Question about Vidal Sassoon Sassoon Vidal 1875 Watt Hair Dryer
Is it universal volt - Vidal Sassoon Sassoon Vidal 1875 Watt Hair Dryer
  • 3,961 Answers
It is not listed as such. You should not plug a 120VAC unit into 240VAC.
Posted on Dec 03, 2013
Hi.why my zoom g1x has no power.im using a universal adator...i am in phillpines.power volts here..220 volts.how is the setting of my adaptor then?
I have a ZOOM GX1XN and it doesn't like universal adapters much. Using one with the wrong voltage or polarity may permanently damage your pedal. Try to obtain a proper ZOOM AC adapter (part number AD-0006 or AD-16) if possible. These are dual voltage and will work equally well with both 220 and 110 volts. Failing that you need an adapter that will give a DC (direct current) output of 9 volts at 0.5amps - maximum 4.5 watts. The outer contact (sleeve) of the adapter needs to be positive (+ve) and the inside contact negative (-ve). Lots of universal adapters are the other way around with the sleeve being negative - but some have a multi-connector on the end with both positive and negative sleeves.
Jan 08, 2011 | Zoom G1x Guitar Multi Effects Pedal with...
What the differential betwen LC and UB type battery, for example LC-X1220P and UB12220. thanks.
Specs Volt 12 Amps 22 Length 7.13 Width 3 Height 6.57 Terminals NB Weight (17.5) Manufacturer Universal Power Model # UB12220 Universal 12 Volt 22AH Battery UB12220 Universal 12 Volt 22AH Battery
Specs Volt 12 Amps 20 Length 7.126 Width 2.992 Height 6.575 Terminals NB Weight (14.56) Manufacturer Panasonic Model # LC-X1220P Panasonic 12 Volt 20AH BatteryLC-X1220P Panasonic 12 Volt 20AH Battery
Dec 28, 2010 | Panasonic LC-X1220AP - UPS battery - 1 x...
My original ac adapter for my psp burnt out I bought another adapter (universal) and after a couple minutes that one burnt too.Whats up?
its because your not suppose to use universal!!! my cousin has a universal and it takes for ever to Charge the charger was probably to weak for example the psp's charge is suppose to be 5 volts and the charger was probably 3 volts so the poor charger coulnt handle it and burned... try getting a new batterie. and a good charger
Apr 10, 2010 | Sony PSP (Piano Black)
Main breaker one side "24." Amp other side "10.3" Amp
Please clarify if it's a boat, RV or a home breaker
Do you have a manufactures name?
Just looking at the data you gave It's a 24 volt 10.3 amp breaker that is used on anything other than a home appliance
I don't know if it's 24 volts AC ,24 volts DC or a universal 24 volt breaker
Oct 08, 2009 | Electrical Supplies
Battery
You can get an universal AC Adapter such as the one sold at Radio Shack. The specifications should be 9 to 12 volts and at least 800 miliamps with the center tip being positive - this is reversible on universal adapters. A decent adapter should cost between $10.00 - $15.00.
Make sure that you plug in the charger on the battery pack, not on the 12 volts input from the PD-3070 - This is use only to power up the player, it won't charge the battery.
Good Luck.
Nov 20, 2008 | Astar PD-3010 Portable DVD Player
I have a CMZ984 coleman portable rechargeable bug zapper.I have lost the manuel and charger for it.It is 4 watts.The company that made it for Coleman has gone out of business.It is about 2 years old.What...
The CMZ984 takes 6 volts DC at about 850 ma or 0.85 Amp. The problem is finding a plug that will attach to the Coleman charging port. Use the Radio Shack universal DC power supply. This is a little unit that comes with an assortment of plugs and has a number of switches on the Radio Shack DC power supply. (1)-Find a plug inside of the Universal DC power supply that fits without forcing, (2)-set the voltage to 6 volts and (3)-the polarity to "+". When the universal power supply is plugged into the bug zapper and the universal DC power supply set at 6 volts, turn on the BUG ZAPPER. If the lights inside turns on when the battery is dead then you probably have all switches set correctly. At yard sales, this UNIVERSAL power supply sells for about $1. It comes with a number of different plugs. Don't forget to write the voltage and polarity on the bottom of the bug zapper for the next time.
Jul 29, 2008 | Kitchen Ranges
Vidal Sassoon Sassoon Vidal 1875 Watt Hair Dryer Logo
60 people viewed this question
Top Vidal Sassoon Health & Beauty Experts
Anglia Clipper...
jasiel murphy
Jerry Greenberg
Jerry Greenberg
Are you a Vidal Sassoon Health and Beauty Expert? Answer questions, earn points and help others
