Question about Schwinn Cycling
1980s airdyne replaced battery. Timer won't turn off
Replaced battery and now timer won't turn off
  • 123 Answers
SOURCE: Replaced XD300U projector lamp.
How to reset the operation time meter
Plug in the power cord, turn on the main power
switch, and reset lamp time by pressing the VIDEO
button and ENTER button for 3 seconds simultaneously.
• Make sure that the STATUS indicator flashed
twice and the operation time meter has been
reset.
Caution:
• Do not spill liquid on the lamp or place it near
flammable objects or where children can touch it.
Otherwise, it could cause injury or fire.
• Be sure that the projector guide is firmly inserted
between the right and left lamp guides.
Important:
• The projector will not turn on if you do not secure
the lamp lid.
• You must reset the operation time meter after
you replace the lamp.
• Do not reset the operation time meter unless the
lamp has been replaced.
Posted on Apr 21, 2008
vatticus
  • 20 Answers
SOURCE: replaced ctm unit and truck won`t stay running.
there are 2 sensor on the carb . you may need to replace both to find out whiche one it is . try this also give it gas while starting and when it starts you will have to keep your foot on the gas a little to keep it running if it runs that way its one of the 2 senors .
Posted on Jan 21, 2009
SOURCE: Gilmour 9400 water timer won't turn on
Well, I have the same problem. In fact, I just took mine apart (look for 4 screws on the back gray plastic) and found that the gears are stripped. About 3 of the teeth are broke off. I've been looking for parts on the Internet, but no luck yet. I'm afraid the only solution is to purchase a new timer.
Posted on Jul 11, 2009
SOURCE: dryer won heat timer dosen't avance
9 times out of 10 check your fuses there r usually 2 for your dryer that most people dont know about 1 of them is for the power and the other one runs the timer and heat
Posted on Aug 27, 2009
projdoc
  • 2237 Answers
SOURCE: same problem as jhart267. replaced bulb unable to
hold down the enter button, down arrow button, and the right arrow button, then press power. that'll reset the lamp timer.
Posted on Dec 16, 2009
The timer won't turn lights on either with program timer or by using on/off buttons
1) Timer is not fully identified.
Copy following link for replacing CR2 battery in the Intermatic ST01c
http://waterheatertimer.org/ST01C-program.html#battery
2) If this is not your timer, then add comment and describe timer in detail, and/or include model number and attach photo
Dec 20, 2012 | Intermatic Inc. ST01C Digital In-Wall...
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
The on/off button quit working. I can't manually turn lights on/off. In wall timer ST01AC
Thank you for including timer model number.
You have almond-colored ST01AC timer that worked before and then stopped working.
The manual override no longer turns lights on-and-off.
Manual override works by pushing in timer door, and also by pushing on-off button on face of timer.
1) Try pushing on-off button directly instead of timer door, in case little plastic point on timer door has worn down. If timer door is worn down, maybe add a few layers of tape so door can push button again.
2) If timer on-off button is not working, then timer may be defective -or- timer CR2 battery needs to be replaced, and then timer reset and reprogrammed.
3) Defective timer: timer has 1 year limited warranty against workmanship defect
http://www.intermatic.com/customer%20service.aspx
4) Replace CR2 battery, reset timer, and reprogram timer and see if functionality is restored.
If timer is not restored, then timer is going bad.
Open following link for illustration of battery replacement, steps for resetting timer, and illustrated re-programming steps.
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Intermatic Inc. ST01C Digital In-Wall...
2001 keyless entry not working Problem I have replaced the battery and now the remote won't work
  • It is possible to register up to 3 sub-key codes including the already registered key code.
  • When any operation time described below is over, registration mode completes.
  • When the next procedure is performed while the timer is working, the timer completes counting time, then next timer starts.
  1. Depressing brake pedal and acceleration pedal:
89456888
Aug 22, 2011 | Toyota Corolla Cars & Trucks
Lost the small (black) battery cap that holds the button (357) battery in place. It's an older AIRDYNE. Located just below the odometer or timer. Presently holding with Gorilla tape.
That part is no longer made, stopped making them in 1990. You will simply need to use a watch to time your workouts. That's all it does anyway.
Feb 05, 2011 | Schwinn Original Airdyne
Battery cover & battery type for ergometer older unit
The battery cover is no longer made since this bike was last built in the late 1980's. I would recommend giving the man a timer/watch. I do have one of these little black round batter covers, and would sell for $25. However, all it does is create a timer for the rider. He already can use the analog computer to see his mileage, load, and can re-set the lower mileage to zero every workout. All the battery cover will allow is for him to set a timer for how many minutes he wants to workout for. Or he can pust the start button to time his workout. (my email is terpcafe@yahoo.com)
Jun 19, 2010 | Schwinn Original Airdyne
Battery missing for exercise bike
I have a Schwinn airdyne (model AD-3) that uses a button type battery in the count-down timer, which is above the work load indicator or the 'speedometer'. According to the manual I was given with the bike, it utilizes a 1 1/2 volt watch - type battery (LR44, A 76 or equivalent).
Hope this helps.
Apr 02, 2009 | Cycling
Kenmore Dryer Timer does not advance
Timer resistance is way too low. You may have misswired the new timer. Basically, when the dryer motor is running, the timer motor gets voltage 115 volts.
Apr 14, 2007 | Kenmore 64902 Electric Dryer
Cycling Logo
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
