Question about Food Mixers
Fgxi ross login - Food Mixers
Kitchenaid frozen bearing
Hi Thaddeus, What model is it? If you have taken it apart and checked the worm gear surely you would have stumbled on the frozen bearing if one exists. When you split the gear cases you are in a position to turn everything by hand so any frozen part is going to be pretty obvious.
Cheers Ross
Apr 24, 2016 | KitchenAid Food Mixers
Mixer will run but keeps hesitating and makes a clacking noise
A model number would help but it sounds like you may have blown the fuse gear. I won't ramble on about how to do it (it's a big job for an ordinary person) until you come up with a model number.
Apr 14, 2015 | KitchenAid Food Mixers
How to pull out the motor apart on a model 3b because I can not pull the rest of the brush that's still inside mixer
You will need to replace the brushes once you get the stuck one out. You want to avoid pulling the motor apart if you can, I carefully drill down through the middle of the brush. Note CAREFULLY. You do not want to drill into the commutator that the brushes run against when the motor is running. Once you have your hole drilled you can try and extract it with a hooked pick type tool or with a vacuum cleaner sucking away at the outside you can break it up and it will come out in many pieces. Once you have it out clean up the brush holder with a small flat file and check that the new brush slides in and out freely. When filing be careful not to mark the commutator just beyond the inner end of the brush holder. Brushes are keyed and will only fit one way, look in the hole with a torch to see the key on one corner.
Feb 10, 2015 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchenaid mixer will not run on speeds LOW SPEEDS only runs on speed ten. I've replaced the phase board and that was not the issue. what else could be causing this problem
If it does not start at all until you get to speed 10 then look for a broken wire an any of the wires NOT associated with the phase board. Highly unlikely since you have just been there. Next look at the operation of the switch low down inside the black speed control board. There is a primitive switch there operated by a shaft from your speed control lever. You may find the switch is not activating until it gets right up to speed 10. Have you checked the carbon brushes? The phase board you have just done is normally the culprit for your problem.
Dec 20, 2014 | KitchenAid KSM75WH WhiteTilt-head Stand...
How do I get an owners manual for Ross mixer 12x2
What model of Ross Mixer do you have?
Dec 18, 2011 | Food Mixers
Need a manual
To geta manual fo a Hobart product you need to register on their website as a user.
Copy and paste the link below on internet explorer bar, then fill teh form and login on second link to access the manual.
New user registration:
https://registration.itwfeg.com/NewUser.aspx
Login page:
https://feg.hobartcorp.com/CookieAuth.dll?GetLogon?curl=Z2Fresourcecenter&reason=0&formdir=2
May 27, 2009 | Hobart Food Mixers
Food Mixers Logo
261 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
