Question about ASUS M2N68AM Plus Motherboard
Tpm device cant detect - ASUS M2N68AM Plus Motherboard
2 Suggested Answers
JonBrant
  • 129 Answers
SOURCE: turned new computer on got this message:
Should be able to turn it off in the BIOS so it doesn't try and detect it. Bet it's an Acer
Posted on Jul 25, 2011
Samsung chromebook recovery. i get keep getting error messages when loading recovery image and the chromebook says its a trusted platform error. i dont know why this is happening
Trusted Platform Manager.
This issue occurs because the TPM is using the OEM driver and not the Windows built-in Trusted Platform Module driver.
To resolve this issue, open Device Manager on the device on which you are experiencing the issue, and then uninstall the Trusted Platform Module driver.
If you do a hardware scan, the TPM will be detected as a security device and will use the Microsoft driver. Additionally, the TPM will now be listed under Security Devices as "Trusted Platform Module 1.2."
Aug 14, 2016 | Samsung Computers & Internet
Is TPM Option available in HP 4440s?
Not sure. Dangerous to use as TPM stores your Bitlocker key and if corrupt all data is lost!
Fix This device can use Trusted Platform Module When Enabling BitLocker
Mar 01, 2016 | HP 4440s Probook
Bypass locked out
The TPM chip in the machine is locked out. You should be able to enter a recovery key, if you have it, but the TPM chip needs to be cleared. It's wise to call the manufacturer for specific support for this device.
Jun 26, 2014 | Dell Computers & Internet
Why wont my equium a100-337 wont post to bios, says there is a problem with the TPM? wont load bios menu either and hangs?
TPM is the security system in the bios.
If you can open the laptop remove the bios battery - most laptops dont have a bios reset jumper.
May 01, 2014 | Amstron Toshiba Equium A100-337 Laptop...
Ahci port0 device error
This indicates the hard drive is bad and close to failure, backup all critical files, test the hardware for errors using windows tools, it can repair files and attempt repairs on bad sectors.
May 28, 2012 | ASUS Computers & Internet
Turned new computer on got this message: can't detect TPM device
Jul 25, 2011 | ASUS M2N68AM Plus Motherboard
What kind of tire pressure sensors are on a 2000 olds alero and are they located inside the wheel?
{: ) The 2002 Oldsmobile uses the TIM system. Here is an overview of how it works:
The tire inflation monitoring (TIM) system detects the differences in tire rotation speeds that are caused by changes in tire pressure. The TIM may not alert the driver if the pressure in more than one tire is high or low. The TIM also may not operate properly if the spare tire is in use.
The TIM system can alert the driver when a large change in the pressure of one tire exists. The system only detects a low pressure condition while the vehicle is being driven.
The LOW TIRE PRESSURE indicator turns ON in the instrument cluster if the tire pressure in one tire becomes 12 psi (55 kPa) lower or higher than the other 3 tires and the ignition switch is in the ON position. The message does not appear if more than one tire is low or high, or if the system is not calibrated properly. The system does not inform the driver which tire is low. In order to clear this message, equalize the tire pressures in all 4 tires and perform the Tire Inflation Monitor Resetting. In addition, the indicator may come ON if a low voltage condition is present.
In other words, this is not like the TPM (Tire Pressure Monitoring) system that is being used in later model vehicles, wherein the TPM sensors are inside the wheel, integrated to the tire valve. The TPM sensors detect changes in tire pressure and temperature, and sends out radio signals to the RCDLR, to be decoded by the BCM and the instrument cluster.
Jul 21, 2011 | 2000 Oldsmobile Alero
No tpm or tpm not working on pavilion dv6910us
I think you are trying to use BitLocker but the TPM (Trusted Platform Module) is not available or not supporting.
Refer the below link for "How To Use BitLocker on Drives without TPM"
http://www.howtogeek.com/howto/6229/how-to-use-bitlocker-on-drives-without-tpm/
Sep 29, 2010 | HP Pavilion dv6000z Notebook
How can i send pictures from windows photo gallery to verbatim?
When you connect the SmartDisk into the USB port of your computer, the computer will detect this as an external storage device. When you open this SmartDisk you can create folders to store your photos. Just select your photos from your computer where the photos are stored then copy and paste these photos into the folders on the SmastDisk.
Sep 25, 2010 | Verbatim SmartDisk Firelite Portable USB...
Dropped in water & windows cant access the device.. is it permently damaged?
If you haven`t already done it open the case up carefully and use a blowdryer on warm and low to thoroughly dry the insides out, before plugging it in or you could permenently damage both it and your computer.
Sep 06, 2010 | Verbatim SmartDisk Firelite Portable USB...
ASUS M2N68AM Plus Motherboard Logo
27 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
