Question about Saft VSE AA Ni-Cd Battery - 416086-106 - 1.2V 980mAh - High Energy
Battery exhasted problem???
It's the way that the camera reads the "energy left" that is the problem. Not all AA batteries are the same. Basically the default setting is (at least in the UK and US versions) set to ALKALINE AA batteries. If you are getting the "battery exhausted" message after putting new AAs in, chances are your batteries are not ALKALINE. You can either buy some new AA Alkaline specific batteries (eg: Duracell make them and they say specifically alkaline on the side). Or you can try to keep power on long enough to press MENU, then go to the "spanner" tab, then select "Battery Type", and select either Lithium AA if that is what you are using, or NI-MH versions. Stupide NIKON don't tell you this anywhere, and I have already chucked one of their products because of it, when actually it was fine. (Jake, Newcastle, United Kingdom, December 2012).
Nov 30, 2012 | Nikon Coolpix S3100 14mp Digital Camera...
Do you know where I could find a user guide manual for a NEXXTECH Ni-Cd/Ni-MH 2300033 battery charger?
Radio Shack 230-0033 appears to be the same charger.
I have this charger (Nexxtech branded, model 2300033) and the specs all appear to line up. However, I don't have the manual.
http://support.radioshack.com/support_electronics/71094.htm
Aug 23, 2012 | Cameras
Battery life is over need new 2 nos.battery rechargeble for my Panasonic ES 7111. need service shop near Surat, south Gujarat.
If you are not able to source the original type battery in your city then the other option is to use AA or AAA cells to match the voltage and current rating. You can choose from NI-MNor NI-CD to suit the purpose - size matters.
Oct 11, 2011 | Health & Beauty
My AA batteries wont go to full charge. They are almost new and only go to 1.35V
Make it charge till it will not fully charge,
Or the battery life is over, dont use more old battery it can be burst...
Sep 08, 2011 | Office Equipment & Supplies
THE BACK PIECE FOR THE BATTERY FELL AND I LOST IT WHERE CAN I BUY THE REPLACEMENT
These are the brands and type of AA batteries that you may use in Jazz DV165-BOX.
1. Ni-MH rechargeable battery (Empire and Powerex brand)
2. Ni-Cd rechargeable battery (Sanyo brand)
3. Lithium not rechargeable battery (Energizer E2)
4. Alkaline not rechargeable battery (Energizer brand)
The site where you can see their prices and make order is http://www.batterycanada.com/pro415.asp
Please comeback and give some ratings. Thank you for using Fixya.
Aug 17, 2010 | Jazz DV165-BOX Digital Camera
Just bought a second hand Canon Powershot SX100 IS.
Try cleaning the battery contacts in the camera first with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol.
Mar 08, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Installed new batteries and the camera will not turn on. The camera has been sitting up for 6 mo. with no use. We used energizer lithium batteries.
Try using recomended batteries:
optional KODAK EASYSHARE Docks with 1 KODAK Ni-MH Rechargeable Digital Camera Battery KAA2HR; 2 Ni-MH batteries AA, 2 lithium batteries AA; 1 KODAK Lithium Digital Camera Battery CRV3; KODAK Ni-MH 2100mAh Battery Pack, KODAK Digital Camera Battery AA (ZR6); KODAK Alkaline Digital Camera Batteries AA; 3 volt DC input AC adapter
You can even contact Kodak direct and they will send you a free CRV3 battery to test with.
(http://graphics.kodak.com/docimaging/US/en/Landing_Page/ServiceSupportContacts/index.htm)
Oct 26, 2009 | Kodak EasyShare C653 Digital Camera
Camera will not work after Ni-MH and Ni-Cd batteries used
Its not good for the batteries to combine different types but it shouldn't have affected the camera as the voltage they produce is the same. Try a couple of Eveready AA lithium batteries.
Feb 10, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Type of batteries
You can use two LB-01E 3V lithium batteries, four B-01 4PE AA Ni-MH batteries (BU-40SU charger and batteries), four AA Ni-CD batteries, four AA Alkaline batteries the B-10LPB Lithium Polymer Battery or the New B-12LPB Lithium Polymer Battery . Please note: the B-10LPB Lithium Polymer Battery, B-HLD10 Power Battery Holder and the B-20LPCE charger are included in the B-30 LBS kit, and the B-12LPB Lithium Polymer Battery, B-HLD10 Power Battery Holder and the B-20LPCE charger are included in the B-32 LBS kit.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Saft VSE AA Ni-Cd Battery - 416086-106 - 1.2V 980mAh - High Energy Logo
Top Saft Electronics - Others Experts
Are you a Saft Electronics - Other Expert? Answer questions, earn points and help others
