Question about Black & Decker Black Decker/ Oldham 100P8160T Signature Series Woodworking Carbide Tipped
Black and decker warm drive saw model 977 front ball bearing
Front ball bearing replacement part where to find (two side sealed fafnir manufactured C1 200PP)
SOURCE: change blade on old model Black & Decker circular saw
I drp a screwdriver through one of holes in the blade; that "locks the blade" when the screwdriver comes up against the sole plate. Works great for tightening as well.
Posted on Mar 09, 2008
SOURCE: Black and Decker Blender Model Number 675 Replacement Parts - Collar
http://www.thegourmetdepotco.com/store/store_partaccess_index.asp?ManufacturerID=5&CategoryID=1&gclid=CICJ0pWm0ZMCFQnIsgodnkhAhg
Posted on May 31, 2008
  • 97 Answers
SOURCE: plastic safety key broke Black & Decker table saw cat# 1736
Try sears .They shoul be able to get it eor you
Posted on Mar 14, 2009
rowdy45176
  • 2176 Answers
SOURCE: I am looking for a manual for my Black &
Go to Dewaltservicenet.com and follow the prompts, I didn't find a type 2 online but they have ty1. Hope this will help. If I have answered your question would you please rate the response accordingly. Thnk you
Posted on Jul 04, 2009
efs_perpends
  • 1996 Answers
SOURCE: how do I replace the cord on Black and Decker port-a-band saw
It's probably some incarnation of model # 3122.
See this chart, for example, with parts listed. Is yours like it?
There are several different types of that model, all of them listed here.
Click on the catalog number to go to the exploded parts view and owner's manuals. Just select the cord you're looking for and choose the shopping cart icon at right, then pick the view cart icon from the header of the next page and you can check out. (like this one.)
Hopefully the diagram will give you all the help you need to change out the cord...
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 21, 2010
Black & Decker 977 Saw User Manual
Contact Black & Decker and request both the manual and the IPB.
Jun 18, 2017 | Black & Decker Saws
Need manual for black and decker worm drive saw 977
Might need more info on the model number. 977 seems a bit short. However, you might try http://powertool.manualsonline.com/manuals/mfg/black_decker/9774701.html. Hope this helps. Good Luck!
Aug 24, 2014 | Saws
Have a noise when driving a 1993 ford festiva.When RPM's are high no noise. but just driving. Sounds like from bck passenger side of car
does the sound go up when you trottle up?
put each wheel off the ground,put your left hand between the spring,
turn the wheel.when the bearing is bad you feel it in your left hand the trembling from that bearing.try each wheell.see iff any rubber off the excaust is good..
May 05, 2014 | 1993 Ford Festiva
Part that guides the blade is broken need a new replacement
Search online for black and decker parts using the model number (on the label on the jigsaw). But Black and Decker are manufactured to bot be very durable, its better and probably cheaper to replace it, with almost any other brand. If cost is an issue but a used high quality item on ebay, made by Makita, Hitachi, Bosch or Metabo. Even and old one of these is better than a black and decker.
Nov 01, 2013 | Black & Decker Scroll Jig Saw Blade
I need a switch for my black & decker 7 1/4 worm drive saw model 7395 type 1
That tool was discontinued in 1980 and parts are obsolete. You may be able to use a Skil 77 worm drive switch as many of the circular saw switches were configured the same. The switches are usually marked with a 1 and 2 on the back so make sure the wires are put on correctly as some will have the 1 on one side (top and bottom terminals) while others are on the top or bottom (next to each other).
Aug 05, 2012 | Black & Decker 7 - 1/4" Heavy Duty...
Why is my tile saw making different noises?
Sounds like you have bearings going/gone bad. If it's a direct drive model, check the bearings in the motor and on the arbor. If it's a belt driven model check the bearings on either end of the arbor shaft. As bearings go bad, someone using the saw regularly will notice a different tone in the tool. If you are getting vibrations that bad, the bearings are already loosing balls or the race is tore up and all the balls are on one side and can't doing their job correctly.
Mar 10, 2012 | Ridgid Saws
How easy is it to replace a front wheel bearing assembly? and also a diagram if possible.
It's not too involved. Here's a link with some more information to change it:
http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?pageId=0900c1528025fae3
Nov 05, 2010 | 1994 Pontiac Grand Am
I have the Black and Decker All-In-One Deluxe Automatic Breadmaker B1600 Series and it's worked well for years. Today I put the ingredients for a loaf in the bread pan and when it started to mix the paddle...
There is a sealed bearing in the bottom of the bread pan. The paddle sits on the sealed bearing shaft. Over time the bearing begins to fail and the paddle does not turn freely or it may even freeze up. If you are sure everything is installed correctly this may be the problem. See if the paddle moves freely by hand and is not really loose. Sealed bearings can not be replaced. Eventually you will need a new bread pan. Sorry Hank
Apr 21, 2010 | Black & Decker Bread Machine
Blade stops going once it hits the metal to be cut.
inside the motor/arbor section of the saw, there is a helical gear and worm drive on the motor. the front of the motor is supported by a bearing in the aluminum arbor section. sounds like most of the bearing balls are disintegrated and the worm disengages when a load is put on it but spins when there is no load. I would check and replace the front bearing.
Oct 24, 2009 | Ryobi Saws
Broken drive belt
Take the broken belt to an industrial supply house or Ball Bearing supply house for a replacement.
Jul 10, 2009 | Black & Decker BR300 3''x18'' Belt Sander
Black & Decker Black Decker/ Oldham 100P8160T Signature Series Woodworking Carbide Tipped Logo
26 people viewed this question
Top Black & Decker Saws Experts
Jason
Mike Carew
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
