audio final is bad. Replace the part which should be fairly inexpensive. If it uses a metal heat sink be sure to apply heat sink grease when installing new part.
Posted on Feb 27, 2011
Where can I purchase a service manual for a Connex 3300HP?
email me i have a generic one that is the same for all exports. ie galaxy 33-99's and connex 3300 superstar 3900's and general lee's style of radios. I thinks its for a superstar 3900 just ignore the SSB & CW portion and its the same radio as the 3300.. any questions let me know
Feb 08, 2011 | Connex 3300 240-Channels Base CB Radio
My connex 3300 wont transmit anymore and the talk back wont work either,i have tried a different mike and when you key it up the meter still won't swing.
Plug in an external speaker to the pa jack ... Switch the band selector to pa and see if you hear yourself... No? Bad audio chip
Dec 29, 2010 | Connex 3300 240-Channels Base CB Radio
How can i disconnect the talk back on a connex 3300 plus? pleasa be specific on directions. thanks
in older connex 3300's you cannot disable the talk back. Its part of the audio chain. If you disable the talk back you will loose your audio. There are 2 things you can do.
Hook a relay to the speaker so that when the radio key's id disconnects the speaker. (Big pain, not worth the trouble.)
The other will not disable the talk back but it will stop any squealing.
Use a noise canceling mic. An RK-56 will work great. You will get no squealing with that mic.
Oct 19, 2010 | Connex 3300 240-Channels Base CB Radio
My connex 3300 hp stopped reciving it transmits people can hear me loud and clear but I cant hear them radio was working fine then one day I turned it on and couldn't hear any thing.
Hi, my name is John. Try a external speaker, plug it in the back of radio, turn the RF GAIN to MAX. Turn the SQUELCH all the way to left, make sure the select knob is on CB, and on AM...try all this and if that's does not do it, let me know, I will post other steps here,.... hope this was very helpful....
Sep 02, 2010 | Connex 3300 240-Channels Base CB Radio
No transmitt
if you'd like call me 904-845-3847 anytime on the week day. mel
Jan 06, 2010 | Connex 3300 240-Channels Base CB Radio
Can you calibrate a General Lee
buy a external swr meter.. usually like 10 bucks at any truck stop.
o your gonna need a jumper wire too for this.which is a short piece of coax you can get at any cb shop
May 26, 2009 | Connex 3300 240-Channels Base CB Radio
When I transmit it feeds through my stereo
if you are using a kicker (amplifier) alot of times they will cause it make sure your wires dont cross any of your radio wires under the dash
you can buy noise filters for stereos they are generally used for car amps but i have heard of people using them because of cbs too
May 02, 2009 | Connex 3300 240-Channels Base CB Radio
Need to know the normal use settings for the Connex 3300 HP. Changed trucks and wife cleaned the radio; I believe the settings all got messed up. Thank you very much.
turn the rf gain all the way uphave your pa fm am knob on am your band knob on your desired band hi rf power band hi or low depending on wich ever u want to uss
Mar 22, 2009 | Connex 3300 240-Channels Base CB Radio
Radio Communications Logo
48 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
