Magnavox mwc20t6 The TV will load a vcr tape and then eject the tape and shut off. When using a DVD it will play one particular DVD but shows a disk read error on all others I try. I'm not using the remote..just using the buttons on the front panel. I don't have a cable or anything else hooked up...just trying to use as a DVD player. Any idea why it shuts off when i try the VCR and why it won't play other DVDs. Note: disk read error doesn't seem to be specific..just general error type. Thanks
  • 1,511 Answers
Toss this out as it is no good
Posted on May 09, 2014
techman
  • 3130 Answers
SOURCE: Tape Loading Error
theres a loading problem with the mechanism. It could be a nylon cam thats cracked and thrown it out of mechanical alighnment??? this is not for the handy man repairer!!! this should be taken to a repair shop for an estimate! as there are hundreds of volts inside a tv that can cause you to be seriously killed!!
Posted on May 21, 2006
nfandres
  • 168 Answers
SOURCE: vcr trouble
this combo unit as far as i know has only one power source which is in the vcr unit. if the vcr has a problem it affects the tv likewise. i beleive u did removed the tape, but unfortunately you misaligned the mechanism of the vcr which will in turn sense an error causing the automatic shuts off of the vcr and likewise the tv. u need to bring it to a qualified service technician if u dont know anything about this.
Posted on Jan 16, 2007
  • 28 Answers
SOURCE: sylvanis tv vcr dvd combo
It sounds like the VCR mode switch is dirty. This is located on the PCB, underneath the right hand side of the VCR mechanism. If you do not know what you are doing, I do not recommend trying to clean it yourself. You have to remove the VCR from the board, and pop the wheel off the top of the switch. Use a cotton swab with a bit of alcohol to clean it, and then put a dab of WD-40 on it. Good luck. Also, you might want to tryt to reset the VCR mechanism to the fully ejected position if it is not there already.
Posted on Sep 18, 2008
  • 3 Answers
SOURCE: Magnavox mwd 2206 dvd vcr player....shuts off with eject word across screen.
On a unit I checked with this same symptom, removing the top cover allows the unit to stay on and operate normally. There is some sort of sensor at the left middle of the chassis, which, when unblocked by any opaque object, allows the unit to remain on. A temporary fix (not advisable) would be to replace the top cover with a piece of clear plastic or taut saran wrap (no vent holes needed). It's unclear exactly where/what that sensor is from a cursory test. This is a work in progress on someone else's machine that I lack full access to.
Posted on Jul 07, 2009
gopakumarg43
  • 74185 Answers
SOURCE: My Magnavox TV VCR/DVD set
Hello
Your Magnavox Combo has mechanical problems in its VCR mechanism, which jams or not run properly. If the Casett tape doesn't run properly, the take up reel sensor inide it will sense this situation ans "Stop", or "End", and will automatically ejects it. If the mcchanism has some trouble with it, there are sensors to detect the trouble. and will stop it from preventing further damages ot the casette tape. It may be due to any motor trouble, shorted or opened low voltage regulators, ans so on. As it is a multi combo, there is no one sentence answer about the detection of this problem. We have to detach section by section to detect which section causes the overload to power supply. The wiring and schematics will be very complicated that you must have well experienced to do this job, otherwise total failure will be the result.
If you have enough awareness in electronics, and have some practical experience, and knoledge in this case, inform me, I'll assist you in this case. Soemtimes we are now thousands of miles apart. There will be a limitation for an online asistance you know.
Anyway if you have confidence and have a concept of soldering, and have a very good quality Digital Multimeter; inform me by Fixya. I'm ready to assit you. OK.
Posted on Jan 03, 2011
VHS tape will not eject and unit shuts down
It's not loading correctly. You need to open the cover (unplug first) and get familiar with the loading mechanism. You can get the tape out by rotating the loading motor wheel.
Mar 22, 2015 | Magnavox ZV427MG9 DVD Recorder/ VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
I am attempting to record from a VCR tape to
I have a Magnavox MWR20V6 and I am attempting to record a Tv show but when I play it back the recording is just black.
Jan 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I hAVE 24 in DVD triple combo ^&@$DG TV. I put
You're describing what could be a loose or worn loading belt problem, most of the vcr mechanisms used in these combos use one to load the tape and thread it for it to play or record, that is why you have to keep puhing the tape untill the machine accepts the tape and you have to keep pressing play untill it starts the play function.
Sep 19, 2009 | Sylvania Televison & Video
MAGNAVOX DVD/VCR RECORDER
I have been using my machine with no problems, until recently. The machine will not stay on more than a few minutes when I try to use it, either watch a tape or tape a show. It starts, then just shuts down. When the machine is turned back on it ejects the tape????
Can you help, please.
Thanks
Sharon
Jul 07, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
T.v. ejecting vcr tape and turning self off after being turned on
If VCR mechanism doesn't load or unload properly, TV will shut off. VCR machnisam in your TV requires cleaning/ service. Spacialy belts and pulleys.
Jun 22, 2008 | Philips Magnavox DVD/VCR Dual Player
Oct 27, 2007 | Audiovox VE1020 10.2 in. TV/DVD Combo
Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Jun 11, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
