Question about SCOSCHE reVIVE Dual USB Home Charger Power Supply
Open scosche switching power supply - SCOSCHE reVIVE Dual USB Home Charger Power Supply
I have a older square black scosche speaker how do I turn on the pairing it to my phone
How to pair the boomBOTTLE+ portable speaker ' Scosche
www.scosche.com/.../how-to-pair-the-scosche-boombottle-portable-spea...
Sep 16, 2015 - How To Pair The Scosche boomBOTTLE+ Portable Speaker ... Turn on your device's Bluetooth Menu to search for and connect to the boomBOTTLE+. ... only one speaker, place the speakers in "S" (stereo) position and turn off ...
Scosche ' Products by Scosche
www.scosche.com/blog/
Jan 01, 2016 | SCOSCHE Car Audio & Video
Scosche SCDBTA60A when hooked up to the wiring in my truck will not power on the head come on when first plugged in and then shuts off
Believe me that is only the start of your problems, the unit is one of the most disappointing things I have ever bought, it doesn't work using a memory stick either using the buttons or the app it needs a complete rewrite of both firmware and software and Scosche tell me they are not rewriting either so tough luck!! Check other forums for other opinions but whatever you do don't buy it.
Mar 17, 2014 | Scosche Industries Car Audio & Video
Hey i have a scosche in-line fuse block i purchased. I haven't had any problems until recently. My fuse fried. So i bought more and went to replace it and every fuse i try instantly fries. i cant seem
Most likely the amplifier you have hooked up to that fuse position is defective and causing the fuse to blow. Or you have a short in the powerline somewhere. Disconnect the power wire from the amplifier, tape up the end so it won't short out to anything. Replace the fuse, if it doesn't blow then you will need to get the amp checked, if it does blow, then you have a short somewhere along your power wire.
Jan 30, 2014 | Scosche Industries Car Audio & Video
I have a scosche ipod connector with an on/off switch on 03 accord but i cant get the stereo to change to aux mode. I repeatedly hit the cd/aux button but it won't switch to aux mode and play mu
Have you tried resetting the stereo?
Disconnect the negative of your battery, wait at least 30 seconds then re-connect it.
That will reset your radio back to factory settings.
Feb 08, 2012 | Scosche Industries Car Audio & Video
Scosche amp and subwoofer not working
Be sure you have 12 volts on the remote wire. Fuse power for amp is switched using the REM (remote) wire.
May 30, 2010 | Scosche Industries Scosche High...
I cannot find the
use your handy dandy test light. it's the easyest way. pretty cheap at autozone. remember, you will have one at 12volts constant, if you can't find one on the connector, tap your cigarette lighter. next turn on the key and find the switched 12volts and make sure it's the right one by turning power on and off. turn the lights on and off just to make sure you didn't get the illumination wire.
Apr 01, 2010 | Scosche Industries Scosche Gm05b Wiring...
Scosche EFX work with MOS-FET Amplifiers
CAN YOU E-MAIL ME THE MANUALS FOR THE VOLFENHAG ZX 7150 AND THE ZX 7170 MY E-MAIL IS smas5305@yahoo.com thank you Thomas Anderson
Mar 22, 2010 | Scosche Industries EFX Amplifier Wiring...
SCOSCHE reVIVE Dual USB Home Charger Power Supply Logo
Top SCOSCHE Computers & Internet Experts
David Payne
David Payne
Are you a SCOSCHE Computer and Internet Expert? Answer questions, earn points and help others
