Question about ViewSonic VG2021m LCD Monitor
How to open viewsonic monitor to clean micro switches
3 Suggested Answers
  • 96 Answers
SOURCE: Can I clean my
To clean the monitor first turn it off then use something like a microfiber cloth or something that is not abrasive to clean the surface. Don't press down excessively this can cause damage to the monitor. If that does'nt get all the fingerprints and such off a solution of distilled water with a little
white vinegar will do fine just use it lightly and don't drown the monitor. Make sure to use just enough solution to lightly dampen the monitor and not so much as to run down the monitor and
risk getting inside where the circuits are.
Posted on May 20, 2011
  • 187 Answers
no. Don't clean with water. Instead use a cleaning solution like cleanex or cleanmax and using a cotton or waste apply it on the monitor (not on the screen) and clean throughly.
PLS REPLY OR COMMENT. THANKS
Can I clean my ViewSonic LCD Monitor (VE510b) with water (using cloth)? Please tell me a procedure how can I clean my ViewSonic LCD Monitor screen.
May 20, 2011 | ViewSonic VE510b (Black) 15" LCD Monitor
I have viewsonic monitor In my monitor the OSD lock screen is appear as like pop up many times\ its bored me very much how i can remove that?
you have a problem with the buttons. if you know how to open it try removing the buttons (plastic buttons). if still the same you need a technician to repair the board of your monitor. switches are needs to be replace.
Apr 12, 2011 | ViewSonic E70f 17" CRT Monitor
Moneter is not opening fist some time blinking light 10 minets when con stend light switch of and swith on two times now it is opening
Look for bad DC filter caps in the power supply section (http://lcdalternatives.auctivacommerce.com/Viewsonic-C196320.aspx)
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 17, 2010 | ViewSonic VA1912w 19" LCD Monitor
My viewsonic monitor goes black after booting up
Does it do the same with other PC?
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 17, 2010 | ViewSonic VA1930WM LCD Monitor
Contrest & brightness menu always pops up and
there is a problem in micro controller chip in the monitor replace that biggest chip in the monitor problem will be solved
Feb 28, 2010 | ViewSonic VP920b 19" LCD Monitor
I have a problems with my Viewsonic vx2235wm, the On/Off button does not always make a good connection in turning off the monitor. I will push it and it will go off and then come back on immediately. The...
press it several times very very quickly, if it doesn`t start functioning the front panel must be opened in a service and the contact cleaned...i don`t think it needs replacement
Oct 28, 2009 | ViewSonic VX2235wm LCD Monitor
Ibm 9513-ag1 flat monitor broken switch
I have the same monitor. I had the same problem you have. I couldn't find the correct replacement part so I improvised. The plastic part you refered to just activates a micro switch on the circuit board. In my case the micro switch worked just fine so I used 5 plastic buttons off of some ball point pens as a replacement. I took the monitor out of its plastic case and drilled holes in the front bezel directly over each of the 5 micro switches. I then put the buttons from the ball point pens in holes. So now the push buttons from the ball point pens act as a substitute for the broken part. I hope this helps.
Apr 20, 2009 | ViewSonic VA721 17" LCD Monitor
Osd lock
turn the monitor off then hold the menu button and turn it back on at the same time
Jul 28, 2008 | Computers & Internet
ViewSonic VG2021m LCD Monitor Logo
26 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
