posted by jt4242 on Oct 09, 2007
I just got a "new" Pavoni Espresso Si machine but when I make the espresso, water leaks out from the top of the filter holder (where the filter holder attaches to the main plastic part of the machine) and also from the crack just above the Pavoni seal on the front of the main part of the machine. Any ideas?
Also - a question - how hard are you supposed to turn the porto-filter in the holder? just till it locks or further? I can push it quite far but am not sure if I need to.
Best Solution
posted on Oct 31, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Check your screws in the bottom of the portafilter, If they are too tight the spring mechanism inside can't do its job, adjust them and it should work. Also, don't over fill your portafilter, if you put too much coffee in then there is to much pressure and again the water will flow from the top. Hope this helps
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for La Pavoni Espresso Si PAB-16 Espresso
Email this problem
Email this problem
Can you Help with these Coffee and Espresso Makers problems?
La Pavoni Espresso Si PAB-16 Espresso Machine
Pavoni espresso machine-heating...
Pavoni espresso machine-heating... Answer This...
NEWCO manufactured 1989 model...
We have a 1989 model NEWCO... Answer This...
need instructions how to use...
have second hand machine and... Answer This...
Krups Orchestro 889 - stuck...
I?ve been using my Krups... Answer This...
Repair Service
Find Coffee and Esp. Repairman Near You:
