Question about Canon PIXMA MP150 All-In-One InkJet Printer
COLOR PRINTING FOR MY COMPUTER
HOW DO I GET MY PRINTER TO PRINT IN COLOR ?
  • Canon Master
  • 705 Answers
From the information you given it is very difficult to resolve your problem. Basically you have given no detail at all.
Assuming You wish to print a colour document via the PC using a Windows based PC with the correct drivers installed and a full set of ink carts:
1 Press [ON/OFF] to turn ON the machine.
2 Load the paper in the Auto Sheet Feeder. (See page 23)
3 Create a document or open a file to print.
4 Open the printer properties dialog box.
   (1) Select [Print] from the application software's [File] menu.
   The [Print] dialog box opens.
   (2) Ensure that your machine is selected (1).
   (3) Click [Preferences] or [Properties] (2).
   The [Main] tab of the [Preferences] screen is displayed.
5 Specify the required settings.
   (1) Click [Media Type] to select the type of media loaded in the machine
   (2) Specify the print quality and other settings in [Print Quality] or [Color/Intensity] AT THIS POINT, you need to ensure the box entitled GRAY SCALE PRINTING is NOT checked. Also ensure the Colour/Intensity option is set to AUTO
   (3) Click [OK]
6 Print the document.
   (1) Click [Print] or [OK]
   The machine starts printing
If any of the umpteen assumptions I have had to make are incorrect then post here what your exact configuration is and I will en devour to account for those particulars.
Posted on Oct 14, 2007
SOURCE:
Print color photos with windows 10 and HP printer
First and foremost, use the most current HP drivers for that model of printer. The two choices you have are printing in color directly via the printer itself. Naturally you can print from the class or inserted USB/Card reader slot. OR you can print from the Computer's devices matched to the printer. To get proper results: Down load the current updated HP drivers for your computer to communicate with the printer. Use the HP software to select either color or b/w. Also make certain the HP Printer FIRMWARE is up-to-date. If all of the software is current, you should only need the HP programs to select your choices and no other apps are necessary.
Jan 12, 2018 | HP Office Equipment & Supplies
It will copy in color and print the test page in color it will not print from the computer in color
check printer properties from the computer on the printer .
When you print see is there is a printer properties setting.
it will most likely be monocrome printing or B/w printing
Apr 27, 2016 | Office Equipment & Supplies
I just installed new printer cart light magenta & magenta the self diagnostic shows them as loaded and 100 %. The print quality pattern does not print any color for either of them? No error codes?? I have...
printers will only print black and white unless you change the print settings to be color
before you go to print find the printer settings or options and make the default setting color
that way it will print exactly what is sent from the computer to the printer
Feb 07, 2016 | HP Photosmart C6200 C6280 Inkjet...
Why won't my Lexmark 5600- 6600 Series Printer print in color?
It could be the print setting on the application where you're printing from. Before you send your print job and hit "Print" button on your computer, check in the Printing Preferences and make sure it is not set to print "Using black ink only.".
Mar 06, 2012 | Lexmark Office Equipment & Supplies
Printer has ink but wont print in color test page wont print in color, also aligned printer and it worked in color. cleaned printer head as well which printed all the colors. what else can i do? It seems...
Take color copy, test all colors are OK..Go to printer properties, printing preferences, finishing check is there any check mark on print in black cartridge only? mark on print color..apply..OK.. give print command..
Go to paint draw a color drawing, print it.> check colors if its not printing in color it might be drivers issue.. un install the drivers re install once again check..> if printed in color check the file which you are printed..take another file.. then test..
Oct 29, 2011 | HP Photosmart C6180 All-In-One InkJet...
I have an HP officejet 4215 printer. I cannot get the cartridge (color) 57 to print color! It has been working fine with the smaller cartridge but due to high level of printing, I was told to get 57. I...
If all the the computers connected to this printer via network:
  • Shut them all down except for one.
  • Go to that computer and go to your printer and fax settings
  • Identify the Hp OfficeJet 4515 and right click on the icon and select properties
  • On the General Tab, click on the button that says, "Printing Preferences"
  • Select the "Features" tab and go down to Color Options and check to see that the radial button is green for Print in Color option
  • Underneath that, there is another setting thatsays, "Color Management".
  • Check to see that it is already selected with, "ColorSmart/sRGB or Adobe/rgb
  • Click Ok and return to the Properties
  • Go to Color Management Tab and check to see that it is set to Automatic.
  • Underneath that, you'll see "Color Profiles currently associated with this printer.
  • Look to see that the field is populated, if not click on ADD, and select each color profile that is available
  • Click apply, then OK
  • Shutdown Computer
Turn the printer off, unplug the power from it, wait a couple of minutes, then plug power back to printer, then power it up.
  • Restart the computer you were working with
  • Go to printers and fax options window
  • Select the HP OfficeJet 4515
  • Right click, select properties
  • On General tab, click on, Print Test Page
  • Go to printer to see if printing test page
  • Check to if the Microsoft Windows logo was printed in color
If it is in color, then print the color document you were previously attempting in color.
If it does not print in color, you will have to check your settings on the program that is being used for the document.
Jun 02, 2011 | HP Officejet 4215 All-in-One Color Photo...
Lexmark X1100 printer will not print black
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
Oct 04, 2008 | Office Equipment & Supplies
The printer prints fine in black, but will not print in color.
try to make a color copy from the all-in-one and if it prints good, then try to print a test page from the computer and check whether the color is printing or not, if the color is printed then check whether the print in grayscale option is enabled or not, if it is enabled please disable it.
May 21, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Problem: Only printing Black/Greyscale
The printer software has probably been set to print in grayscale. Follow the steps below to check this setting:
  1. In the software application being printed from, click File , then Print . The Print dialog opens.
  2. Make sure the correct printer is selected, then click Preferences . The printer Preferences dialog opens.
  3. Select the Color tab, then make sure that Print in grayscale is not selected
Please let me know if still you cant print color. Its intresting. :)
Jan 25, 2008 | HP Officejet 7210 All-In-One InkJet...
Computer doesn't print color
Hi, the problem seems with the logic board inside the printer, are you in a position to open the printer and try some stunts, that is only if you have done it earlier.. let me know??
Dec 17, 2007 | HP PSC 750 All-In-One InkJet Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
60 people viewed this question
Clive
Clive
old marine
old marine
Ekse
