How to remove mould from inside wall?
I found mildew mould on my interior walls. Suggest me a way to remove it.
    Sergeant:
  • 302 Answers
One good way is to make a fairly strong solution of bleach and water and wash affected area,(with gloves on) allow to dry. Long term , mould and mildew is caused by moisture and poor air flow. Check to see if can find any moisture entry points and try to improve air flow (install air vents in wall).
Posted on Nov 22, 2013
I have painted the wallpaper in my kitchen about three times about two years ago I used Dulux matt dark streaks have appeared on the outside walls condensation marks? the paint looks chalky do you think...
There are 2 types of paint I do not like, Behr and Dulux. Buy Benjamin Moore for best results. Painting wallpaper is not advised, if it is not adhered on well, you can have trouble. Streaks could be condensation, especially in a bathroom, a kitchen can also be damp because of boiling pots. Warm moist air condenses on a cool object. It could be the wall paper is losing adhesion. Check to see if the paper moves a bit when pressed. Remedy is remove the wall paper and repaint. Get all the glue off, scrape it after soaking the wall. Sand the wall, wash with TSP, rinse with clean water. If you don't do this, you will get a lousy paint job. You would be best to prime then top coat. Alternately get a paint that is self priming. In a moist area use Zinnser
Home Hardware Paint Dcor
Zinsser 1 gal Perma White Mold and Mildew Proof Satin Interior Paint 2...
Mar 02, 2015 | Miscellaneous
Mildew has entered the inside of the plasma tv
Let me get this correct, you can see mildew/mould inside your TV? If it's inside the LCD panel (obscuring the picture etc) then I'd get the panel or TV replaced. If it's just on some of the other internal wiring and the TV still works ok I would give it a good clean with some alcohol (such as isopropanol) , perhaps put a sachet of silicon moisture absorption crystals inside the TV somewhere, seal the TV back up and hope it doesn't occur again.
Mar 19, 2014 | Panasonic Televison & Video
We have a very foul in our mobile home, and we think it is coming from our empire heater! is there anything we can do to fix this odor
Oder doesn't seem to be electrical smell or you would know a house fire may occur. We normally know the electrical smell I'm worrying you about, and if it is that, do not use it and call a professional! It may be mildew in the unit or in the ductwork. Mildew is quit common, mold is not. No one LEGALLY can tell you it's mold unleased certified by you state or province. Mildew can grow anywhere we have a warm surface that comes in contact with a cold surface. This means uninsulated ductwork, or aged ductwork. The unit itself can also produce some mildew due to lack of maintenance. And also, water can get inside the duct for many reasons if you have cooling. If water is trapped it can produce "growing" stuff and a smell. Varmints can also cause this, either by dying inside the unit/duct or by leaving their droppings, to say it nicely. Temporary fix is what we call in Texas a Odor Cake. These are sold at the HVAC parts houses. Come in a little Tupperware style cup, and are mainly used for fire, smoke, and mildew damage to a structure. You just set em inside the airflow and the help, but don't solve the issue. If mildew is present inside the unit, have a tech out to inspect/clean. And a ultraviolet light may be needed to help control the growth. Internet U.V. Light for HVAC to study on them. Hope this helps!
Sep 04, 2017 | Empire Heating & Cooling
Mold and Mildew
several products can be used --- white vinegar --- bleach---exit mould ---
Jun 22, 2013 | Limeaway Lime Calcium And Rust Remover 28...
We have mould spots in the corner of our downstairs toilet.. started with just a small amount but now have lots. Not a patch of mould but lots of small spots. the room is on the outside corner wall of...
There is probably moisture inside the wall. Take a look at the outside of the wall to see if you can identify the source of dampness. Maybe leaves are piled against the outside of the house, or vines are growing under the siding, or a downspout is splashing against the house when it rains. Or perhaps you have something leaking down inside the wall from upstairs. You will probably need to remove a bit of the wall from inside. If it's drywall, this isn't very hard to do, but start with a small hole, maybe 6 inches across. If you find wet insulation, you should enlarge the hole and remove all of the wet stuff. Before you replace all of the wet stuff with dry stuff, you need to remove the source of the dampness. It could also be that this corner is poorly insulated and gets lots of condensation from the shower. Good luck, Al K
Nov 16, 2010 | Cornerstone Positec Group Ltd No.MM11 Mm...
Our Clothes seem to smell after being washed, checked drawer and found lots of mould etc how do get rid of this problem, why does the drawer attract this mould? i wash reguarally.
its a comon fault,,,i would put in a strong vinegar into the drawer and do a rince with nothing in the washer first this will kill off any mould after that do a fuw rinses and then leave the door open after you use the washer to stop any more mould growing in it this also works on wood and walls too!
Jul 30, 2010 | Washing Machines
Is there a way to make a stud wall for a shower part transparent?
You mean clear plastic dry wall? or how about a window? How about removing the wall and putting in glass panel? Glass block? Anything can be done, depends on your imagination. An exterior wall can be totally removed with a lintel replaced in the top, and interior wall can be totally removed with no lintel, depending on trusses, or rafter placement.If you want to leave the studs exposed in the wall, I would clean them up a bit. The problem with that is you can't clean it and the panels are subject to fogging up inside, condensation will get in there, an exterior wall is a bad idea, no insulation. Hope this helps.
May 20, 2010 | Basco Semi-Frameless Tub Shower Enclosure...
I would like remove old vinyl shower wall and install a tile wall. but do i have to remove the drywall also? I'm keeping the shower base.
if the sheetrock is in good shape you should not have any problems. If you are worried about mold and mildew, you might want to change out the drywall with either green coat or yellow coat- these are mold and mildew resistant
Nov 04, 2009 | Home
Build up of mold/mildew on rubber gasket. Makes
you need to purchase a package of 3 tablets called AFRESH at your local appliance parts store and follow the directions on the package. also, leaving the door open a bit after each wash will help.
Oct 24, 2009 | Frigidaire Affinity ATF7000E Front Load...
Mildew
I have found nappy soaker on a damp rag effective in removing mould from fridge seals. It might also work on you washer.
Mark
Jun 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
