Question about Pride Jazzy 1103 Ultra Indoor Power Wheelchair
How do you replace battery in Jazzy 1103 - Pride Jazzy 1103 Ultra Indoor Power Wheelchair
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
Take the seat off and take off the cover over the batterys and then
write down diagram of current wires on batterys and then change batterys and return cabes as to your wring diagram and reverse the first steps
Posted on Jan 19, 2014
dromtonpa
  • 40 Answers
SOURCE: problem with joystick on Jazzy 1103 ultra
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
Posted on Apr 01, 2009
  • 175 Answers
SOURCE: where do I find a wiring diagram for the jazzy
Here's a link to the Pride Tech Manual guides. Click on the 1103 for a PDF file.
http://www.prideservice.com/TechnicalProductGuides/technicalproductguides.asp
The wiring is pretty simple and straightforward. These operate on a 24VDC system provided by two 12VDC batteries. Power from the batteries goes to the controller into a Joystick/controller combo. It leaves the joystick down to each motor/gear/brake assembly. Power to the batteries comes from the charger which puts out 28VDC, with a 120VAC input. Very rarely does any of the wiring go bad excepting those people who grossly overload the chair, or run it into fixed objects at full speed. Other mishaps with overamping are caused when somebody tries driving over unstable surfaces like sand, gravel, mud/wet grass and spin the motors. This drives the controller crazy because its job is to keep the chair pointed in the right direction, and with wheels spinning, it doesn't know what to do. Overheating the motors or controller, or both. There are two sets of "brushes" on each motor that carry the current from the batteries to the motor. These are located under a black-plastic slotted screw port at the ends of each motor. Removing the plastic screw reveals the brush. It should have a flexible semi-copper lead that shows no evidence of overheating, or brittleness, and should be about 3/4 of an inch long. If 1/4 of an inch, it should be replaced. Check all four. Good luck.
Posted on Jul 11, 2009
  • 175 Answers
SOURCE: Replacing battteries in Jazzy 1103 power chair
Here's a quick link to the owners manual for the 1103 that will show you how to replace the batteries on your chair.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_1103_Ultra_om.pdf
Posted on Oct 22, 2009
  • 103 Answers
SOURCE: The battery on the Pride Jazzy 1103 will ot take a
Have the batteries load tested. If they have sat to to long then they will need to be replaced.
Posted on Dec 16, 2009
  • 5 Answers
SOURCE: i need the pinout of the jazzy 1103 ultra battery
The Output voltage 24 - 29v ,Usually 27v. (And 4 Amps)
The Pin arrangement is Negative to the Left, Inhibit in the Middle, And Positive to the Right Assuming your looking into the plug itself from the front.
Always check with a Voltmeter first though because there are some chargers with the Opposite Pin Arrangement.
Posted on Jan 28, 2010
Reset button
While replacing the batteries you may have bumped the brake releases. Release both and return them to the operate position. It is also possible to get one or both batteries backwards. This is a 24 volt system so pay close attention to the color codes on the cables. Be careful of shorts.
Nov 06, 2013 | Pride Jazzy 1103 Ultra Standard Power...
Best battery for 1103 jazzy ultra
MK batteries and/or interstate batteries are top quality. you get what you pay for cheap batteries are manufactured cheaply.
Aug 01, 2012 | Pride Jazzy 1103 Ultra Standard Power...
The battery light flashes and the chair wont go.
Sounds like it might be time to change the batteries. Even if batteries are charged correctly they eventually lose power with use and need to be changed. Here is a link to the battery needed for the Jazzy 1103 Ultra http://www.replacementupsbattery.com/UB12350-NB.html
Oct 31, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Y mom's jazzy 1103 ultra will not operate .
Make sure motors are in gear. Unplug from wall then try to turn on.
Jun 26, 2010 | Pride Jazzy 1103 Ultra Standard Power...
I need the pinout of the jazzy 1103 ultra battery
Dec 11, 2009 | Pride Jazzy 1103 Ultra Standard Power...
Nov 22, 2009 | Pride Jazzy 1103 Ultra Standard Power...
Oct 22, 2009 | Pride Jazzy 1103 Ultra Indoor Power...
Problem with joystick on Jazzy 1103 ultra
Apr 01, 2009 | Pride Jazzy 1103 Ultra Indoor Power...
Pride Jazzy 1103 Ultra Indoor Power Wheelchair Logo
106 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
