Question about Shoprider SCOOTIE Scootie Jr Scooter
Disconnect backup beeper
I need to disconnect the backup beeper as I use it in house and it is driving me crazy
  • 2 more comments
  • Glen Kruger Jan 20, 2014
    Nice try Robin that is where you would think it would be even took control box apart as that was where it sounded like it was coming from. Next I will take battery box apart and see if it is in there.
  • Robin Hill
    Robin Hill Jan 20, 2014
    If it 's not located where i said then i say the wiring been tampered with, i repaired hundreds of those scooters so beware if it's a mod ...regards rob
  • Glen Kruger Jan 21, 2014
    Hi Robin, I appreciate the information. I will look again. I have taken the body base plate off and can not find it unless I need to take the controler box out and see if it is between the box and the cable hub.
    Thanks Robin I found it. I had to take the control box out after unplugging all connections and was much easier to work on then. I ran 2 lengths of 20 gauge wire to a micro switch I mounted in box on top of tiller. I then cut red wire and soldered one end to each wire coming from switch. Now when inside I turn it off and when outside I turn it on. Thanks again I really appreciate your help. For those who just want to eliminate it just cut red wire and heat shrink ends of wire.
  • Shoprider Master
  • 1,263 Answers
Hi, IT's located underneath the scooter, it a small circular bleeper....it's normally located within a black plastic sleeve, just tape up the ends , that should quieten it down.
But take care when doing this as the cable cab be easily damaged...
Regards
Rob
www.gewizrepairs.co.uk
Posted on Jan 19, 2014
Humming sound outside my house (even with all power disconnected). How can I track down the source?
Take a drinking glass and put it up to your ear and then put the other end on the plumbing and see if it is coming from the ground.
Oct 21, 2017 | The Audio Players & Recorders
How can I disable the backup beeper on an excel yoga mobility scooter?
99% of the time this is done thru a programmer. but you can try disconnecting your horn (if any) located at the front top tiller mechanism.
Aug 14, 2016 | Health & Beauty
How do I disable rear beepers on dihatsu charade, pleas?
Usually you can locate the actual beeper under the dash and disconnect it, but then you loose all beeper warnings. Other way is to find the wires running to the sensors in the back bumper and cut them, taping the ends. This is there for your safety. You sure you want to do this? (Yeah, I know, they drive me crazy too)
Dec 12, 2014 | Daihatsu Charade Cars & Trucks
How can i turn the beeper off on my Oster bread maker?
I think you may be stuck with it. I have never owned a bread maker but going by the posts on websites it appears these beep a lot and can drive people crazy. I am assuming the only option maybe to find where the beeper is located inside the unit and cut the wires. It is definitely a safety feature and manufacturer may not want it to be tampered with.
Make sure you do not violate the warranty conditions if you cut wires.
Jul 28, 2014 | Oster 5834 ExpressBake Bread Maker
How can i immortalize the alarm on my shoprider electric scooter
Hi , what model shoprider is that ?
Regards
Rob
Jul 16, 2014 | Shoprider Health & Beauty
How to kill the door beeper?
you can remove the switch for the drivers door and tape the plug then cover the hole. its located right below the latch the on door opening
Mar 16, 2013 | 1996 Subaru Legacy
How to disconnect the back-up sound oon a medical drive falcon 4
Hi. On most scooters, the reverse beeper and the horn beeper noises are emitted from the same speaker.
The simplest way, is to unplug the speaker from the circuit board, although this might also disable the horn. It is easy to reconnect the beeper if you need to.
If you still need to use a horn, you can get cheap plastic ones from the bicycle shops.
Good luck. Neil.
Jun 11, 2010 | Drive Medical Drive Falcon 4 Wheel Compact...
Backup Beeper
Hi. A lot of scooters use the same beeper for reversing and for the horn. The quickest way to disable the horn is to unplug the speaker or beeper from the circuit board in the top of the tiller where the controls are. If you ever need to make it work again in the future, its a simple matter to reconnect it. If you still need to use a horn, buy a cheapie one from the bicycle store.
Good luck. Neil.
Jun 03, 2010 | Drive Medical Daytona 4-Wheel Power...
I want to disconnect annoying "door open" beeper on my Kenmore
Of course you can disable the alarm - depending if you're handy or not.
If you remove the main PCB ASSEMBLY, you can de-solder the piezo making the noise and remove it from the board.
Be careful - however - as this is a $215 controller board :D
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 15, 2009 | Refrigerators
Is there a wy to disconnect the beeper?
Looking at the owner's manual, there is no shutoff listed.
One way to make it quieter is to put a piece of electrical tape over the piezoelectric beeper.
To silence it, you would need to cut one connection to it, desolder it, or simply break it off.
Disassembly & safety info:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Nov 30, 2008 | Sanyo EM-Z2000S Microwave Oven
Shoprider SCOOTIE Scootie Jr Scooter Logo
180 people viewed this question
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
