This error message may appear when the computer BIOS is set to boot from a network and cannot find a bootable operating system on the network or on any of the storage devices included in the notebook PC's boot path.
The following steps are for most HP Pavilion and Compaq Presario Notebook PCs. The boot order can be configured on the
Advanced tab in the BIOS settings menu. The steps to modify the boot order may vary depending on the model of your computer. On most HP notebooks the boot order can be configured using the following steps:
Turn on or restart the computer.
While the display is blank, press the F10 key to enter the BIOS settings menu.
NOTE:
Some notebook PCs use the F2 or F6 key.
Use the right and left arrow keys to select the Advanced tab.
Use the up and down arrow keys to select Boot Order .
Follow the on-screen instructions to change the boot order.
Reset the boot order to the default settings
Use the following steps to reset the boot order to the default settings:
Press the F9 key to reset the BIOS to default settings.
Press the F10 to save the changes and exit the BIOS settings menu.
I think it will you to fix your problem.
If still have problem then tell me more about it.
Thanks
Iqbal
