Question about El Mexicano Achiote Verde
Need a recipe with achiote verde - El Mexicano Achiote Verde
Tv green light flashes
cuando le dan a prender prende el led verde y la tv prende prende por 3 segundo presenta en la pantalla el letrero sony y se apaga la tv y el led verde. luego prende el led rojo 2 parpapadeo pausa larga 2 parpadeo y pausa larga y se repite
Dec 08, 2013 | Sony BRAVIA KDL-40V3000 Television
COMO CUANTO COSTARA LA CONVERGENCIA DE COLOR VERDE
If can speak English I can help as my Spanish is limited---the convergence of green cannot be adjusted except in technical menu and if bad needs both the stk-392-110 chips replaced first.
May 29, 2012 | Toshiba 42H81 42" Rear Projection...
Hi I need to know if I can switch the direction my hunter green Lasko fan is turning it is going clockwise and I would like to reverse it for the summer can't find a switch we've have it for...
Turn the fan off. Locate the reversing switch. It is on the base of the fan near the fan speed and light switches. if its not on the remote control. have a good day !!
If it does not have a revesing fan switch and its older, You may have to physically(with fan stopped)
Push blade in from end and twist blade for reverse air.
Jun 22, 2011 | Hunter Traditional Southwest 52" Ceiling...
Cambie el filtro por uno nuevo y la luz sigue prendida en rojo como cambio a color verde
Una vez que filtran la luz se vuelve roja, sigue siendo rojo hasta que se resetea. Para restablecer el indicador del filtro, presione ambos LOCK y DISPENSADOR DE AGUA
botones simultáneamente y mantener durante 4 segundos. Hacer luz verde que parpadea tres veces cuando el indicador
se restablece.
Feb 05, 2011 | Maytag MSD2655HE Side by Side Refrigerator
Green pantalla
Checa las resistencias que tiene el conector de la pantalla probablemente una esta reventada
Oct 02, 2008 | Insignia IS 20" TV040919 TV
El Mexicano Achiote Verde Logo
466 people viewed this question
Top El Mexicano Cooking Experts
Tom Chichester
ray gallant
Are you an El Mexicano Cooking Expert? Answer questions, earn points and help others
