Question about SVAT VU500-C Long Range Night Vision Hi-Res Indoor/Outdoor CCD Camera with True Color ID and Vandal Resistant Bracket
Horizontal lines on my screen and video images going off intermittent
The lines are moving up on the screen and the images keep going off
My Z1275 has developed intermittent horizontal lines on the view screen when the camera is moved, and on images some times. Get good images if I use tripod and shutter delay. Looks like loose connecti
When having bright lights on a dark background, you can have horizontal lines. That is supposed to be normal. but the camera should give good pictures in bright light. Try setting the camera in automatic. most of the time it is the green camera loge on the mail dial.
Jul 21, 2014 | Kodak EasyShare Cameras
Insert game disk and horizontal lines move fast on screen ???????
Sounds like your TV has multiple video inputs. Make sure the TV is set to the right channel or input. I know on ours if I hit the TV-input button on the tv remote I can change from inputs like s-video, video, cable etc and the Wii only displays properly on one of them.
Mar 28, 2009 | Nintendo Wii Console
LCD screen purple and distorted in Shooting mode
There is recall on this model for this problem, Go to Canon USA web site, Look up Service advisory, CCD malfunction N/C to repair.
Feb 24, 2009 | Canon PowerShot A80 Digital Camera
Black horizontal lines
Sounds as if you have a bad capacitor in the horizontal deflection or video circuitry. You can spot a bad capacitor in circuit with a ESR meter.Hope this helps.
Jan 16, 2008 | Mitsubishi TS-5545 55" Rear Projection...
Horizontal line throught the screen.
Sounds like it might be getting too hot and/or going bad. Try it on another machine and see what it does. Also try another video card because the video card could be going bad.
Nov 12, 2007 | Gateway FPD1975W 19" LCD Monitor
Panasonic PV-GS35 Viewfinder screen connection problem in hinge joint
the hinge is definetly damaged and is going to need replacing. these hinges do need replacing if used allot because this is a moving mechanical part. This is not a easy thing to do, it needs to be done by a panasonic technician.
Oct 11, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Lines appearing on camera and images
Chwck the Samsung website -technical Support team -especially if this is a recent purchase. But generally speaking this is a no repair situation.
Jun 11, 2007 | Samsung Digimax V50 Digital Camera
Horizontal lines traveling up screen
Sounds like a ground loop on the video signal. Try using a ground lift on your computer and or your projector.
Jan 09, 2007 | Sanyo PLV 70 Multimedia Projector
Red Horizontal Lines On Screen
Sounds like the DMD board, I would rather have Samsung to do the in home repair
Dec 27, 2006 | Samsung DLP HL-P4663W 46" Rear Projection...
SVAT VU500-C Long Range Night Vision Hi-Res Indoor/Outdoor CCD Camera with True Color ID and Vandal Resistant Bracket Logo
14 people viewed this question
Top SVAT Home Security Experts
Lawrence Oravetz
Are you a SVAT Home Security Expert? Answer questions, earn points and help others
