Question about Zazzle Planet Mercury Blackberry Bold Cases
How big is mercury - Zazzle Planet Mercury Blackberry Bold Cases
Radiator fan
remove the relay and test it across the battery ,the two big connectoprs are the fan power supply and two smaller ones are the relay ,test the smaller one across the battery and see if it clicks ,if they click then test the big ones for continuety when the small ones are connected and gone click .Simple if all ok then test for power in the big connectors in the relay holder ,one of them should read a permanant 12v supply
Dec 27, 2013 | Mercury Tracer Cars & Trucks
2@yahoo.comI'm trying to locate the fuse layout for a 1994 mercury sable
i have pictures for the layout but there file size is too big to post on here.
Oct 24, 2010 | 1994 Mercury Sable
I have a 2000 Mercury Cougar, I need help determining what kind of transmission I have..Any one know how you find that out, plus, where is the transmission range sensor located..
If it is the original transmission, you can contact the Mercury dealer (parts dept) with the V.I.N. # and they can pull it up on the computer
Oct 07, 2010 | 2000 Mercury Cougar
Where are all of the freeze plugs in a mercury sable 2000
look in block and the cylinder head for a round metal insert ,these are the core plugs you also have a big one behind the gearbox bell housing
Jan 12, 2010 | 2000 Mercury Sable
Finding the thermostat on a 95 mercury tracer
Find the lower radiator hose - the big one attached to the bottom of the radiator. Follow that back to the engine. It'll attach to a housing of sorts, and the thermostat is inside that housing.
Dec 06, 2009 | 1995 Mercury Tracer
Need to know location of blower relay to be able to repair car
its under your hood engine bay area usually on the fender. ITLL BE A LITTLE BLACK BOX. with a cover on top.open cover and you will see relays and some big fuses.
Oct 07, 2009 | 1998 Mercury Tracer
Replace fuel pump on a 1999 mercury grand marquos
you need to remove the tank. the fuel pump is inside about 6-8 bolts. the big pain is the straps that hold the tank in try not to bend them at all.
Jul 03, 2009 | 1999 Mercury Grand Marquis
Crankshaft damper pulley
undo the big nut in the middle
Nov 05, 2008 | 1998 Mercury Sable
Where is the starter located on a 1993 mercury sable engine
trace the big cable that came from the positive terminal of your battery. at it's end is the starter.
or if it passes trough a big relay, then there is another big cable from that relay that would go down to the side of the engine, either left or right, that would be the starter.
tnx 4 using fixya,
drcool
Oct 04, 2008 | 1993 Mercury Sable
Zazzle Planet Mercury Blackberry Bold Cases Logo
66 people viewed this question
Top Zazzle Optics Experts
james laughton
james laughton
ray gallant
Are you a Zazzle Optic Expert? Answer questions, earn points and help others
