Question about Frigidaire FFBD2406NS Built In Dishwashers
Cycle won't start and I can't choose any other cycle options, green normal light is on but buttons don't beep or work.
Hello friend, thank you for your post!
I understand that the light on your Frigidaire dishwasher is lit as it normally is, except it will not operate. It is possible that your dishwasher may have an issue within the keypad or control panel. You can perform a reset, in the case that it is a miscommunication error within the dishwasher. You can reset the dishwasher by flipping the household circuit breaker off for at least ten minutes. If this does not help correct your issue I would recommend seeking assistance from a professional technician for a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Posted on Dec 04, 2015
SOURCE: "Clean light" keeps blinking; dishwasher won't start new cycle
Check to see how it's loaded. If something is obstructing either of the spray arms it will not start. I had this same problem and checked to see if there was something impeding the arms - I found there was. Reloaded the unit and it's running like a champ now!
Posted on Feb 09, 2008
SOURCE: Problem starting fridgidaire model FDB1050REC2
hello kwill8
welcome to Fixya.
You said, You just installed the dishwasher and the only cycle it will go through
is the rinse cycle. When You turn the dial to any of the other cycles:pots&pans, normal, light wash and upper rack, the start button
as well as the heat dry button and the high temp button do not work.
only button that will light up when pressed is the delay button. How
can you fix this?
Is this your model FDB1050REC2This is a brand new model and you said you just installed it!
If it is brand new!
You do not have to fix it.
You have a full years warranty, parts and labor!let them fix it no cost to you.
The first thing they will do, . You can do your self!
Go to the breaker and turn it off for 5 minutes and then on again. This should reset the system and this usually is the end to most bad starts!
try it!
Huuum
Posted on Oct 03, 2008
SOURCE: My frigidaire dishwasher will not turn on.
How can I burn a cd on another?
Posted on May 13, 2009
SOURCE: Frididair GLD2250RDC0 The lights on
Sounds like the very common control panel issue. They have a tendency to short out due to overheating. It is possible it is the motor is bad, you can test power to motor with a voltmeter. If no power, then try power from control panel to motor. If there is power to motor, than motor is bad.
Posted on Dec 04, 2009
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
Same thing happened - couldn't do anything - was completely "locked"...tried the breaker reset and it worked immediately. Thank you for sharing the answer!
Posted on Jan 10, 2010
Nov 26, 2015 | Washing Machines
Nov 25, 2012 | Washing Machines
Aug 02, 2012 | Whirlpool Dishwashers
Jun 18, 2012 | Kenmore Dishwashers
Sep 06, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Jun 29, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Nov 19, 2017 | KitchenAid 24 in. KUDP02FR Built-in...
Jun 21, 2009 | Whirlpool Dishwashers
Feb 07, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Oct 15, 2007 | Epson AcuLaser C900 Printer
337 people viewed this question
