RCA ViSYS 2-Line Speakerphone Logo
Posted on May 07, 2009
Sounds There are clicking sounds and the sound of another phone being lifted up while I'm in conversation(but no one else is home), Feedback and echoes, the phone company did a check on the line 3 TIMES nothing. But two days later it's back,is anyone else having this issue?
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on May 07, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
2753
Points
14
Two possibilities:
1. Do you have DSL service on one of the lines? This can cause line noise.
2. You may have crosstalk between the lines OR between the lines and an AC power line. The phone lines need to be run with Category 5 wiring, which is twisted and shielded to prevent lne noise leakage.
3answers
How do i turn the volume up on a alcatel 2038x
Your phone uses sounds and vibrations to alert you, including ringtones, app notifications, alarms, and navigation feedback. You can customize any of these sounds, as well as control their volumes.
  1. Change default ringtone for incoming calls
  • Touch "Settings" icon from Home screen or under main menu.
  • Touch "Sound".
  • Touch "Phone ringtone." You will see a list of ringtones
  • Touch a ringtone to select and hear it.
  • Touch "OK" to confirm your final selection.
2answers
How to silence keystrokes?has load clicking noise
From home screen, not within Swype, go to Menu>Settings>Language and Keyboard>Swype Settings>deselect Audio Feedback.
1helpful
I have an enV3 9200, I would like to know if I can record phone conversations.(i live in Ohio) It just states "Not allowed during Calls" when i try options/main menu /music and tones/my...
It is possible to record your phone conversations. Sounds like you are trying to activate a voice recorder while you are talking on the phone (this would only record one side of the conversation anyway - yours). Here is a website all about <a href="http://www.recordphoneconversation.com>recording phone calls </a>
1helpful
Google Nexus One Incoming call Problem
Activate haptic feedback so you can feel the vibration. In the home screen press the button at the left of the home button and select Settings->Sound At the bottom of the Sound settings menu select "Haptic feedback".
Clicking sounds and message envelop appears
Make sure your phones have the filters on them if the modem is pluged in on same line, this envelope is telling you that you either had missed calls or messages receved go into it and view all missed calls , it will then go away.
My lock button as well as my sound buttons won't work
It sounds like you may have accidentally turned them off. To make sure the sounds are on, do the following:
1. Click on "Settings"
2. Select "Sounds"
3. At the bottom you will see "Lock Sounds" and "Keyboard Clicks".
If the sounds are on, I would then recommend preforming what's called a "Soft Reset". To preform this, do the following:
1.Press down the "Home" button and the "Lock" button at the same time.
2.Hold these buttons until you see the apple logo appear.
3.The iPhone may take up to 2 minutes to come back to your "Lock Screen"
This should fix your problem.
1helpful
While engaged in a phone conversation dial-up sounds come in
sounds as if you have a tap on your line in which the phone company has half tapped you to another customers line pair. call you local phone company.
2helpful
I have video but no sound using SKYPE.
It sounds like you're asking whether headphones are necessary to the Skype experience.
You don't absolutely *need* headphones (or a microphone or a headset that has both), but if you don't use headphones, then your Mac external microphone might pick up the sound of your conversation and you might get unpleasant levels of feedback.
If this doesn't answer your question, please write back with the following information:
1. Your Skype version (click Skype --> About Skype)
2. Your model of Mac
3. Whether you are having problems with your audio
- On Skype only?
- On other applications?
- In general?
4. Whether you have tried clicking on "Skype Test Call"
- Whether you could hear the voice giving you instructions
Thanks!
1helpful
Uniden Power Max 5.8 - (TRU8880-2)
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
please rate this post
Volume and feedback sounds
I suggest you read the manual to see if it solve your problem if not then contact me again ok http://www.vtechcanada.com/en/support/manuals/resources/5867.pdf
Top RCA Lands Phones Experts
k24674
SmartAviator
SmartAviator
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
