Question about Car Audio & Video
Profile baja b200
Protection light on
How do I run a head light to my 2007 Baja dirtrunner? No battery.
Hi, Michael the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Baja Dirt Runner 125 adding lights
How to install led headlight on dirt bike with no battery
Baja Motorsports Parts
http://bajamotorsports.com/parts_catalogs
Baja 49CC DIRT RUNNER Owner Manual
Sep 22, 2017 | 2007 TN'G Baja 150
Why the cartridge does not move when the printer is on. and when i set to print error no. B200 appear?
http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#b200
B200 Error- This could also be displayed as P10 or the orange and green light blinking 10 times Description:
B200 is a service error that can occur due to a hardware failure with either the printer or the print head.
Resolution:
In most instances, a B200 error will require a repair at a Canon authorised repair centre, however prior to sending your printer for repair please follow the steps below to try and resolve this error-
  1. Turn off the printer
  2. Disconnect the power cable
  3. Open the printer cover
  4. Check for any orange protective tape or white polystyrene and remove if necessary
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary
  6. Close the cover
  7. Reconnect and turn on
If the error message is still showing, then it is necessary to deliver or send the printer to an authorised repair centre.
If the printer is still under warranty, (generally one year from purchase) and supporting documentation is provided, then a free of charge warranty repair will be carried out.
If the warranty has expired, then any repairs can only be carried out at cost and charges will apply.
You can find the details of your nearest repair centre using our interactive repair centre locator.
If you own a PIXMA PRO-1 please contact us directly as you may be eligible for an on-site repair.
Jan 14, 2016 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
Canon MP276 show a error number B200. how i solve it?
FIXED: Canon Printer Error B200 With 5 Different Solutions ...
? 3:33
www.youtube.com/watch?v=LZELHKjVZAY Mar 18, 2014 - Uploaded by ITJungles Five different solutions you can try to fix the Canon printer error B200. Is your printer playing up and not doing ..
Jul 22, 2015 | Canon Office Equipment & Supplies
Error b200
A service error has occurred.
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, the device needs to be send to service for repair.
Mar 26, 2014 | Canon Pixma iX6520 Inkjet Printer 4895b002
The protection light is on in my baja200
the ground might be bad make sure its thick as power cable and is touching bare metal
Mar 09, 2013 | Profile BAJA HA700M Car Audio Amplifier
My baja car amp keeps poping fuses
due to a short you have fused two things together.try doing a continuity test between things that you know arent supposed to be conducting. like the connections near the fuse and where you connect the power, remote,ground wires
Apr 11, 2010 | Profile BAJA HA700M Car Audio Amplifier
My sub flickers on and off in my truck!!!
could be a number of things loose wires bad ground fuse on its way out or internal problems
Feb 13, 2009 | Profile BAJA HA700M Car Audio Amplifier
How to replace low beam bulb on 2004 baja
I was able to locate an owners manual for the vehicle. The large plastic weatherguard protecting the headlight bulb connections needs to be rotated CCW about 90 degrees, and removed to provide access to the bulbs. Then remove the center connection for the low beam and release the spring clip retainer to release the low beam bulb. Replace with new bulb and reconnect/reinstall retainer clip, center connector wire, and weatherguard. Note that this is the procedure for the Turbo Baja...non-Turbo model is different.
Jan 02, 2009 | 2004 Subaru Baja
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
