Question about GE JEB1095 Convection/Microwave Oven
Light in convection shorted out when replaceing blub
I shorted the light when replaceing the blub the oven works but I need to know what to do to get the light to work
  • Anonymous Mar 31, 2014
    Under cabinet blubs blow out new ones won't work fan works inside blub works too
  • GE Master
  • 9,098 Answers
This is most often caused by the filaments shorting when the bulb blows, or by not disconnecting the microwave from the power line when removing or installing a bulb.
This is a problem with the control panel assembly, which we repair nationwide for $39.95.
We have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams by entering your model number here: http://tinyurl.com/gv383
Posted on Oct 12, 2007
I have a panasonic microwave with convection oven, grill and steamer. When I switch on the microwave, the house fuse (16 amp) cuts out. With the other functions of the oven, it works fine. Do I need a new...
you have a short circuit.
test the a) HV rectifier b) Capacitor HV c) HV transformer d) Magnetron e) test the swich for door for short.f) circuit board main is short.
see the diagrams and proceed.
10_2_2012_12_41_44_pm.jpg10_2_2012_12_42_15_pm.gif10_2_2012_12_42_35_pm.gif10_2_2012_12_43_09_pm.jpg
Oct 01, 2012 | Panasonic NN-C994S Convection/Microwave...
Bought house with GE Profile Convection Oven. Do not know proper cooking directions, nor how to work many of the features. Also no light bulb in it & would like to know which one to buy. Need manual t
GE has the manuals for most of their appliances on their site: http://www.geappliances.com/service_and_support/literature/ . Just enter the model number and click Submit.
The direct link to the manual for the JVM1790 Over-the-Range Convection/Microwave oven is here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40480-1.pdf . GE only lists the JVM1790CK, JVM1790BK, JVM1790WK and JVM1790SK.
I hope this helps.
Nov 10, 2011 | GE JVM1790 Convection / Microwave Oven
I have a panasonic convection/microwave. Last night, after I cleaned it, using oven cleaner on a sponge, it made a loud humming noise after running on microwave for about 10 sec. It does not make the noise...
Since the unit makes the noise on Microwave but not convection it is a problem it he Microwave Circuit. Probably in either the rectifier of bad mag, one of them shorted. Just looked at the date you posted this, Im sure you have fixed or replaced this by now
May 31, 2017 | Panasonic NN-C980 Convection/Microwave...
I have an R-8310 Sharp Microwave/convection oven. It just quit working while I was baking potatoes. There is no light and no sound. How old is this oven? Am I in the market for a new one? VLC
This is a 1985 model.
I would bet that the magnetron overheated, tripping the thermal cutout on the magnetron.
This can happen if the internal cooling fan is not running, or if the vents are blocked, or if the magnetron is failing and running hot, due to age in this case I would bet.
If you or someone you know can check and replace the defective parts, it would probably be economical, especially since this is a convection model.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
If you don't use the convection feature much, a simpler replacement oven may be the way to go.
You can find the bulk of the service manual with parts list online here.
Once you have part numbers, you can get pats at a good price from Encompass here or you can call them toll-free at 866-779-5835.
Oct 10, 2009 | Sharp R-1210 Microwave Oven
GE Advantium Oven - LED lights went out.
if anything like my own it is the led blub thats blowen - major hasel to change out - get some one who knows these cookers/ovens...
Aug 07, 2009 | GE Monogram ZE2160SF Convection /...
Convection Oven has stopped working
magnetron may be defective . replace d magnetron
May 29, 2009 | GE JVM1790 1000 Watts Convection /...
GE JVM1190 control pad
It is not your key panel, but the magnetron inside the microwave that is causing you the problem. The reason it does not short out on defrost or convection is because it is not drawing as much current through the magnetron to short out.
Oct 31, 2008 | GE JVM1190 Microwave Oven
Short circuited Whirlpool MH1150XM while changing the bulb underneath. Need help to fix it, thanks :)
We replaced the board behind the control panel. $130.00. If you do this make sure you can put the wires back the right way. My husband finally got it and our micro is working like brand newThanks to all who tried to help.
Sep 29, 2008 | Whirlpool MH1150XM Convection/Microwave...
My microwave/convection oven blew a fuse. replaced it and the convection works but when I try to use the microwave it blows the fuse again. what needs to be fixed?
Typically, when the fuse blows in the microwave, the high voltage capacitor fails and becomes shorted.
The door switches are also configured in such a way that if tampered with (in this case, failed switch or latch) the fuse will also blow. Check the capacitor first.
If you need further assistance let me know
Regards,
reg501
The FixYa Team
Jun 19, 2008 | Microwave Ovens
GE JEB1095 Convection/Microwave Oven Logo
60 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
