Question about Kenmore Dishwashers
Plastic door latch on detergent dispenser Kenmore dishwasher (model 665.1303) is detached at the base
The base of the door latch to the detergent compartment has a very tiny attachment point. The reason it probably came detached was because I manually tried to to get the latch to go over the lip of the door to the detergent compartment - it just wasn't doing it on it's own. It was just not working. Yes, we have resorted to using duct tape to close the door to the detergent compartment now! I checked and there are no screws near the base of the latch. I am afraid someone would have to take off the whole detergent dispenser just to fix that little door latch attachment now.
  • 311 Answers
SOURCE: Bosch Dishwasher Soap Dispenser Fails to Latch
Need to replace dispenser. I have access to that part; let me know.
Posted on Nov 28, 2008
SOURCE: Inside detergent compartment door will not open during cycle
to much detergent clean it out and start over
Posted on Jan 31, 2009
SolutionGuy
  • 331 Answers
SOURCE: Latch on my Kenmore dishwasher model# 363.14582100 won't close
Sharon,
The "latch keeper" has gotten out of alignment. You'll need to adjust it.
All you'll need is a phillips screwdriver to fix this. Open the door and look at the "latch keeper" (it's not on the door, but on the frame). It's the thing that the door lock/latch grabs on to when you try to lock the door. There are 2 screws holding it in place. Loosen these, pull the keeper toward you a bit and tighten the screws to lock it in. Now try your door.
This may take several attempts to get it just right, because you want the door closing tight enough so as not to allow a water leak and loose enough for you to close it easily.
If you have any questions, post back and I'll try to explain in better detail.
SG
Posted on Apr 01, 2009
  • 574 Answers
SOURCE: The soap dispenser on our Kenmore Elite dishwasher
Yes its probably the little latch that holds the door closed thats worn out.
Posted on Dec 31, 2009
SOURCE: I need to replace the detergent dispenser latch on
To replace the parts you have to buy a whole dispenser assemble for $100 to $200. To buy some time ... Get a heavy gage sewing needle - hold it with pliers and heat it red hot. Stick the hot end into the plastic door at the area where the plastic latch is (where it will line up with the far end of the latch mechanism). when it cools cut off most of the needle leaving one eight to one sixteenth (more or less) protruding. Use a drill and small bit to remove some plastic (or drill a small hole) on the spring latch mechanism. push the remaining part of the needle in or out to engage the hole in the latch.. this will hold awhile.
Posted on Sep 04, 2010
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Jul 08, 2013 | Dishwashers
Dtergent dispencer does not open
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
We have Model 665.13889. Can the detergent dispenser be repaired or replaced due to latch mechanism failure to connect?
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Mar 14, 2011 | Kenmore Dishwashers
Jul 19, 2010 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Detergent door does not open, it completes cycle without using the detergent
  1. The most common problem with the detergent doors on KitchenAid dishwashers is that they either don't open during the cycle or open only halfway. Before looking into more complicated repairs, make sure that the door is able to open. Check the seal around the door and the door latch for soap- and food-related gunk, and scrub it off if present. Sometimes this can keep the detergent door from operating properly. Consider switching detergents, as some liquids and pouch-style dish detergents can gum up the detergent dispensers. Also, make sure that there is nothing blocking the detergent door when the dishwashermag-glass_10x10.gif is loaded. Because of the location of the detergent door, a large item such as a cookie sheet or a pan can prevent the door from opening. Run the dishwasher through a cycle without anything placed in front of the detergent dispenser and see if that solves the problem.
  2. Broken Timer
  3. KitchenAid dishwashersmag-glass_10x10.gif rely on an internal timer to complete the wash cycle properly. When this timer malfunctions, certain steps in the wash process (such as the release of soap from the detergent dispenser) can be interrupted. If the dishwasher detergent door is either not opening or appears to be opening late in the cycle, this is likely the mechanical culprit. A broken timer isn't something that's simple to replace without knowledge of dishwasher repair, so it's best to consult a professional if you suspect that this is the problem.
  4. Malfunctioning Door Components
  5. For the detergent door to function properly, all of its mechanical components must be in working order. Older dishwashers' detergent doors rely on a spring-loaded hinge to pop all the way open when the timer gives the signal. If the door doesn't swing all the way open instantly when it's manually released, the spring may need to be replaced for the dispenser to operate properly. If the particular model is newer and does not rely on a spring to open the door, chances are it either uses a wax motor or a bi-metal switch to release the detergent door at the appropriate time. If either of these components is dying, that can mean that the detergent dispenser will not operate properly.
thank you
vijay(vote for me)
Sep 23, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
Rinsing detergent from dispenser
Use gel run a few cycles and help clear and then don't overfill w gel soap
Nov 13, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
The cover of detergent dispenser does not open..
It is most likely the flip spring...you need to be certain that the legs of the spring are inside the door edge and the spring does not swing freely...and there must be tension on the spring so that when the latch releases the door flips...you can also try this with an elastic, put the elastic inside the closed door and up around the drying solution knob, this will let the door flip open showing that the latch does work
Nov 11, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
Detergent dispenser
The opening of this dispenser is controlled by a wax motor for release. If you are unable to keep the latch shut you are probably looking at the spring and latch assy. This is not a hard job, but you have to open the inner door to get at the latch. Part numbers for the spring disp. flap is 912547. The latch (inside door) is 99001291. If you take your time and observe carefully the job will be easy. Catriver, post back.
Aug 08, 2006 | Magic Chef CDB6100 Built-in Dishwasher
Dishwashers Logo
59 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
