Question about Garden
No user manual for pole chainsaw
Bought a hagen 52cc online but it came with the brushcutter user manual not the pole chainsaw, not sure how tight chain must be and at the front on the side of the chain there is a bottle & not sure what fluid to put in it
The chain should not have slack but not so tight it will not roll by hand (wear a glove) when u pull down on the chain in the centre of the bar there will be about 1/8" max slack. be sure the guide that runs in the bar groove does not clear the bar when pulling down. Chain will loosen over time so check ea time u fuel.
Jug is for bar oil, assuming a separate compartment has been identified for gasoline oil/ mix. when buying bar oil buy the grade to the climate u are in , heavy for summer -- light for winter -cold climate
Posted on Nov 22, 2013
SOURCE: Poulan Farmhand chainsaw chain tightens too tight for motor to move chain
Make sure the chain is not over tightened. When adjusting the tightness, ensure there is at least 1/8" of looseness by pulling up on the chain in the middle of the bar and releasing it. If a chain becomes overheated because of leaning on the saw when the chain is dull, or lack of oil on the chain, it may expand in the track and not turn freely.
Marlyn, Mountain, Ont. Canada
Posted on Oct 03, 2008
  • 35 Answers
SOURCE: Chainsaw chain won't move on 16" Homelite bar
Sounds like th clutch brake is engaged. Try Pushing firmly foward on the hand guard in front of the handle. It should click to release the clutch brake.
Let me know if this helps.
Posted on Dec 31, 2008
SOURCE: poulan pro with tooless chain tightening - chain will not stay on
i have a 4620 poulan that had the same problem. use it for 10 minutes, spend 15 minutes reinstalling the chain. i sent poulan an email threatening to sue them and they decided to send me the parts to change it over to the old style for free. try poulan.com
Posted on Apr 27, 2009
dontbother10
  • 2220 Answers
SOURCE: Poulan Pro Chainsaw chain tensioner is junk
Hammy if you scream loud enough Poulan may foot the bill for this.
Poulan “PP4620AVX” IPL (exploded parts list)
We are going to replace this page 2; item 70
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2009/NIUS2009-PP4620AVX-545103410-952802169.pdf
Poulan “PP4620AVHD” OM
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2005/NOUS2005_545047502.pdf
Poulan “PP4620AVHD” IPL
http://www.ordertree.com/modelinfo/PWE/PP4620AVHD-Gas-Saw/75.PP4620AVHD-Gas-Saw.1.59.1.html
With this; “Handle, Chassis & Bar Assembly” print; item 67; ChainBrake Assembly; $21.83.
You also need;
  • Item 68; Bar Mounting Nut; $0.56 each (need 2) and
  • “Engine Assembly” print; not illustrated; part number 545006011; Scrench; $9.75.
This is the configuration professionals have used forever. The only thing to remember here is to hold the nose of the bar up when adjusting and tightening the bar nuts.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 18, 2010
Testimonial: "Thanks -- that's exactly what I was hoping to find. It's wonderful to be able to tap into expertise like this. Very Happy!"
dontbother10
  • 2220 Answers
SOURCE: Remington electric Pole Chain saw - what type of oil do I use?
You need “Bar and Chain Oil”, available at hardware stores and home centers. It is SAE 30 with additives to make it adhere to your bar and chain.
An excerpt from a Remington manual follows (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F.
• Colder use SAE 10 oil.
• Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
• It is normal for oil to seep when saw is not in use.
• Empty oil tank after each use to prevent seepage.
Some manuals go from page 6 to page 14. This one is very good.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
Lou
Posted on Apr 24, 2010
Where do I buy spare parts for the 52cc 7 in 1 pole saw motor?
if the make is on the side of the machine then try the service dealer
the engine parts may be specific but the rest will probably generic
May 03, 2015 | Garden
How do I remove the clutch plate from a Yukon 52cc chainsaw
You turn the clutch clockwise. There should be an arrow on the plate. As always be gentle. GOOD LUCK FRIEND.
Sep 21, 2014 | Garden
I just bought a used 350 husqvarna chain saw fires up n stalls right away put new premium gas in it
Start with a few simple things, replace the fuel filter in the fuel tank, check the fuel hoses for signs of leakage, replace if required.
Dec 22, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Stihl brushcutter [four stroke] wont rev.
Check the valve clearances, remove the rocker cover to expose the tappets. Adjustment tools can be bought online or from your local dealer.
Jun 18, 2012 | Stihl String Trimmer Brushcutter Service...
I have a husqvarna 350 that wont start, wondering if anyone can tell me what is the factory compression rating?
Hi and welcome to FixYa, I am Kelly You should have 120 PSI or greater compression. There is a ported compression release so you may see as little as 110 PSI but it is best to see 120 or greater.
The Owners manual is here:
http://www.northerntool.com/downloads/manuals/195946.pdf
carb basic settings are on page 29 of the manual.
The saw has a Zama C3-EL18 carb.
The manual for the carb is here:
http://www.zamacarb.com/pdfs/TechGuide_2007.pdf (Click and wait 2.50 mb)
Your carb is the C3
The workshop manual for the saw is here:
http://www.scribd.com/doc/8152011/Husqvarna-Chainsaw-Workshop-Manual-340345346XP350351353 (Must have a facebook account to download but can be viewed online)
Thanks for choosing FixYa,
Kelly
Sep 23, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
I detached the pole and cannot figure out how to reattach it. The online manual does not show any instructions for this
the pole will go back on but you may have to twist it or maybe look and see if theres a groove it fits in
Jul 29, 2009 | Remington Electric Pole Saw
How to attach chainsaw to pole
I am not sure what model number you have, but here is a link the owner's manual for model # 106821A ... http://12.153.20.74/manuals/111219-01B.PDF. On page 15 of this owner's manual explains how to attach the pole to the saw. Just make sure you are attaching the saw that is made to fit the pole or it may not work or be to heavy for the pole. I hope this helps.
Jun 06, 2009 | Remington Polesaw Wizard
Looking for user manual for McCulloch 10'' Electric pole saw
hello i found a printable version of the product information on the mcculloch web sight for your 10" electric pole saw here's a link to it so you can print out the product information http://www.mccullochpower.com/node3829.aspx?pid=85295
Mar 27, 2009 | McCulloch 10" Electric Pole / Chain Saw
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
