Question about Cycling
Timer won't turn off on 1980 schwinn airdyne
Timer works, but doesn't turn off
  • 990 Answers
SOURCE: Need users manual for old Schwinn Airdyne - analog model
Sheldon Brown's Bicycle glossery is a good place to start, you can google him and he may be slow on replys but he can usally steer you in the right direction.
Posted on Aug 21, 2009
Testimonial: "I emailed Sheldon Brown. Larry"
  • 1138 Answers
SOURCE: purchased a schwinn airdyne 4 need assembly instructions
Try this link:www.proterapi.dk/.../DWSDownload.aspx?...Files%2FFiler%2FPT%2FService%2FBrugermanualer%2FCykler%2... - If that doesn't work, try this one:http://www.proterapi.dk/Admin/Public/DWSDownload.aspx?File=Files%2FFiler%2FPT%2FService%2FBrugermanualer%2FCykler%2FAirdyne_engelsk.pdf I hope this helped.
Posted on Nov 29, 2009
SOURCE: older schwinn airdyne manuel
figured it out
Posted on Feb 04, 2010
terpcafe
  • 16 Answers
SOURCE: I bougt a used schwinn
Your computer's pickup magnet pickup sensor is not reading the magnet as you spin the bike. You probably have too much of a gap in between the magnet sensor and the magnet on your bike. Gently push the metal bracket holding your magnet sensora bit to close the gap and it should then read your magnet, calculate RPMs etc. Terpcafe@yahoo.com
Posted on Oct 24, 2010
terpcafe
  • 16 Answers
SOURCE: I need to tighten the chian on my schwinn airdyne.
Two places to tighten the chain and it requires you to loosen the nuts on BOTH sides of the bike, almost at the same time. Start at the fan wheel (top) of the bike. First thing you need to do is to loosen the little nut at the hub of the fan wheel on both sides. Unscrew it almost to the point of taking it off, but leave it screwed on the end of the bolt so it will stay on the bike. Then use an adjustable wrench to loosen the nut a bit on one side and then do the same on the other side OR use both hands and loosen both at the same time by unscrewing with adjustable wrench in opposite directions on both sides. Once the wheel is loose, you want to sit in front of the bike and pull both of the large nuts at the same time toward you and the chain will tighten. The goal is to have the fan wheel centered and for you to be able to see about 1/4" inch of clear gap behind the nut on both sides. Then use your fingers to tighten the nuts to the frame just enough until you can use the adjustable wrench again. I have sometimes used a flat head screwdriver to insert into the gaps to prevent the chain from loosening up. The tighten the nut on both sides of the bike. Be sure you tighten the little nuts as well (they are called chain tensioners). That SHOULD do the trick. However, if your bike chain is still too loose, you need to do the same for the chain at the pedal area, That requires the same thing all over again, but in most cases, the chain loosens at the top part of the bike (fan wheel place). However, if you do work on the pedal area, you want the chain to be pushed toward the fan and not toward the **** side of the bike. It may sound crazy but that's the only way to tighten the chain. give me a thumbs up with my solution.
Posted on Jun 06, 2011
What kind of batteries does the schwinn Airdyne take its about 22 yrs old?
Most computer console batteries for Airdynes are AA, you'll have to open up the console/meter housing in the back to replace them. I will be attaching a link to a diagram of the housing. Hope this helps, sincerely SportSmith..
http://www.sportsmith.net/images/product_support/schwinn/service_manuals/Airdyne%20Evolution%20electronic%20trouble%20shooting.pdf
May 21, 2015 | Schwinn Cycling
Tip
Identifying Your Schwinn Airdyne
How To Identify the Model of a Schwinn Airdyne Exercise Bike
  • We'd like to share some characteristics of the Schwinn Airdyne bikes that can be used to help you identify the model of your Airdyne bike.
What size/type fan does it have? Is it a spoke fan like a bicycle wheel or short wide blade fan?
Does your Airdyne bike have two chains or a chain and a belt?
  • AD3, AD4 bikes have two chains.
  • AD Pro/Comp and AD Evolution Pro/Comp bikes have a chain and a belt.
How do the crank arms attach to the Airdyne, by wedge pin or bolt?
  • AD3, AD4 and certain AD Pro/Comp crank arms attach by wedge pin.
  • Certain AD Pro/Comp bikes have crank arms that attach by bolt.
  • AD Evolution Pro/Comp bikes have crank arms that attach by bolt.
How To Identify the Model of Schwinn Airdyne Bike
on Mar 11, 2015 | Schwinn Original Airdyne
Schwinn airdyne computer battery
it may need to be calibrated. Call schwinn or Treadmill Doctor at 800-750-4766 to walk you thru the calibration.
Jul 11, 2012 | Schwinn Airdyne Ad4 Upright Bike
Lost the small (black) battery cap that holds the button (357) battery in place. It's an older AIRDYNE. Located just below the odometer or timer. Presently holding with Gorilla tape.
That part is no longer made, stopped making them in 1990. You will simply need to use a watch to time your workouts. That's all it does anyway.
Feb 05, 2011 | Schwinn Original Airdyne
I need assembly picture or diagram for original airdyne.
Here is the diagram for the original Schwinn Airdyne. Only the computer is different.
Aug 25, 2010 | Schwinn Original Airdyne
Battery missing for exercise bike
I have a Schwinn airdyne (model AD-3) that uses a button type battery in the count-down timer, which is above the work load indicator or the 'speedometer'. According to the manual I was given with the bike, it utilizes a 1 1/2 volt watch - type battery (LR44, A 76 or equivalent).
Hope this helps.
Apr 02, 2009 | Cycling
Cycling Logo
43 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
