Need Hacker Sovereign 2 RP25A circuit diagram
I need part for my air conditioner
since an AC has many parts, I would recommend going to the manufacturers website for a parts diagram and listing.
May 03, 2015 | Royal Sovereign ARP-1003E 10,000 BTU...
Totally useless manual on the sovereign
I'm sorry that you are having problems with the manual for your Sovereign AC unit. If you have any questions you need answered about your ac check us out at Air Conditioning Boca Raton
Mar 03, 2015 | Sovereign Heating & Cooling
Hot Spring Spa pump won't run just click on circuit board....
Check for voltage at the pump, before assuming the relays are out... then check for voltage before and after the relay contacts
Apr 08, 2010 | Pool & Spa
Royal Sovereign not keeping the room cool.
electronics give off alot of heat you need larger unit
May 19, 2009 | Royal Sovereign ARP-4009 Portable Air...
How many watts does an ARP-3012 draw?
Assuming you are in the United States....
This unit should work fine on a 15 amp circuit assuming there aren't several other loads on the same circuit.
You didn't say what the BTU was for you unit, but there are about 3.41 BTU's per watt. Multiply the btu rating of your unit by 3.41 and then divide by 115 or 120 (your house voltage in the U.S., use 220 for Europe) and that number is the amps.
Apr 07, 2009 | Royal Sovereign ARP-3012 Air Conditioner
55 people viewed this question
 Grubhead
Grubhead
