Question about Dryers
Clean condenser how to clean
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Genaraly you can remove the condenser and wash it with flowing water
Posted on Nov 22, 2013
Runs louder after cleaned condenser unit
The filthy condenser unit was also acting as a sound absorber. Now that the "absorbant" has been cleaned ..........................
Aug 05, 2015 | Refrigerators
Tip
Condenser Coil Cleaning Condenser Coil Cleaner
One of the most important things to maintaining a highly efficient Air Conditioner is keeping the condenser coil clean. To make your condenser coil cleaning as easy as possible you need to know what to use to clean your coil.
There are a number of different things that can be used to clean your condenser coil. It does not matter whether you are cleaning a central air conditioning unit or a window air conditioning unit. What does matter is the type and location of the coil and the amount of dirt that is in the coil.
When looking at the type of coil cleaner to be used, make sure that the chemical being used is compatible with the type of metal that the coil is made out of. Some chemicals and certain metals do not get along well and should be avoided.
Also, if you condenser coil is severely plugged then a foaming type coil cleaner is a must have item. If the condenser coil just needs to be washed down and is not completely plugged then a mild detergent may be just the tool needed to do the job.
For many units that have regular cleanings, a good quality detergent similar to what you use to wash your car, will work just fine. The main object of the cleaning is to remove the dust, dirt, and grime from the coil to promote better air flow through the coil. If the coil is just plugged with grass or dandelion seeds them a simple hosing off with the water hose may do the trick.
If a foaming cleaner is need to clean a neglected or very dirty coil then look up your local heating and air conditioning supply house and purchase a coil cleaner specifically for cleaning condenser coils. Most of these products are for professional use only and care is needed when using and handling these products.
Condenser coil cleaning can be done by the homeowner if proper care is taken and it will keep you air conditioning unit running great whether it is a central air conditioning unit or a window air conditioning unit. Once you know what to do and how to do it you may find that you will be cleaning your condenser coil a number of times a year to insure top performance from your unit.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
on Jan 10, 2010 | Heating & Cooling
Tip
Air Conditioning - Cleaning the Condenser Coil
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Air Conditioning works by exchanging heat from inside a building to the outside air. To do this some very basic refrigeration principles need to take place. One of the most critical pieces that make this happen is the condenser coil. This is usually the aluminum coil the surrounds the air conditioning compressor.
What happens inside this outdoor unit is a very basic state change of the refrigerant inside the air conditioning unit. The refrigerant that changes from a liquid to a gas inside the indoor coil moves to the outside where the compressor compresses the gas under high pressure. When this happens the gas also becomes very hot. The hot gas then leaves the compressor to start traveling through the many feet of tubing in the condenser coil. As the gas cools it changes back to a liquid form going back indoors to start the cycle all over again.
Big problems start when the condenser coil becomes so blocked up with dirt that the hot gas in the condenser coil does not cool enough to change the hot gas back to a liquid form. If this happens the cooling process does not happen and then air conditioner runs but is not cooling. The compressor starts to get very hot and the ultimate result will be the death of a compressor. For these reasons the condenser coil must be kept clean and free of debris at all times when the air conditioner is running. Cleaning the coil is a fairly simple process, Here are a few guidelines to follow when doing this.
To clean the coil a few simple tools are needed. A garden hose with a nozzle, wrenches to remove the condenser fan, a garden sprayer for applying the cleaning solution. The first thing is to disconnect the power to the outdoor unit. There should be a disconnect switch of some type near the condenser. Then remove the fan from the condenser unit. Usually this will be the top of the unit. The fan can usually be laid aside carefully without disconnecting the wires to the motor. Carefully wet down the coil with the garden hose. If you have very high pressure water where you live be careful that the water pressure does not bend over the fins on the coil. These are very thin and fragile. If they get bent over the air will not be able to freely flow through them. Using the cleaning solution from the garden sprayer, coat he inside and the outside of the coil. Let the solution work on the dirt build up before washing it off. If you use a foaming type coil cleaner then let the foam cook the dirt out of the coil. Then use the garden hose to wash the dirt out of the coil. I often work from the inside spraying out through the coil. This is the reverse of the usual air flow and it washes the dirt out easier. Rinse the coil with water till it is clean with no more dirt or cleaner coming out. Replace the fan and start the unit back up.
The cleaning solution for the condenser coil can be any good household cleaner. Many automotive type radiator cleaners will work well. For very dirty condensers it would be good to buy a foaming coil cleaner made specifically for cleaning condenser coils. A local plumbing and heating supply house should stock coil cleaning solutions. Most of these solutions are very strong chemicals. Be sure to wear gloves and eye protection when working with them.
By keeping your air conditioning condenser coil clean, you will help to have your air conditioner running at the best efficiency possible. A clean condenser coil is one of the easiest ways to save electric while running your central air conditioning system. A clean coil will allow your compressor to run cooler and help it to last longer. Your condenser coil should be thoroughly cleaned at least once a year. If in you live in very dirty areas like along a dirt road you may need to clean the condenser coil more often. Also do not do things that would clog up the coil. Blowing grass clippings into the condenser coil is one common thing that happens. Keep shrubbery from growing into and around the condenser coil. This stops the air flow to the coil. Large flowers planted too close to the coil can do the same thing.
As you can see there are many things that can cause your air conditioner to work harder and cost you more money. By taking a the time to look over things and give it a cleaning you can save a lot of money.
on Dec 03, 2009 | Heating & Cooling
Door gasket Very hot and also metal strip very hot asa well
Check if condenser fan motor is running and condenser unit - it might be full of dust and lint - clean it! It is dangerous for both compressors if that fan motor has stopped working! These parts located on top behind that alluminum grill, on right hand side. Sub Zero refrigeration condenser cleaning - Read instructions here:
http://www.subzerolosangeles.com/how-to-clean-a-condenser-on-a-sub-zero-refrigerator/
Sub Zero refrigerator repair service and parts in Los Angeles
Jul 21, 2014 | Sub-Zero 690 Side by Side Refrigerator
The ice cube indicator is blinking
From the manual:
The Control Center monitors refrigerator and
freezer temperatures as well as the ice maker
system. If there is a temperature or ice maker
problem, you'll be alerted by a flashing
SERVICE indicator light. This same SERVICE
light will also flash if the condenser needs
cleaning. Before calling for service, please
check and see if your condenser area needs
cleaning. Refer to Condenser Cleaning,
page 22.
CONDENSER CLEANING
In all Built-In models, the condenser is located
behind the grille. First, remove the grille. Then
using a soft bristle brush, vacuum to remove
dust and lint from the condenser. NOTE: To
avoid bending the condenser fins, be sure to
vacuum in the direction of the fins (up and
down). Clean the condenser area every three
to six months.
CAUTION
Before cleaning the unit, shut the electricity
off at the control panel. When you
clean the condenser, wear gloves to avoid
injury from the sharp condenser fins.
Failure to clean the condenser could
result in temperature loss or mechanical
failure or damage.
Mar 14, 2011 | Sub-Zero 650 / O Bottom Freezer...
My LG Artcool isn't working keeps flashin ch 61
CH61 means Condenser coil temp high due to non cleaning of condenser/over charged gas/non condensable gas.
Clean your condenser coil. If still problem rests, due to non condensable gas also there will be high temp. kHnce remove the gas, flush out the system and vacumize and then do gas charging.
Dec 10, 2010 | LG Heating & Cooling
We have a flashing vacuum condenser message on our screen -- what does this mean?
It probably means that your condenser coils are dirty and need to be cleaned up. The condenser coils are the copper tubes in the back of the machine next to the condenser fan. If just vacuuming them up doesn't sufficiently clean them then you may want to get some coil cleaner from your local hardware store or whoever sold you the refrigerator.
If the condenser coils are already clean then you may not have enough airflow. Be sure you have 4 to 8 inches of free space behind the unit to provide adequate airflow.
Mar 13, 2010 | Sub-Zero 642
Vacuum condenser light of sub zero 650 is on - how to clean it
We recommend vacuuming your condenser every 3 - 6 months. Cleaning the condenser is important for the overall operations of the unit including cooling functions. A dirty condenser may lead to warm temperatures in the refrigerator and freezer. It may also cause the unit to run excessively. It may contribute to condensation or frost inside of the compartments. If the condenser is not cleaned properly it may even cause premature failure of mechanical components in the unit. Condenser Cleaning - All Models Before cleaning the unit, shut the electricity off at the control panel. When you clean the condenser, wear gloves to avoid injury from the sharp condenser fins. Use a soft bristle brush and vacuum to remove dust and lint from the condenser. To avoid bending the condenser fins, be sure to vacuum in the direction of the fins, up and down. Clean the condenser every three to six months or sooner if you have pets. 600 Series Framed and Stainless Steel louvered grilles: First remove the grille screws located at the bottom of the grille. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. Overlay Panel Grille: To remove, lift up then pull out at the bottom and down to release from its mounting bracket. Remove the two black screws in the lowest louver of the grille. Tilt the bottom of the grille out and away. It will release from the top of the grille. Model 601RG Stainless Steel Grille: Remove in a similar fashion as the overlay grille panel. 700 Series All Units: At the bottom of the unit, remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 400 Series 424/424FS At the bottom of the unit, remove the screws holding the kick plate. The condenser is located behind. 427/427R: Remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 430: First remove the screws located at the bottom of the grille. NOTE: These screws (Phillips head) are accessed with the door open. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. 200 Series 245, 249, 315W Remove the kick plate at the bottom of the unit, giving you access to the condenser area.
May 30, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero 632 cycles from 37 to 50 degrees
few things to check... condenser coil clean. dirty condenser fluctuate temp. clean condenser. evap fan motor work? open the fridge. press the switch. heard the fan? feel the frame around the fridge an freezer is hot? or cold? cold ok. hot dirty condenser coils OR condenser fan motor. or seal system problem. call a tech>.. good luck... LEAVE YOU COMMENT IF IT WAS GOOD FOR YOU... thanks
Mar 07, 2009 | Sub-Zero 632 / S
Dryers Logo
Top Dryers Experts
