Sharp How To Connect vc-h952
Can't get tv picture to show or record
  • 537 Answers
SOURCE: Taping TV shows
You need to have an antenna in (from TV antenna or cable). Set the VCR to that channel and press RECORD. Or use the on screen menu to set up the recording time/channel
You really need to have a manual to find the step by step instructions for your VCR. Go to this website and search
for a VCR manual from Sharp. I was there and did not find the exact manual.Download a couple of ones that have similar model numbers and follow the process.
www.retrevo.com
Or call Sharp and ask them to fax/email you a manual.
http://promosearch.sharpusa.com/search/?sp-q=vc%20h954&sp-a=sp10009e61&sp-k=
Mike
Posted on Nov 02, 2007
SOURCE: reording from tv to a sharp vc-a560
I am not sure how I fixed it but It works now. Thank You :)
Posted on Mar 28, 2008
SOURCE: Video cassette recorder Sharp VC A36YM
this should help you good luck
http://www.visualtv.net/faq/sharp_vcr.htm
Posted on May 31, 2010
mybradley7
  • 242 Answers
SOURCE: vc-a573u (a) stop working
clean the heads.
Posted on Jul 16, 2010
danbusa
  • 185 Answers
SOURCE: Would you happen to know
Hello! Here is the link to our remote codes, if that fails follow these additional steps for the Power Scan this should resolve it as well.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
***BEFORE STARTING THIS USE THE INSTRUCTIONS IN THE LINK TO PROGRAM THE REMOTE TO 222
  1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate (about 3 seconds), then release.
  2. For AUX mode Power Scan ONLY: press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device, then press *.
  3. Press and release the Power button.
  4. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
  5. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
  6. To verify the code works try several different functions for that equipment.
Daniel Busa
DISH Network Customer Service
Posted on Jan 21, 2011
WOULD LIKE A USER MANUAL FOR A SHARP VC-A582U
It depends what you are recording from. Most newer tv broadcast will block the recording by injecting copyright code into the stream. It forces you to get a dvr system from the company like cable or satellite. Because of the new digital broadcast it makes over the air recording to vhs difficult. More for the fact that you have to hook a converter box to the vcr to get the signal from digital to analog again. Here is the link to the manual. http://archivos.diagramas.mx/otros/VCA582U.pdf
Sep 23, 2015 | Sharp VC-A582U VCR
Manual for sharp camcorder model VL-E760U.
I HAVE A PROBLEM WITH THIS CAMCORDER, WHEN I CONNECT TO VIDEO INPUT OF MODERN DVD RECORDER TO RECORD FROM 8 mm T6APE TO DVD DISC THE PICTURE THOSE NOT SHOW PROPERLY IT SHOWS QUARTER OF THE PICTURE . WHEN I CONNECT DIRECT TO TV COLOUR TO PICTURE SHOWS IN ALL SCREEN, CAN YOU SUDJEST SOMETHING FOR THIS PROBLEM?
BEST REGARDS
FRANK PLEVEN.
Feb 12, 2011 | Sharp VL-E760U Camcorder
I need instruction to set recording for sharp h952 vcr
You need remote to get menu to set the clock then go to timed recording setting. Then you load a new tape, then shut down the vcr and wait for the timer to start the vcr and recording for you.
If you need a manual, google for sharp vcr manual download free from sharp website.
Aug 26, 2010 | Sharp VC-H952U VHS VCR
Can not find my instructions book to turn my freeview tv into my video recorder
If the TV has a scart then you don't need to tune it. All you need do is connect a scart to the VCR and TV. Then when you want to record anything, set the VCR to an AV setting instead of channel 1 etc. You need to set it to the one with the scart, as the VCR will have more than one AV looking at it's picture. You then just press record. You won't be able to change channel, or the VCR will record that channel instead.
If this is a problem, get a freeview box and just have it connected direct to the VCR.
If the TV has only one scart, you can get one of these boxes below.
Feb 09, 2010 | Sharp VC-H812U VCR
I have a Sharp VC-MA31 vhs recorder and I can not tune the channels of my t.v. into the VCR so I can not tape any channels.
you need to put the antenna cable to the vcr first then connect the vcr to the tv the tv gonna be on the 3 channel, and put on the vcr the channel you wanna record
Jul 07, 2009 | Televison & Video
I have trouble taping when i put the timer on it does't tape.
You are looking for a user manual? Is the Sharp VC-A554U VHS VCR the correct model or do you have another device?
Thank you.
Jan 26, 2009 | Sharp VC-A554U VHS VCR
Sharp vcr problem
The way to connect them is as follows:
1. Connect the cable from the wall to the cable input on the cable box.
2. Connect the cable box RF output to VCR RF input (VCR must be on channel 3).
3. Connect the RF output from the VCR to the RF input on your TV (TV must be on channel 3).
After all the connections are done, leave the VCR and TV on channel 3 and use the cable box to select the channel you want to record programs from.
Good Luck.
Jul 10, 2008 | Sharp VC-A410U VCR
Reording from tv to a sharp vc-a560
Mar 27, 2008 | Sharp VC-A560U VHS VCR
Taping TV shows
www.retrevo.com
Mike
Oct 31, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
