Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Hunter 44665 I have a Hunter 44665 thermostat with remote sensor. I can read the temp on the sensor but it should be able to control the main thermostat. I just don't know how it is supposed to work. I have tried everything I know and what the manual says about the remote sensor is not helpful. The remote sensor is working and I can read the temp. from the sensor on my thermostat but can't control the temp.with it. Any help would be appreciated.
  • 73 Answers
Just fixed mine;
Note the sensor channel on face of remote
(ref: http://www.manualslib.com/manual/257219/Hunter-44665.html)
Mine was set on Ch15, well the thermostat only monitors 14 channels had to flick down dip switch #1 to set Ch7.
Then on the base unit thermostat, see page 5 of a similar unit for 44668/44665 manual (below) then wait about 10 minutes for things to sync up, and press remote button to check sensor temp.
Note the button order for Remote Sensor Programming at base thermostat:
http://www.hunterfan.com/SupportDocuments/OwnersManuals/44008-01Thermostat44668-44660WebR02102010.pdf
Posted on Dec 30, 2014
  • 3,368 Answers
You can get the manual at: http://www.manualslib.com/manual/257219/Hunter-44665.html
Normally these thermostats read remote temperatures but do not use them for control. The external remote sensor is normally put outside in our area yeilding an inside out side thermometer.
Posted on May 13, 2014
SOURCE: Light remote control stopped working
most of my fan controls have done this to me. you know the reciever is working cuz the fan works fine. you need to dis assemble the remote completely and clean the contacts for the light button. mine are two small black dots that seem to keep getting slimey and wont work till i clean them, then all works like brand new again.
good luck.
Posted on Mar 11, 2010
SOURCE: low battery on hunter 44422
I have the same unit, 44422. The base has four clips, two on the top and two on the bottom. The front portion is clip-on. Try to push on the base's bottom and pull off the front portion, like opening a book. After the battery replacement you will have to reset the unit trough the little reset hole. Otherwise, the ''LOW BATTERY" will not go away. Yes, you will have to reprogram the unit.
Posted on Jan 25, 2009
  • 19 Answers
SOURCE: need a wiring diagram for thermostat/hunter model44260
Hello please try this link and see if this contains the information that you need
Reply to bsix@hotmail one way or the other Thanks
http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/42711.pdf
Posted on Sep 14, 2009
milten1
  • 1304 Answers
SOURCE: Hunter 44260 Thermostat Problem
make sure you have the jumper in place
if you dont have a secondary heat source red should be on r with a jumper to rh
Posted on Oct 17, 2009
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
Hunter model 4409. How can I reset?
Reset hunter model 4409 - Fixya
www.fixya.com/support/t26079594-reset_hunter_model_4409
34 mins ago - reset hunter model 4409 - Hunter Set and Save Programmable question. ... Clicking this will make more experts see the question and we will ...
Controller Frequently Asked Questions ' Hunter Industries
www.hunterindustries.com/homeowners/.../controllers
Hunter IndustriesWhen the station or stations finish watering the controller will go back to ... How do I reset my Hunter controller · How do I address the Wireless Solar Sync sensor ...
CodeLink®, Steering Angle Sensor Reset Tool, Wheel ...
www.hunter.com/alignment-systems/codelink
Hunter Engineering Company's CodeLink® steering angle sensor reset tool plugs into a vehicle's OBD-II port.
Feb 03, 2016 | Heating & Cooling
Why is Hunter thermostat temp is wrong ?
The most likely problem is the wall on which the thermostat is mounted. The thermostat is designed to read the temperature of the space in the room, but if the wall is exceptionally warm or cold it can really throw off the actual reading.
Options might be to stuff insulation into the wall behind the thermostat, or relocate it to a wall that is more consistent in temperature with the actual temperature in the room.
May 11, 2014 | Hunter Fan Company 5/1/1 Programmable...
Programming the remote sensor to the 44665 hunter thermostat
Just fixed mine;
Feb 05, 2012 | Hunter Fan Company 5/1/1 Programmable...
Flashing time on a Hunter Programmable Thermostate #44665
Teresa
have a cental air guy in for a check up on your units. they may need servicing
Jul 22, 2010 | Hunter Fan Company 5/1/1 Programmable...
I need to program the 44665 thermostat
enter "hunter 44665" in your internet search box, it should give you several sourced of the manual, both free and for a charge.
Good luck,
Gilshultz
Dec 03, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter remote controlled cieling fan does nothing when turned on
I don't believe there is a fuse in a Hunter Fan. Have you checked your breakers or the wall switch? Make sure you have power up to the fan.
Kurt
Mar 13, 2009 | Hunter Fan Company 5/1/1 Programmable...
How do you set the thermostat??
hi
you may get a pdf download of the manual form this site Programmable thermostats at discount prices at hunter-thermostats.com.
they may have the model you require .
riz.
Feb 26, 2008 | Hunter Fan Company 5/1/1 Programmable...
Programmable Hunter Thermostat
hi
this site as the owners manual you can download in pdf . if this helps you out .
riz.
Nov 14, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
357 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
