Question about Carrier Heating & Cooling
Carrier model 38ce004300 - Carrier Heating & Cooling
Compressor capacitor carrier model #50SS060-311
What you'll need to do is contact a Carrier dealer with the product, model, serial numbers. Or get the compressor model number and call a good dealer for that make of compressor.
Mar 31, 2017 | Carrier Heating & Cooling
I need a contact or for a carrier ac model #38en036320 but can't find the part#
You need to contact carrier customer service online or locally.
Aug 23, 2016 | Carrier Heating & Cooling
What is the weight limit for the Snugli baby carrier blue plaid model 26L5001?
Weight limit for the Snugli baby carrier blue plaid model 26L5001 is 26lbs. Though you can check its manual or their official site to confirm it or you can contact their customer care center. You will easily find out their number online on google. Baby Shop Melbourne Cheap Baby Cots Melbourne baby direct com au
Sep 23, 2014 | Evenflo Snugli Front & Back Baby Carrier
My carrier bearing is bad in my 96 firebird and I can't find another anywhere. No one has heard of a 2 part driveshaft in my car. Can I replace it with a solid driveshaft? Or do you know where I can find a...
If you mean the carrier bearing on the driveshaft - then you must have a v6 model. I would advise to skip replacing it and instead purchase a 1pc shaft (no carrier bearing). The cb is located near a Hi-Speed CV Joint which make changing the carrier a little difficult.
A new replacement 1pc driveshaft costs about $225.00
The carrier bearing itself may run $40-$140. ( http://www.fortwayneclutch.com/index.php/driveshaft-parts/carrier-support-bearings/gm/1993-2002-chevy-camaro-v6-pontiac-firebird-v6-carrier-bearing-new-f-body-carrier-bearing-for-v6-models-pn-s-3r80-40.html ) - for reference...
You could also check a junk yard for a 1pc oem shaft (most shafts there are bent or have bad uj's and will cost $$ to have fixed )
>1994-2002 f-body models all have the same length from the seal of the transmission to the center of the uj @ the diff.
>when looking for an oem 1pc shaft you will find them in Steel and Aluminum. Slight differences in length when measuring center to center of the universal joints ( 40 7/8" - 40 1/2" ) - but the slip yokes vary in length, weighted / non-weighted..etc = this will make it appear the the shafts are different.
>>watch out for oem shafts with the weighted slip yoke from manual 6spd v8 models. This slip yoke may hit the trans/exhaust mount that is used on v6 models.!!
Jul 22, 2012 | Cars & Trucks
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
What is the hold up cooling water capacity and hold up capacity of chilled water in carrier make chiller having sr no XR3J1619,model no-19XR4747377KFH52?
Go to this site:
http://www.corp.carrier.com/Carrier+Corporate+Sites/Corporate
Under "home and comfort" choose your region then see if you can find it. If not Carrier has a contact us / site map link. Be advised that it can take 1 to 4 days for a response.
I tried looking up the model number you submitted 19XR4747377KFH52 and came up with nothing.
I am sure that Carrier can help you. It is a matter of making sure the Model numbers are correct and that you use the correct region.
My experience with Carrier is that you can ask Carrier North America a question and they say they can not cross the model number... but, if I go to another region all of the sudden they have the answer.
Kelly
Sep 25, 2010 | Carrier Refrigerators
I have a Carrier model 38ycc048320. Does anyone
On Carrier.com. All units are listed there. You can call your local Carrier office and they can get that for you as well
Sep 28, 2009 | Carrier Heating & Cooling
Is parkway receiver mount bike carrier right for mercedes s320
hi,better to consult your dealer,if your model can fit your bike carrier,dealer have a special equipment manual for every mb model
Mar 22, 2009 | 1999 Mercedes-Benz S-Class
Heating & Cooling Logo
43 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
