Question about Plumbing
Onga rivaflow gp40 failure light keeps coming on
Big rainwater tank ran dry and so electric Onga pump that normally pumps water from big tank to little overhead tank kept failing. Have since refilled big rainwater tank, but pump keeps failing. Have
Release AIR lock. Air has got trapped in the pump hence it cannot create necessary level of suction. The way normally you do this by filling the water path of the pump with water and get the air released.
Oct 12, 2014 | Plumbing
My onga pump has lost pressure ,it was working fine , but now it's not. It kicks in and the failure lite comes on.
Sir/Ma'am, All you can do is replace it, they cannot be repaired economically. No fixinya in this case just R&R! (remove and replace)
Sep 19, 2014 | Cars & Trucks
Wont work ongas
Is it automatic ignition? check gas supply, jet clear and thermal safety cutout.
Apr 06, 2014 | Refrigerators
What kind of lubricant do I use for a Bachmann EMD GP40
A light- plastic compatible oil for the wheel bearings, (a drop on a tooth pick)
grease for the gears- a very small amount, a plastic compatible grease
DO NOT USE 3 in 1 oil or WD-40.
lubrication kits are available at your local hobby shop
or online train dealer...
Labelle, Bachmann, Atlas all offer lube kits.
Oct 09, 2011 | Bachmann 63598 Alaska Emd Gp40 Diesel...
New onga JS120 pump worked fine for 4 months bringing water from tank up to house then suddenly stopped.We undid the pipe and reconnected it,the pump worked again but stopped again after a few...
a number of possibilities like insufficient pressure in the bell or pressure leak 'or pump motor dying
but i'd be looking at a warranty claim
May 11, 2010 | Plumbing
Onga sand filter pumps sand in to pool ,just got re connected to new above ground pool
The lateral(s) are damaged and allowing sand thru and back to the pool. I have never dealt with that specific brand to know if the laterals come as one assembly or individual pieces. You'll need to contact the dealer you got the unit from or check online at http://www.onga.com.au/dealerlocator for someone in your area.
Dec 05, 2009 | Pool & Spa
Plastic impellor sticks inside on onga pool pump and i can't get free .When i try with phillips head screwdriver it is jamming and i can't loosen to get impellor off and the pump only makes noise and can't...
Your Onga Pool pump was running dry causing the
impeller to melt down and stick to the pump case.
You have to remove the impeller, and the only way
to take it off by using the heat gun to melt the stucked plastic impeller. Or by forcing it off slowly, cutting the impeller using hacksaw, taking care of the mechanical seal and the motor shaft not to bend it. Afterwhich you can replace the impeller, and assemble the Onga pump/motor. Then, you can
install the Onga pump back to its location. Just
send you e-mail for further assistance. God bless
you.
Oct 20, 2009 | Plumbing
Diagram to repair onga house water pump
Got an Onga Riva-Flo water pump, model number TF30, its not working, can you suggests why and how to fix it please.
Feb 20, 2009 | Northern Tool 12 Room Purple Martin House
Plumbing Logo
47 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
