Question about Systemax Computers & Internet
Everytime I start my pc up it reads files are compressed
I have a systemax pc with windows 7 cerial # is 106708350, how can I fix this, it has a new hard drive in it
  • Systemax Master
  • 27,725 Answers
Is it affecting your computer from running>???
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer pressENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
You might use the system restore to restore your system to an earlier time click start all programs
If it is a hardware issue the system restore might not work
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a serviceyou can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Posted on Nov 23, 2013
samisam
  • 106 Answers
SOURCE: Trying to install new Ultra-ATA
update your system bios first. as far as parition magic's related error.. if you were you delete the parition and recreate it, you should be ok. What's the error message you receive when you try to install windows on it?
Posted on Jun 17, 2008
kamal1984
  • 1383 Answers
SOURCE: My pc started up and got stuck on a black screen. PowerSpec 7501
Ok
If you have windows xp disk then you can fix bs.
When you power up the computer pressF2 or "del" key to enter in bios then go to boot option then set cd or dvd rom as first boot device then save settings and exit.
then put your cd or dvd disk into rom then it boot with it .
Then foolow the procedure
you need to enter in RECOVERY CONSOLE
thenj type in prompt "chkdsk /r" then press "y"
then it fix bs on harddisk.
Posted on Jul 20, 2009
SOURCE: corupt hard drive 1
First you'll need to acquire an external harddrive enclosure. IDE or SATA depends on your hard drive. Shut the computer down. Remove the hard drive from your computer and place same into the enclosure. You'll need to hook your enclosure with the hard drive hooked up in it to another computer and remove all your data. Place back the hard drive into your computer and now you can do a system restore or a full reformat and OS installation. Respond to me, if you need step by step instructions.
Posted on Aug 13, 2009
  • 107 Answers
SOURCE: DVD drive Read problem in my Dell Dimension 3000
Make sure you have any and all Windows 7 updates from Microsoft, along with any updates for your DVD drive for use with Windows 7. Some components work fine using Vista SP2 drivers, but some will need an update to work with Windows 7.
This Microsoft site might help verify if your DVD drive is compatible with Windows 7:
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
Posted on Feb 12, 2010
  • 368 Answers
SOURCE: I have a systemax desktop
In the beginning of powering on, there should be a screen that post you some F keys or even DEL key for you to go into setup. Press the correct key, then it should take you into the bios menu and then go into the boot priority, usually under advance if it doesn't have it's own tab.... then change the boot priority order to your HD, and not usb. Save and exit.
Posted on Jan 23, 2011
If TFGHT is compressed, can i reformat my laptop without cd? or pressing long 0. give me an answer. please! :
Saving space by compressing the drive is not a good thing.
What follows applies to both 32- and 64-bit Windows Vista and Windows 7.
The tip off that the Windows drive has been compressed is a message which looks like the following. 'Some file' in the message can be anything. It might be BootMgr, TFGHT, QXHDK, DFJEU, VUFEI, DGKAR,..
'Some file' is compressed. Press CTRL+ALT+DEL to restart.
Windows will not start.
1. The first step to fixing this is to begin the process which leads to the Windows Recovery Environment (aka WinRE). In both Vista and W7, one can use an installation DVD if available. In many OEM environments (including Toshiba's), one can use the entry Repair Your Computer on the F8 Advanced Boot Options menu. In Windows 7, one can use a System Repair disc.
2. On the way to WinRE, you will encounter a screen that looks like this.
3. Click the Load Drivers button and you will find yourself looking at folders on your computer..
4. Find Computer on the left side (the navigation pane) and left-click it.
5. On the right side, right-click the drive with Windows (the C drive) and click Properties in the pop-up.
6. At the bottom of the Properties box, clear the check box that says Compress this drive to save disk space.
7. Another window will pop up asking you to confirm the change. The windows will get messy at this point. You'll need to move them around the screen to see things. Don't panic.
8. On the new window, set Apply changes to drive C:\, subfolders and files, and then click OK.
9. Now you'll need to wait for a few minutes while the decompression takes place. You won't see a progress indicator.
10. After your hard disk stops showing activity, cancel the remaining boxes and restart the computer. It should boot normally.
Nov 16, 2015 | Toshiba Computers & Internet
My windows 7 build 7601 is not genuine? what do I do?
you needed to download window 7 activator from http://cnet.in/ download and run the window loader file and choose your PC brand and then install it... it will run in background... after few seconds the PC will ask you to restart the computer press OK and enjoy your window 7 activated
May 21, 2014 | Systemax Venture H431 Build-to-Order...
How do i view the backup from my previous computer ? i can see the photos from my iphone and one pdf file, the files from the computer are "protected"
Eortiz, did you try to read the files with a windows PC? Because when you connect the external drive to a PC you should be able to view the files and even be able to change the attributes like read only and hidden.
May 12, 2014 | Hitachi Touro Mobile Portable External 1...
When I open a program in window it keep rebooting itself.
A critical Windows file has been corrupted. Too late to fix it, you will have to reinstall it using the recovery cd that came with the pc when you bought it.
Aug 15, 2011 | Systemax (036052) PC Desktop
A month ago my window is vista and now I replace a new one "the window 7' then now I cannot find the memory card reader driver and the webcam together with the bluetooth device thats why im so...
Some PC Laptops have devices that doesn't supports Windows 7 Operating System. Even if you search for the driver in the Internet, if the PC Laptop doesn't support Windows 7, you can never find a driver that device. Here try using these if these will help you fix the problem, but do not expect that this will be 100% that it will fix your problem. As I said earlier there are some PC Laptops that don't supports Windows 7, But theres no harm in trying. Heres the Solution.
  1. First, you must download this software. DOWNLOAD
  2. After downloading the software, Extract the file into a folder.
  3. After Extraction, Go to the folder and click on the Setup file.
  4. Once the software is installed, Run the program and Start the Scan, This will start the scanning of installed devices in your computer.
  5. Now after scanning, Browse for your missing drivers (MemCard Reader, Bluetooth, Webcam)
  6. Click the download button parallel to the device to download the driver.
  7. Now after downloading the driver, you will see a install button beside the download button, click it to install the driver.
  8. After installing the driver, I suggest you reboot you computer for the newly installed software to take effect.
  9. And your Done.
Now if the procedure above, worked for you.. then congrats, your PC is Windows 7 Compatible. But if the device is still missing, I suggest you change your Operating System to the OS that is supported by your Laptop.
Goodluck. Hope my solution will help you. Thanks for using Fixya! Have a great day!
Jul 09, 2011 | Acer Computers & Internet
I have reinstalled windows, i need the ethernet and sound drivers for this pc. would it be possible to send a link to download them to a disk?
Download the drivers to the computer you are using. Then burn them to a CD disk.
When you go to download the drivers, Note where they are going First. Write the name of the driver file down. Then look to see where it is going to be downloaded to.
See if it is going to your My Documents folder, (Documents in Vista)
(Start > My Documents for WinXP)
It may go to a sub-folder within the My Documents folder. Downloads.
Double-click on Downloads to see.
It may go directly to your desktop screen.
Have a fresh CD disk in the optical drive. (CD/DVD drive)
Right-click on the file name when you see it.
Left-click on Copy.
Then click on Copy to CD, or the name of your optical drive.
Windows running on the Systemax computer, put the CD with the drivers in it's optical drive.
Go to My Computer.
(Start > My Computer)
Left-click on My Computer.
Now double-click on the optical drive name (Letter. Example; (D:) drive)
Then double-click on the name of the Ethernet driver file.
The Installation Wizard should come up, and lead you through installing.
(Essentially click on Next, Next, and Finish)
Restart your Systemax computer.
Go through the process again to install the Audio (Sound) file.
This is Systemax Support > Downloads,
http://www.supportforyourpc.com/tools/downloads4.asp
Oct 09, 2010 | Systemax Dual-Core AMD Athlon 64 X2 4400+...
Windows
Definitely a bad virus that deled ur files OR u did it.First u should back up and then reinstall windows
Aug 01, 2008 | Systemax AOL Optimized PC (100607) PC...
Installing Office 2007 Enterprise on new Systemax PC
i have to install
512mb ram in the system the system already have 512ram
Apr 18, 2008 | Microsoft Office Professional 2007 Full...
Computers & Internet Logo
27 people viewed this question
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
