Question about Dell (E210882) Motherboard
Front panel hook up
I have e210882 motherboard that i want to put in a coustom tower now my problem is that i dont know what pins to connect the front panel to. all my lights and switches are on seprate wire bundles and the motherboard has a connection that resembles a small ide ribbon connection. i need to know what pins are what so that i dont fry my board
  • Anonymous Mar 13, 2014
    connection diagram.
  • 188 Answers
Posted on Oct 10, 2007
I am looking for the mother board connection diagram so i can connect the towers front panal ie power switch /reset ect
Connect the front panel leads to the motherboard connector marked "JFP1" using the following pins as indicated by the markings on the motherboard and the front panel leads: HDD LED on Pins 1 and 3; power LED on Pins 2 and 4; reset switch on Pins 5 and 7; and the power switch on Pins 6 and 8.
Good luck.
Mar 03, 2011 | MSI 865GM2-LS Motherboard
E210882 socket type 775, PCIe, DDR2 - Will not turn on
On the Dell board, the
CORRECT pinout for J8H1 is as follows:
1-3: HD LED (#1 is +)
2-4: PWR LED (#2 is +)
6-8: RESET
5,16: +5V
10,11,14,15: not connected
12,13: GND
Jul 27, 2009 | Dell (E210882) Motherboard
I am putting my e210882 motherboard in to a computer case an need to know wiring specs for the front panel
Here is the link to your motherboard manual.
This will give you 1/2 what you need. You will meed to have the case manual to.
Jul 10, 2009 | Dell (E210882) Motherboard
Power connections for tower led's
The manual in question can be located here
It is a pdf file, so you will need ADOBE,
I have checked and the pinout for the front panel connectors is there.
May 24, 2009 | Intel D945GTP Motherboard
Is It required to connect Tower Front Panel I/O to Motherboard
The power button on the front panel would definitely need to be hooked up to the motherboard so you can power up the computer.
If you have any usb slots or a media card reader on the front panel, or both, then you would need to hook those up as well, otherwise the main one you need to connect would be the power button.
May 23, 2009 | ASUS P4V8X-MX Motherboard
The only front panel pins you need are for the power switch. Track them from the front panel to the connector and plug them upto the 2 pins for power. Dont worry about polarity it can go either way. The connector may look a little odd but it will work just fine. In the past in that situation I have cut the plastic in such a way I have separated the different connections but its not worth the trouble in my opinion.
May 06, 2009 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Need proper wiring for the J9C2 connector pinout
The User Manual for this m/board (E210882) can be found at :-
you will need adobe free reader to view it. refer to pages 40 thru 46 for the front panel header and isb info.
Apr 01, 2009 | Dell Dimension 4600 PC Desktop
I am trying to hook up front panel usb ports.
check out this diagram i think it might help you
or if the link is unavailable then here is the same info
pins 1,3,5,and 7 are one usb connection
pin 1 = +5V
pin 3 = D-
pin 5 = D+
pin 7 = GND
pins 2,4,6,and 8 are another usb connection
pin 2 = +5V
pin 4 = D-
pin 6 = D+
pin 8 = GND
pin 10 is not used
Dec 04, 2008 | Intel Motherboard
Front mic port and headphone
to connect your front panel header you must refer to your motherboard manual ...
it will given in detail with the pin diagram how to connect ....
check the motherboard compatibility some motherboards dont support working of the back panel header and front panel header at same time especially the old motherboards ....
almost all new motherboard supports working of both the panel headers at the same time if the motherboard supports multi streaming...
thank you
any doubts you can reply me
i am always here to assist you
rate my solution
Aug 06, 2008 | Computers & Internet
Cant connect power swuitch
one of the pins will alway be marked in very small print
its where you have all those pins to connect to.
Feb 02, 2008 | Intel Motherboard
Dell (E210882) Motherboard Logo
817 people viewed this question
Alun Cox
