Question about Apple iPod nano
From i-pod to i-tune
I charges my i-pod with i-tune (win XP) so i want return this s?lection to i-tune but is not possible. All over the folder or librairy i got the big "O" with a slash in to show that it is not acceptable. So how can i return this s?lection to a folder ?
  • 3 Answers
I have done this with windows explorer and manually copying selection to the folder with itunes in it. Usually in your documents and settings/user/documents/mymusic folder or something similar. You can find out by checking the options or settings in Itunes and the folder it looks for.
Posted on May 04, 2008
I changed computers and from win-8 to win-10 and can no longer access my I-pod / I-tunes library. How can I reconnect so I can put new music onto the I-pod?
This is a common complaint and computer manufacturers do not recommend the 10 upgrade that was offered for 7&8 system users because of loss of functions issues just like this.. Reload the software from the Apple support site to fix this, hop it works.
Mar 02, 2017 | The Audio Players & Recorders
My ipod wont show on the computer but will charge?
If you want the i-pod to,I hope you have I-tunes software and a cable for your I-pod.
Of you don't have I-tunes, you can install i-tunes from I-tunes website
You can get a detailed information on how to put song on your
i-pod from the link below.
I wish you good luck.
Mar 17, 2010 | Apple iPod shuffle MP3 Player
Humax pvr can not read my maxtor 500gb harddrive why is that?
1)allows access local to w2k w2k3 XP win NT4 with SP4 & later may get access for somefile.
2)Maximum size of partition is 2 Terabytes & more.
3)Maximum File size is upto 16TB.
4)File & folder Encryption is possible only in NTFS.
FAT 32
1)Fat 32 Allows access to win 95 98 win millenium win2k xp on local partition.
2)Maximum size of partition is upto 2 TB.
3)Maximum File size is upto 4 GB.
4)File & folder Encryption is not possible.
I hope this clears things up for you
Mar 08, 2010 | Maxtor Hard Drive
"Lost" all USB ports on win xp laptop after plugging ipod shuffle
go into the system restore and choose a date when the usb ports were working then let it go thru its process of restoring. It will restart and then test the usb ports then, if you still can't get them to work then that means the motherboard is bad.
Jun 30, 2009 | ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI...
Is there driver/ software for Win ME for the Sansa Clip mp3?
a friend told me that if the device shows as"connected" when hooked up (it does) AND the battery charges correctly (it does), then (a)the USB connection had enough juice; and (b) the PC recognizes it - i just had to FIND it. device manager/ MyComputer: nada; same for ANY file/ folder with "sansa" or "sandisk." working thru WMP (Windows Media Player), however, I discovered that drive E - for a portable hard drive, NOT currently connected via USB - was STILL showing up in the "Copy to CD or device" field. sure enough, it was the SanDisk clip player (even though it was NOT under the "Recognized Portable Devices" subsection). without using the installation disk at all, it downloaded tunes just fine. *note: the installation disk seemed to be an .exe file ONLY for the Rhapsody music service. as noted above, it was unnecessary. also - my USB ports are 1.1 and not 2.0, and package stated USB 2.0 was a "minimum requirement" - not true*
Jun 17, 2009 | SanDisk Sansa Clip MP3 Player
Task manager in win xp keeps blinking, it will not closed, no matter what i push nothing, plus win xp keep freezing any solution how to fix this problem
VIrus infection?
to check and secure u need:
win-xp cd or other bootable win-cd, seperate up-to-date antivir software on cd or usb-stick,
your passwords
boot system from cd/dvd (do not bother if screen resolution is different from usually),
exit windows-setup,
insert antivir-cd or stick, run full system scan.
found infections? remove/erase these files(antivir will do that for you)
if possible, back-up personal data (my folder, music, save games, etc.)
this data has to virchecked by another protected system before reinstallation !
boot from win-xp cd-rom, run setup until repair options are available,
repair your xp on harddisk(xp-will do that mostly), exit setup without installing win xp anew
boot system from hd, ignore error messages, run vircheck again.
if you're lucky, this will do, else lemmie know
Jun 13, 2009 | Dell Inspiron 6000 Notebook
New i/pod for xmas, charged it up but no instructions how to load
Just visit and download iTunes. When you run iTunes and have your iPod plugged-in, you will see your iPod in the left window pane of iTunes. You can drag your music from folders on your computer, and drop it on the icon of your iPod. You can also use the library in iTunes to manage your music, but I have always preferred dragging directly on the iPod as I mentioned above.
Jan 16, 2009 | Apple iPod touch
Your library needs to be rebuilt to version 8.0 before ITunes will work. Once the database is rebuilt, your songs will reappear in Itunes for use.
Give Itunes the library that your files are in using the folder options. Itunes will rebuild the library off of those settings.
Backup your purchased songs asap.
Dec 02, 2008 | Apple iPod nano
Ipod not recognized by computer or itunes
I don't have an i pod icon on my I tunes how do I get it
Jun 12, 2008 | Apple Mini IPod
Ipod nano problem
hello blair,I Have my own I-pod so I hope this will re asure you. First I think you should restore your I tunes as long as your brother has your songs too. Then ask him to create a CD of all your songs, which is not hard at all. then take the CD and open I-Tunes. Place the CD into your hard drive and I-Tunes should pick up the CD. Then download the content of the CD onto I-Tunes. You Will Now have all your songs on I-Tunes like before. Now plug in your I-Pod and continue like It's the first time you have pluged in your i-pod! hope this helps! Rosebetts xxx
Dec 29, 2007 | Audio Players & Recorders
Apple iPod nano Logo
27 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
