Kdf46E3000 If I watch the TV for an hour it won't turn back on until it cools down completly. I hear the fan running so I do not think that is the problem. There are no warning messages and no red lights on the front panel.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
that is a control board problem , you need to get it fixed on a repair shop .
Posted on Nov 22, 2013
Slinteriors
  • 8617 Answers
SOURCE: Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Posted on Apr 01, 2008
  • 80 Answers
SOURCE: LG 62SX4d
please provide the complete model number - look under the model # and you will see rest of it - also on the side
thanks
nipper00
Posted on May 26, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony- KDF-50E2000
Have you replaced its Lamp?
Symptoms shows TV needs new lamp.
Please always buy original Sony lamp for replacement.
Posted on Mar 15, 2009
praky16
  • 744 Answers
SOURCE: no picture- no sound
hi
first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Posted on Jul 12, 2009
  • 927 Answers
SOURCE: I have a Samsung HLS4266WX/XAA that keeps turning
Dear dreadtrainer;
It sounds like your Lamp is going bad. The part # B96-01472A. Go to internet (like Google), enter Model # and Lamp toget your best price. To replace the lamp is easy, look at your 'owner's manual".
Good luck, Big Irish.
Posted on Nov 21, 2009
"My sony bravia kdf46e3000 wont always light the lamp when first turning tv on. I can see it sparks the lamp but the lamp only stays lit for about 3 seconds. The power light on the front stays green a
does the lamp fan stay on? you can see thru the back if the fan is running. If it is not running you need to replace it.
If it running you may need a new lamp driver/ballast part# 1-480-180-21 https://www.encompassparts.com/model/SONKDF46E3000/_/_/Sony/KDF46E3000/
then there is the possibility the new lamp is bad,, Sony's like Sony OEM lamps
Dec 20, 2014 | Sony Bravia Kdf-46e3000 46-inch 1080p 3lcd...
Why does my car sound like something's still running? I turned it off 1 hour ago.
(red-hot,) carbon build-up in the cylinders are burning fuel/air in the cylinder which creates more heat; turning the crankshaft and dumping more fuel/air in to the cylinder which is again ignited by the carbon....and so on. This is called 'dieseling' because it is essentially how a diesel engine also runs, (they have glow-plugs rather than spark-plugs.) This was far more common back when there was leaded-gas. Lead deposits form more quickly. Find som over the counter gas treatment for carbon build-up, and quickly. It is NOT good for your car.
Aug 21, 2012 | GMC Cars & Trucks
BATTERY IS COMPLETELY DEAD-COOLING FAN STILL RUNNING
Possibley a short in the wiring to the fan, i would check the underhood fuse box for a relay or fuse to remove so as to save the charge of the battery until you can isolate the issue. Water intrusion in the front frame area is typical.
Mar 24, 2012 | 2002 Chevrolet Cavalier Coupe
Hi there, I have a Samsung RS21DCNS F/F. and have just moved house and connected it all back up. The LED display lights up, but the fridge and freezers won't cool and there's no motor or fan...
Was the fridge laying down? How long? Rule is if a fridge is laying down for an hour leave standing for a minium of an hour WITHOUT PLUGGED IN. ^hours laying equals 6 hrs standing. I tell everyone give it 24hrs of standing to eliminate problems. If you plugged it in without enough time for the oil in the compressor to return back to the compressor you may have fried your compressor. Now if you did leave it long enough and the oil in the compressor got back in compressor before plugging in. It could be in your defrost timer or your start relay. Does the fan in freezer come on? Push the switch to make the fridge think door is shut. If fan does not run it sounds like the defrost timer. If fan does run the check the start relay on compressor. Does the compressor turn on? Do you hear a clicking sound coming from copressor? If you hear a clicking noise than its your start relay trying to come on. Replace start relay and overload. The model number you gave me is not valid so get the full model number and check thru Searspartsdirect.com
If you need further assistance please feel free to contact.
Jul 24, 2011 | Samsung Refrigerators
I have a HP PL4245N plasma HD TV. sometimes while watching it just shuts itself off screen goes black and will not turn back on unless I unplug it wait 20 seconds and plug back. Then it works fine. it...
Hello
I thinks you may be right. All plasma and LCD panel tVs will have cooling fans at the top side. Plasma screens will heat up much more, and if cooling fans stops work, of has damaged, the set will overheat, and awill automatically shut down; because there is a overheat sensor fitted inside it, will sense the heat, and if the set overheats, it will send a signal to the main system control fo the TV; which in turn shut down the whole system. look fans for proper working. If not replace them. OK.
Jul 04, 2011 | HP PL4245N 42 in. HD-Ready Plasma...
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
I have a Luxeon v1 that runs for about 1-2 hours and then shuts itself off. The bulb is off but the fan is still running. I am unable to turn off the projector and I have to unplug it from the outlet to...
First of all, DO NOT unplug the unit until the fan stops. The fan should continue to run until the lamp has cooled down completely. This is normal. If the unit is shutting down on its own, perhaps the fan is not working good enough. Check for debris in the fan area and be sure that there is enough ventilation to keep the unit cool. The shutdown may be a safety shutoff because of heat.
Check the fans and update this with what you find.
Dan
Nov 03, 2009 | Luxeon V1 Multimedia Projector
Refrigerator not colling properly
Let it run until you have a problem again then look at the back wall of the inside of the freezer, if there is frost then it's not defrosting and that would be your problem (usually the defrost heater). If you don't see frost then you need to determine if the compressor is running or not. It's possible to hear the two fans run, but not the compressor. If the compressor is running, along with the 2 fans, then it is a sealed system problem and usually not worth fixing. If it's not running you'll need to check the compressor start relay on the side of the compressor. It is possible for a bad compressor to cause the relay to fail, so replacing it may or may not get you going again.
Jul 21, 2008 | Kenmore 53642 / 53644 Side by Side...
DLP tv trouble shooting
Hi.
Yes it could be a cooling problem, If your tv has any filters remove & clean them ensure fan can turn freely & that nothing can or is snagging it.
http://dysonmanuals.inc.io/
Chris.
Nov 09, 2007 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
