Question about Sharper Image Deluxe Spire SI788SNX Tower Fan
Need new pedastal base broken pedastal - Sharper Image Deluxe Spire SI788SNX Tower Fan
Where can I get a replacement base for ld200sl9 tv
Glad to hear it, I suspect ebay would have been your only realistic hope. Your TV is made by Funai
May 28, 2014 | Sylvania 20"" LCD TV with Built in DVD...
Have a bulb broken off inside socket in gas oven..cannot remove..need help
power down at the breaker or unplug the oven,then if possible you can remove the lamp cover and shell from the rear oven wall,then most lamp bases have spade terminal connections unplug these remove the whole lamp base with the broken lamp,remove the broken bulb base,then check the center power tab inside the lamp base to make sure it isn't flattened out too much,otherwise carefully bend it upwards to make sure it makes contact with the bulbs base then re-insert the terminal connections and new bulb into the opening at the rear of oven,then replace the bulb,but,do not over tighten new bulb as this leads to non operation due to heating
Jan 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Brand new tub vibrates so bad i have to turn it off very unhappy
have you removed the shipping bolts on the back of the machine and make sure it is level and all the legs are locked.if it is attached to a pedastal then make sure that it is properly secured to the pedastal.
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a pedastal singing machine that is missing the power cord. Where can i get a replacement?
Nov 08, 2010 | Audio Players & Recorders
How do i fix broken handle
HI, The tool you are looking for is a Basin Wrench. Google Plumbers tools pictures. I am sorry I can't provide you with a picture myself, kind of new on the computer. Good Luck. Home Depot, Lowe's or a hardware store has them.
May 21, 2010 | Kohler FortĀ© Widespread Lavatory Faucet...
How many bolts hold the pedastal to the block on a 1996 f350 turbo charger
there is a total of 4 bolt holding the pedastal to the block and two bolts holding the turbo to thepedastal
Mar 28, 2010 | Ford F-350 Cars & Trucks
LG WM0532HM is level but make my house vibrate Can anyone help?
Put 5 or 6 bath towels on a quick wash cycle.
During the spin cycle adjust the feet on the washer to smooth out the vibrations. Some times you only have to adjust one foot on the front to make a big difference.
If you have a pedastal snug up the washer feet to the pedastal then proceed above.
The washer came with a flat silver wrench to adjust the feet.
Jan 16, 2010 | LG WM-0532HW Front Load Washer
Missing LG pedastal
You can find a replacement base stand assembly for that model (42LC7D) at the following link:
LG 42LC7D Replacement Part Base Stand Assembly
Model # RU52SZ30 may have no stand / pedestal available.
Nov 17, 2008 | LG RU52SZ30 52" Television
Attach pedastal to whirpool duet washing machine front loader
you will want to lay the duet unit on its back. remove the legs. put the base up to the bottom of the duet. you can use the legs as bolts and pass them thru the top of the base back into the bottom of the duet appliance, using them as bolts. I have had some people just get new bolts. this should fix you up. please rate this if it was any help.
Thanks,
David
Oct 11, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Sharper Image Deluxe Spire SI788SNX Tower Fan Logo
19 people viewed this question
Top Sharper Image Dryers Experts
Are you a Sharper Image Dryer Expert? Answer questions, earn points and help others
